xyster
I removed the old, broken rack this morning and went for an unpowered ride. I noticed while riding about 10mph that my voltmeter, though I thought disconnected from the batteries, read 10 Volts.
Then I realized this was the hubmotor's regen I slowed to zero, and sure enough the voltmeter needle moved to zero too.
I don't understand though why my ammeter, also wired to a shunt between the controller and batteries, only read zero while I was pedaling or not.
(I'd like to think my pedaling was generating at least 10 amps at 10 volts!)
And I also don't understand why the controller's freewheel diodes didn't block the regen current the voltmeter sensed.
The controller is always turned on as I use a switch on the battery pack (now removed) to switch system power.
My poor, back rack -n- battery pack emasculated bike (I still have 6s15p lithiums on the midframe, but the ~24 volts is below the controller's cut-off):
