CUTE geared hub motors from bmsbattery/ecitypower
Re: CUTE geared hub motors from bmsbattery/ecitypower
Postby d8veh » Tue Mar 27, 2012 4:48 am
12 FET controller sounds like overkill for that Cute motor. How will you limit the current? I'm using a 6 FET which will go up to about 18 amps safely. A 9 FET controller would be lighter than a 12 FET.
All my present bikes that I built can be seen here: http://www.pedelecs.co.uk/forum/members/d8veh.html
d8veh
Postby Haste » Tue Apr 17, 2012 6:12 pm
so has anybody ran a high speed motor at 48v? Or go the 24v and went to 48v while keeping amps low? It should be as fast as bafang bpm correct? Im looking for a 30-32mph solution...
1997 Marin Hill Hawk. Bafang BPM 2 10T. KU123 30 amp controller. 12s LiPo.=32mph
Haste
Postby full-throttle » Tue Apr 17, 2012 7:02 pm
I'm about to try a 24V 108 rear on 48V, 10~15A, 26"
Will let you know
full-throttle
Postby Hyena » Tue Apr 17, 2012 8:00 pm
I used to hold you in such esteem full throttle, with your cool custom stealth bomber and high powered mods. But look at you now, playing with these tiny little kids motors
You've changed man, you've changed...
:lol: :P
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby full-throttle » Tue Apr 17, 2012 8:16 pm
should change my username to full-circle than, huh?? :lol:
nah, it's just for an ultra stealthy project ;)
full-throttle
Postby motomech » Tue Apr 17, 2012 9:20 pm
Haste wrote:so has anybody ran a high speed motor at 48v? Or go the 24v and went to 48v while keeping amps low? It should be as fast as bafang bpm correct? Im looking for a 30-32mph solution...
The fastest wound Cute would be the 24V/250W "328" Q100 which I believe has a no-load speed of 328 rpm @ 36V. This is the same as some fast wind 24V Bafangs and the mini GM. Russell has reached 29 mph on a fast road bike[700cc whl.s] w/ a 24V GM @ 12S. To reach 30 mph on a 26" MTB, you would probably have to have at least 14S.
Of course, it wouldn't be able to get out of it's own way on any kind of hill and it's questionable how long it would last.
You could try "oil-cooling" it, like some here are trying out on larger motors, but the best way to reach 30 mph with a mini is to run two of them @ 12S.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby Haste » Wed Apr 25, 2012 1:24 pm
So I'd still be better off with a Bpm :)
Haste
Postby d8veh » Wed Apr 25, 2012 1:50 pm
The Cute 24v 250-350w 201 rpm motor at 48v will just about run at 30mph down a slight hill, but it won't give enough to sustain that speed up a slight incline. Instead it'll get hot. You need a sustained 750-1000w to maintain that speed, which clearly can't be done from that motor otherwise it would have 750w stamped on it. 30mph is even pushing it for a BPM if you could find the right one (code 8). My advice would be to set your sights lower to about 23 mph or start looking at big heavy direct drive motors and expensive batteries that can sustain 30amps for whatever range you need. If only life was so simple, but it's not!
d8veh
Postby full-throttle » Wed May 16, 2012 8:37 pm
d8veh or anyone else,
What is no load current @ whatever voltage you are using?
I tried mine last night and~3A @ 48V seem a bit high.. Just wanted to make sure I have not disturbed the Hall timing too much.
full-throttle
Postby veloman » Wed May 16, 2012 11:47 pm
full-throttle wrote:d8veh or anyone else,
That's what mine ran at no load (no wheel either, just the hub.) That was at 36v lifepo4 on the 328rpm version (29mph no load speed for a 700c wheel). The drag on these seems considerably higher than a mxus geared hub or a Mac.
They're light though!
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 74v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby DAND214 » Thu May 17, 2012 12:00 am
Just give up on those CUTE things. They aren't what they were a year ago.
My 128 36v 20" was a real nice thing till I went offroad. Killed the gears and the gears not to be had!
BUY a MAC and save a lot of trouble.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby full-throttle » Thu May 17, 2012 12:10 am
Thanks
I might play with adjusting the timing on the halls
Took some photos while changing the wiring
full-throttle
Postby veloman » Thu May 17, 2012 7:38 am
Yeah, come to think of it, my hall wiring may not of been perfect, I really don't know. I haven't actually ridden that motor yet. It ran very quiet though.
veloman
Postby d8veh » Thu May 17, 2012 10:50 am
My no-load current is less than 1 amp with 12s lipos. It's also very free-running when riding; however, when I turn the bike upside-down, it doesn't free-wheel for very long with fairly light 20" wheels and thin tyres.
d8veh
Postby veloman » Fri May 18, 2012 5:10 pm
I just rode a folding bike with what looks like this same motor, on 24v "200watts". I'm not sure what the amp limit is set, but the little 16" wheel almost stalled on me going up a 4-5% grade (no pedal). I know this is partly due to running such a low power, but my 6 turn Mac on 500watt peak in a 26" wheel still had way more torque.
veloman
Postby d8veh » Sat May 19, 2012 1:00 am
I guess you've got the 393 rpm version. Mine's the 201 rpm one and it'll easily pull me (100kg) up a 10% hill with minimal pedalling at 18 amps.
d8veh
Postby veloman » Sat May 19, 2012 11:48 am
To me, 5mph is near stalled. The thing felt like a childs toy. its ebikes like this that create this idea that ebikes are not real transportation. I would guess it being 24v 10amp limited, topped out at 15mph at best. More like 13mph on a flat.
veloman
Postby full-throttle » Sun Jan 20, 2013 6:04 am
Problem solved.
Turned out one of the stands on the winding broke off. So 5 out of 6 were connected on one of the phases. Now the no load current draw is 0.6A. Much better.
Thanks d8veh!
full-throttle
PreviousNext
Who is online
Users browsing this forum: migueralliart and 12 guests
