DAND214 wrote:I need a set of gears for a 128 Cute, tried BMS no response. I tried Ananda the manufacturer and go no return there either. Good hub just no support if needed.
Dan
The Mighty Volt wrote:Hi d8veh thanks for the photo, you find that this motor runs good and safe at 36v? What amps are you running it at?? I'd say it has packets of torque in the 20" wheel yeah? Thanks.
Haste wrote:so has anybody ran a high speed motor at 48v? Or go the 24v and went to 48v while keeping amps low? It should be as fast as bafang bpm correct? Im looking for a 30-32mph solution...
full-throttle wrote:d8veh or anyone else,
What is no load current @ whatever voltage you are using?
I tried mine last night and~3A @ 48V seem a bit high.. Just wanted to make sure I have not disturbed the Hall timing too much.
Users browsing this forum: Google [Bot], RLD70, sabongi and 6 guests
