LI-ghtcycle
Hello! Well, I am FINALLY building something for MY E-Bike kit!
Previously I was building things for my father's kit or working on making a 24v pocket bike motor for my GT, but that became too difficult to justify, and I decided to start concentrating on my geared motor kit that is almost here.
I am using kfong's interface boards to use Dewalt 28volt batteries while still in their case, but I wanted to have a "lego" attachment on the bottom of each battery, in other words, a battery mount that will mimic the tools that these batteries were designed to plug into attached to the bottom of each battery so I can chain them together.
I decided to use black ABS (1/4" for the main parts of the mount) instead of lexan, and using a variation of Kin's design, I will have a 1/16th inch piece of ABS glued to the bottom of the entire circuit board (with holes drilled to allow space for the electrodes of the resisters and such) which will also be glued to the main mount, solidly attaching the circuit board to the mount.
Here is the link to where Kin shows his battery mounting tray:
http://endless-sphere.com/forums/viewtopic.php?f=14&t=10986&start=45
I am using 28 volt batteries, so the dimensions are 5 x 3.5" for the "blank" that I started with, then I made a master patterns to duplicate for the rest. I don't have much automated tools, so forgive the crude hand-cut mounts.
Note in the third picture (above) that there is a channel cut into the bottom of the mount, this is for a rib that is on the battery's "deck" just below where the interface board attaches on the battery. On a 36 volt, there are 2 of these ribs.
I've used standard ABS pipe glue from the hardware store to bond the pieces or ABS, but I will be using super glue to bond the 1/16th inch thick piece of ABS to the circuit board initially, and if it doesn't hold up, I might go silicone so as to have a bond that isn't impossible to break if I need to take off the board and repair it.
Another great trick with ABS plastic is to get MEK (methyl ethyl ketone) and use it to create a glue with scraps of ABS plastic. Be aware, MEK is EXTREAMLY volatile solvent, so treat it with respect, it can also do a number drying out/burning your skin, gloves strongly recommended.
I have measured from the "deck" of the battery's mounting surface to the top 9/16ths inch so, I will also be putting a piece of 1/16th inch thick ABS as a third layer on top of the two 1/4 inch thick pieces to make it the right hight. Also, if you look on the side of the battery there is a "step" in the grove that attaches to the mount. This step is also 1/16th inch thick where I will be placing a small strip of ABS on the mount to make this a very snug mount.
Once I have the masters done of each part of the mounts (and the 1/16th inch sheet :wink: ) I will glue it altogether and sand down the edges so they match and round out the corners. I'm not sure exactly how I want to mount these to the bottom of the batteries yet, I am hoping that the Dewalt battery cases are also ABS, so that I can just glue these to the bottom with the same glue, if not I can just use gorilla glue to put them on.
The hope is that I will be able to use the battery cases themselves as a "stressed member" in lieu of a full battery box. If all works as planned, this will also allow me to create custom configurations of the batteries to fit inside the frame triangle with minimal mounting hardware, and if I want to add some more packs, I can just plug a few more on.
*** NOTE *** I also wanted to mention I have the male connectors soldiered on the opposite side as normal to make more clearance between the interface board and the mount below.
