Friction rim drive
Friction rim drive
Postby wheelbender6 » Sun Feb 28, 2010 6:55 pm
Anybody tried one? I thought about it when I saw an old rim driven (resistance) bicycle trainer.
I was considering using one of the elastomer wheels from an oxygen scooter to drive the rim.
It may be possible to use a cantilever brake to engage the friction drive on the rim.
I'll sketch something up in AutoCad and create a materials list.
"Rico! Remember that little talk we had about true but unhelpful statements?" - Penguins of Madagascar
wheelbender6
Re: Friction rim drive
Postby hydro-one » Sun Feb 28, 2010 7:35 pm
great idea, i always thought friction would be great. nice to see some more friction projects lately!! i always thought you could use the throttleizer to control power output for not slipping even when wet, kind of friction roller traction control. Are you going to drive both sides? or one side could just apply pressure, but both side drive would be pro....I know there is a french rim drive picture in some threads here.
mike
hydro-one
Postby EVTodd » Sun Feb 28, 2010 8:09 pm
I know it´s possible to do a friction rim drive (like the French system someone posted) but I don´t really see any advantages over a tire drive. You have such a smaller contact area on the rim and I would rather replace a tire from time to time instead of a rim. Not to mention how easy it is to make a moving, self torque sensing, mount with a tire friction drive.
New Tidalforce friction drive build: viewtopic.php?f=28&t=28029
My Friction Drive Outrunner Setup: viewtopic.php?f=28&t=9652&start=330
EVTodd
Postby wheelbender6 » Sun Feb 28, 2010 8:11 pm
I would apply pressure to both sides of the rim, to keep the rim centered, but only one side would drive the rim.
I would probably need to roughen the suface of the rim for wet weather traction. Still many things to decide like
motor choice, motor orientation/mounting. etc.
wheelbender6
Postby paultrafalgar » Mon Mar 01, 2010 11:36 am
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby rkosiorek » Mon Mar 01, 2010 11:59 am
back in the late 80's there was a very similar Israeli kit called the "BIKIT" it had a pair of motors with rubber wheels mounted one on each side of the front rim. the mount attached to the front forks and the handlebars. there was a lever that would pivot the motors so that the wheels would contact the rim. the motors looked like the motors and gear box from a battery powered drill. the battery pack was made up from a bunch of "d" size nicads.
i've tried looking on the web but i can't find much info on that system.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby rkosiorek » Mon Mar 01, 2010 2:05 pm
i was wrong. it drove against the sidewalls of the tires.
my excuse is that i am getting old. my memory is begining to suck
this was one of the first ebikes i ever rode. not having a comparison, i remember being being impressed back then. i wonder what it would be like now.
i found a partial copy of the manual. it's in the zip attachment. more details there.
rick
manual.zip
(601 KiB) Downloaded 30 times
DISCLAIMER:
rkosiorek
Postby hydro-one » Mon Mar 01, 2010 2:45 pm
this some neat stuff.. Im seeing two small outrunners, positioned like that poster, but driving the rim on both sides. One motor for cruise, two for acceleration. . The rim itself is steel, no wear. Caliper mounts plus reinforcments to hold the motor mount. hand engagement via cables , tilting of motors and drive wheels. freewheeling inherent.
hydro-one
Postby veloman » Mon Mar 01, 2010 5:47 pm
You guys read my mind. I had thought of this idea a few months ago and just started to piece my parts together.
Hubs for sale: viewtopic.php?f=9&t=63121
Mush! Mush you electrons! Push harder!
Moped build: viewtopic.php?f=12&t=60209
Small motorcycle build: viewtopic.php?f=10&t=51259&hilit=+ke100
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3525, 77v lifepo4, 12fet Infineon set to 26amps.
veloman
1 GW
1 GW
Who is online
Users browsing this forum: aCeMadMod, darth_elevator, dusan, thewall241 and 13 guests
