Xtreme-scooters' XB-310Li
Postby The Stig » Thu Oct 29, 2009 9:05 am
Hi sphere members,
I went ahead and bought the XB-310Li. It seems to be as described and is working fine so far, Works the way its supposed to. Chinese build quility but not bad. Haven't done any range or speed tests yet although I should.
I took apart the plastic part on the back that houses the controller because I'm thinking of doing some sort of shunt modification for a little more current. I was hoping to get some advice about that here. The controller board wouldn't budge easily from inside the aluminum casing so there are no pics of the whole board. I'm also thinking about 36V. Maybe someday I'll replace the cells in the battery pack and rearrange for more voltage. Also could someone identify that hubmotor?
I took lots of pics of the important parts you don't see on any of their websites:
I would appreciate your impressions and feedback/opinions/whatever.
"Not brushes" haha typical chinese labelling...
LATEST UPDATE: Folding hinge gasket modification http://endless-sphere.com/forums/viewtopic.php?f=3&t=13910&p=551869#p551869
The Stig
Re: Xtreme-scooters' XB-310Li
Postby TylerDurden » Thu Oct 29, 2009 9:20 am
The Stig wrote: The controller board wouldn't budge easily from inside the aluminum casing so there are no pics of the whole board.
The cover should slide off; the board will be likely screwed to the case via the FETs.
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby The Stig » Thu Oct 29, 2009 9:46 am
Ah thanks for drawing that out, I didn't notice that.
The Stig
Postby morph999 » Thu Oct 29, 2009 10:18 am
how do you like it so far?
morph999
Postby The Stig » Thu Oct 29, 2009 11:43 am
I like it, its well equiped and has non-junk bike components. Its not a powerfull ebike, but it folds easily and will get me places easily legaly and safely.
The Stig
Postby The Stig » Tue Nov 03, 2009 12:00 pm
I wouldn't like to do a shunt mod on this controller to up the Current limit from 14A to about 20A. How do I do a shunt mod, or increase the current limit?
I haven't got a picture of the whole board because the top of the case is glued on but I believe the shunt in this picture, on top of the board and to the left(where all the black wires connect too).
The Stig
Need help with a shunt mod
Postby The Stig » Wed Nov 04, 2009 11:04 am
Bump - I need some help with a shunt mod.
Also can anyone identify the hubmotor in first post?
The Stig
Postby TylerDurden » Sat Nov 07, 2009 7:12 pm
I can't help with the hub, but for the shunt:
Since the shunt is a precise resistor, adding solder up one leg will reduce its total resistance because the solder resistance is lower. The lower resistance should raise the current limit.
You might try adding solder up to the halfway point, then test; continue as needed or shave off solder if limit goes too high.
Have a Nice Day,
TD
TylerDurden
Postby The Stig » Thu Jan 28, 2010 1:54 am
Another shoutout for help from the ES community as I want to turn this bike into a duel motor snow driving, mountain climbing beast.
Can anyone tell me what the hub motor that came with the bike is? I'd like to know how heavy it is and if I could take it to lets say... 36V 30Amps. 48V maybe.
Also could the controller possibly be overvolted as well as given a shunt mod? I was unable to budge the top of the casing to get a pic of the board.
The Stig
Postby MrKang » Thu Jan 28, 2010 2:18 am
I even think that the FET's are only pressed by the case and are not even screwed to the case.
So just open it up and you then can remove the board easily.
MrKang E-Scooter : 24V 750W Bosch Motor modified with YK-43 48V 1kW on 12S6P Lipo - top speed 44kmph
Xinling XTD800A : LYEN 4110 72V (modified for safe 100.8V with extra cooling) - 24S4P/100.8V 25Ah Turnigy + CA with Datalogger + SOUNDSYSTEM + USB power outlet + 78km top speed(120%)
MrKang Retro II : in progress.. ** 12FET MKII LYEN + 28S 20AH LifePO4 cells **
Project link [/color]: http://endless-sphere.com/forums/viewtopic.php?f=10&t=13442
MrKang
Postby Lyen » Fri Feb 12, 2010 2:19 am
The Stig wrote:Another shoutout for help from the ES community as I want to turn this bike into a duel motor snow driving, mountain climbing beast.
I have identified the hub motor and the controller. The brand of the hub motor is simply on the piece of sticker from you photo. It is a Chinese brand so no English name for it. You can over-volt both motor and controller. But keep in mind your battery will reduce the range dramatically and may cause potential damage to the battery circuitry if any. It is due to the battery is not designed for higher discharge from both the controller and the hub motor. Let me know or PM me if you have any other questions. :)
Items For Sale
Please sign up here and donate your marrow to save life.
Lyen
Postby bodepn » Sat May 22, 2010 1:18 pm
Recently got the Xtreme-scooters' XB-310Li from craigs list. He says it is about 6 months old so was new about Oct 2009.
It's great to find someone else that has one.
I find the hand grips to be too hard, so will change out the left one with a padded gel one. I'm 74 inches tall, so the handle bar is a little low and I have the seat fully up. (34 pants inseam).If was an inch taller would be better.
I weigh 210 pounds and the bike shocks seem to bounce a lot. I want to stiffen the ride but have not found any directions to do so.
Power wise the motor assists in all 7 gears and the only way I can stop motor is with key lock. If I am riding with someone, I have to take care not to surge past them when I start pedaling.
Battery seems to last forever. I usually can ride about 2 hours on gently rolling hills (less than 6 ft elevation changes) and return home using only used one bar of battery power. The manual indicates it is best to recharge even though battery is not fully discharged.
This morning I hit the edge of a curb and blew out my tire. So I'm going to get a 26 x 1.95 tube and check wheel rim and spokes.
bodepn
Postby The Stig » Fri May 28, 2010 9:46 pm
Glad to here from you Bodepn! I have since upgraded to a 36V 10AH battery thanks in accordence with Lyen's advice, it has the same case/mounting as the stock battery and I have a new 30A controller so now I'm very satisfied with the power and weight of the bike ;) I did use it and enjoy it for 6 months the way it came stock. All in all a good deal. Much better than commuting by foot or car at least. And it survived a full winter of salt, snow, slush and water so thats something.
However I did manage to kill it eventually by letting my girl friend ride it up a steep mountain. She isnt much a of a pedeler so after several minutes of full throttle at extremely slow speeds one of the hall sensors was fried. So I replaced it and replaced the battery, controller and throttle along on the bike with it. And now I can keep up with traffic and surpass it, even on decent hills.
So did you fix your tire?
The Stig
Postby Accelerated » Sun Jul 04, 2010 5:57 pm
Hello all e bike winners! 8)
I just ordered this xb310 today and hope to get my ass on it later this week. So excited to use it!
Question about the speed. I was told at a bicycle shop that the governor can be "adjusted" so the top speed can be responsibly advanced. What will I need to do to do this?
Thanks everyone! :mrgreen:
Accelerated
Postby The Stig » Tue Jul 06, 2010 5:41 pm
Hey welcome to the club!
20mph is pretty good for 24v with that motor. To go faster I think you would need higher voltage and thus a different speed controller. You can get a 36v replacement battery for the xb310li from BMsbattery.com and a 36v controller from ecrazyman.
Looking forward to hearing about your experiences when you got the ebike.
The Stig
Postby SergeTruth » Mon Aug 09, 2010 11:44 am
I ordered the XB-310Li. Please, write more about how to upgrade it.
Thank you,
Serge
SergeTruth
100 µW
100 µW
Postby The Stig » Wed Aug 11, 2010 2:02 pm
Hi Serge
I replaced the battery and the controller(and throttle because I wanted a thumb throttle).
The battery is in the same case and has the same mount that bolts to the seat tube. Only its a 36V 10AH Li-NiCoMn. I was told by BMS battery its good for 20A continuous and 35A Burst for 10 Seconds.
Specs:http://www.bmsbattery.com/index.php?main_page=product_info&cPath=1_2_26&products_id=17&zenid=0bbd6ffcaa154655454869875bd0b28d
When you click add to cart I think it adds the 10AH version instead of the 5AH. Its $210 without shipping. I ordered through skype though because they're not very reliable and its good to have a contact to hold accountable. http://ecitypower.com/index.php?option=com_contact&view=category&catid=12&Itemid=30 I think Annie Lei has the best english. I ordered through Mandy and she wasn't the best I got my battery about the latest she orginally said it would arrive.
The controller I got from Keywin, master of controllers: ecrazyman@gmail.com
It was the 36V 30A brushless one. I think it was 9 Fet.
For wiring the controller to the motor: "YB GG BY, both phase wires and hall sensor" -Keywin
The Stig
Postby The Stig » Thu Aug 12, 2010 6:32 am
The results are great. Top speed is higher now. High enough for a bicycle I think. Acceleration is improved especially at medium speeds. Its now the kind of ebike you don't really have to pedal much, whereas before I always pedaled.
The cons are that the motor that comes with the XB is not the highest quality. It would have more power with a better motor. Because of the low quality don't be running the motor at full throttle at really low RPM for a long time (like dont pull a buddy on a pedal bicycle up a small mountain. I burnt a hall sensor doing that. This was before the modification. Luckily the hall sensor failed close to the top of the mountain!)
Heres a post about the battery: http://endless-sphere.com/forums/viewtopic.php?f=4&t=16824&start=15#p267023. An alternative and probably higher quality supplier for a similar battery would be this vendor who is closer by in europe: http://www.e-bicycles.eu/en/contact.html
Last edited by The Stig on Sun Apr 21, 2013 2:53 am, edited 1 time in total. View post history.
The Stig
Postby SergeTruth » Sun Aug 15, 2010 10:36 pm
Thank you for your report. How about this: replacing the motor with a better 350W one, replacing the battery with 36V LiFePO4, and replacing the controller. The world definitely needs more e-bikes, and that means that more people have to learn about them, since at the moment it's a project type vehicle.
SergeTruth
100 µW
100 µW
Postby The Stig » Mon Aug 16, 2010 2:07 am
Yeah replacing the motor would be a good idea, but not crucial. I like the cute128 as a replacement motor although I've never tried one before. Lifepo4 would be much cheaper in the long run. 5 times cheaper.the bmsbaterry is slightly lower power than its LiMn.
The Stig
Postby SergeTruth » Mon Aug 16, 2010 7:05 pm
LiFePO4 is amazing technology...at least compared to many of the other batteries. It's safe - less likely to spontaneously combust than LiPo, it has a long life, it does not have "memory", it self-discharges slowly, and it is considered non-toxic. LiFePO4 has energy density four times higher than lead acid batteries - the same amount of Volt*Amp*Hours weighs four times less in LiFePO4 than in Lead Acid batteries.
SergeTruth
100 µW
100 µW
Postby Evoforce » Mon Aug 16, 2010 7:19 pm
I almost bought one! Here is what I did instead. Look at E-Bike Photos and Video topic under "Evoforce bike build 1". Then look up builds 2 and 3. Isn't this fun!
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby SergeTruth » Mon Aug 16, 2010 7:22 pm
How about 36V battery without upgrading the controller? What are the risks?
Evoforce wrote:I almost bought one! Here is what I did instead. Look at E-Bike Photos and Video topic under "Evoforce bike build 1". Then look up builds 2 and 3. Isn't this fun!
viewtopic.php?f=6&t=20345 - Build 3
Haha, looks extreme:)
That silver and red picture is a nice, clean build.
SergeTruth
100 µW
100 µW
Postby SergeTruth » Tue Aug 24, 2010 2:37 pm
The bike has arrived. :) I ordered a 24V LiFePO4 from BMS Battery.
I just tested the bike and it is awesome. It's comparable in speed to regular bikes, which is fine because I like to ride on the side-walk, so it's stealthy this way. Just have to get rid of the e-bike stickers...but people probably don't read them before I zoom by hehe. The quality of the bike is good. One of the reasons for buying it were the disc brakes, and they perform well. This bike is certified win.
More speed might be nice, so a 36V upgrade might be good. Can I run two controllers in parallel, so I can switch between 24V and 36V batteries?
SergeTruth
100 µW
100 µW
Postby The Stig » Fri Sep 17, 2010 9:39 pm
SergeTruth wrote:The bike has arrived. :) I ordered a 24V LiFePO4 from BMS Battery.
Its a good ebike. I don't think there would be any point in keeping the 24V battery and controller on their if you have a 36V system.
If you do get a 36V battery you also have to get a 36V controller. The 24V controller will not work at 36V.
I like the looks of the ampedbikes.com tube battery. I have a feeling it would go nicely on the frame, just in front and above the pedal crank.
The Stig
Next
Who is online
Users browsing this forum: d8veh, maca55, Melbourne, millzy555, phil o' dendron and 7 guests
