lepton
1 W
I've been working with a Crystalyte Phoenix e-bike setup for the past few weeks, but I'm having trouble with my motor.
A few weeks ago the motor (rear mounted) hopped out of the mounts and ended up damaging the power leads, causing them to short out against the metal inside body of the motor. I had to replace my controller, so I now have a new, presumably working unit.
When I turn the controller on the motor has quite a lot more resistance than when its getting no power. When unpowered I can easily turn the motor. When the power is on and I manually turn the motor, it also clicks along. Also, the resistance isn't constant - it feels like as I turn the motor the magnets inside are attracted to each other and the closer they get the harder it is to turn.
When I turn the throttle the motor will turn, but it makes the same clicking sound that it makes when I manually turn it under power.
I've check the hall effect sensor leads following the instructions from the Crystalyte UK website, and it seems to be working fine. I've also checked my battery voltage, and that's not a problem.
Any help here would be appreciated. Is it possible that the motor was damaged from the short out? Thanks!
