"1606" - Larger diameter 9c motor now available
Postby El_Steak » Thu Apr 22, 2010 7:29 pm
Looks like ebikes.ca is now selling a larger diameter 9c motor.
Its huge (273mm) but the magnets are smaller (just 16mm)
Performance is a better than the regular 9c, but at 9.95 rpm/V, the only available winding is bit fast for high voltage applications in 26" wheels. Should be good for 30mph @48V though.
I'll let you judge the aesthetics of the cover... :?
All the info at http://www.ebikes.ca
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Re: "1606" - Larger diameter 9c motor now available
Postby Russell » Thu Apr 22, 2010 9:16 pm
On the ebikes.ca simulator the predicted performance looks so close to the 2806 (10x6) that it seems pointless to even stock the new motor especially with the single cog limitation on the rear version.
-R
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby ecowheelz » Thu Apr 22, 2010 11:35 pm
Looks kind of magic-pie-ish...
Jeremy P
eCo Wheelz - Electric Bikes & Scooters
Clean, Green, No Gasoline!
ecowheelz
Postby liveforphysics » Fri Apr 23, 2010 12:45 am
This larger diameter rotor is a very good thing guys.
Efficiency is related to the rate at which the magents can move past the stator poles. This is why a geared hubmotor can develop good torque at low wheel speeds, because the rotor gets to move ~3x faster than the rim, letting efficiency come on sooner because it gets magnet speed sooner.
These larger stators are a blessing for hubmotor users. Similar to getting the advantages of a geared motor, with the reliability and cooling of a direct drive hub.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Zoot Katz » Fri Apr 23, 2010 1:12 am
Justin had one on the dynamo meter when I visited Wednesday.
Its performance looked good but it will take awhile having them in the hands of the ES tweakers before any one knows for sure.
He was concerned the narrow width between the flanges doesn't allow much bracing angle for the spokes.
There's a lack of freewheel space that limits its application to single speed bikes.
Zoot Katz
Postby amberwolf » Fri Apr 23, 2010 6:34 am
It's much better than the Magic Pie. It's da bomb:
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby dogman » Fri Apr 23, 2010 7:02 am
Big Rotor Good. But making the magnets narrower, uh, sorta waters it down. I see where they are headed with it though, like the pie. Better hill performance, better starts, but not making the motor a big heavy watt hog like a clyte 5304.
I can see how with the right winding, you'd get a faster motor without the compromise in slower speed or uphill performance you get with for example, my aotema. That motor is fast, but look how slow off the line it was in the race. Equally slow out of the corners too. We are all familar with hub motors slow building of the last 5 mph of speed. Perhaps with the extra leverage, that last 5 mph might get there sooner. It seems that way when I compare my 2807 with my aotema.
I don't know if the narrower flange will matter all that much in a front hub. It doesn't leave much room to dish a rear for sure.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby icecube57 » Fri Apr 23, 2010 7:22 am
I was kinda puzzled at that too. About them making the motor narrow. I was trying to decide between a 9x7 and now this guy came out. I can understand going up in diameter but i think i would have took the hit on the weight with the wider motor. It probably would have been a beast.
icecube57
1 GW
1 GW
Postby Mark_A_W » Fri Apr 23, 2010 9:27 am
If it doesn't fit 7 speeds and a disc, it's useless.
You can fit 7 speeds and a disc on an X5, so why can't 9C do it?
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Mark_A_W
Postby John in CR » Fri Apr 23, 2010 12:00 pm
The 7.5kg is the only issue I have with it. Imagine all the space inside those covers for blades in a ventilated arrangement.
John in CR
Postby Ypedal » Fri Apr 23, 2010 12:09 pm
meh.. single speed is all you need ( smallest gear you can screw on ) :twisted: .. i really don't get the need for 7 speed. Even a 3 speed wide range would be more than enough for me.
I wonder how hard it would be to hack this thing with more magnet...
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Drunkskunk » Fri Apr 23, 2010 12:15 pm
that fast of a motor, there isn't much I would want to do with it. But a slower version might be interesting at 100 volts. That much surface area should cool its self fairly well.
Drunkskunk
Postby mrzed » Fri Apr 23, 2010 12:28 pm
I've often thought a front derailleur only setup would make ebike sense. One gear for takeoff, one for cruising. A chain tensioner somewhere in the back hacked from an old rear derailleur.
This since upgrading my 9c from 36v NiCad to 48v LiFePO4. Messing with gears means so much less now.
If I had a long commute though, I'd be looking to keep the gears in case of running out of juice or failure.
mrzed
Postby John in CR » Fri Apr 23, 2010 12:48 pm
mrzed wrote:I've often thought a front derailleur only setup would make ebike sense. One gear for takeoff, one for cruising. A chain tensioner somewhere in the back hacked from an old rear derailleur.
That's what I had on one of my ebikes, and just used the derailleur hanger (or whatever the thing is called that makes the S in the chain) as my chain tensioner with the derailleur locked in the correct position. One speed is all I ever used, though I had 3 up front and functional.
John in CR
Postby John in CR » Fri Apr 23, 2010 12:50 pm
Ypedal wrote:I wonder how hard it would be to hack this thing with more magnet...
More magnet would require more iron in the backing ring, which is already much of the weight of a large dia motor.
John in CR
Postby dogman » Fri Apr 23, 2010 12:59 pm
The pic does show screw on disk compatibility. But why is it so hard to make it bolt on disk? Sometimes I do actually use two of my gears on the rear derailur. I'll use the second smallest when using the ol trusty 36v ping. But yeah, break down and you may want the big gear on the cluster! And you may want all the gears if you are touring, doing a lot of riding at low speed to extend range. Commuting is just WOT all the way there.
dogman
Postby mwkeefer » Fri Apr 23, 2010 1:47 pm
Bolt on adapters of the 42mm 6bolt standard would and do in many cases interfere with bearings embedded into the covers, that's why the chinese manufacturers don't like to do BOLT ON and prefer that thread on mess!
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby El_Steak » Fri Apr 23, 2010 2:27 pm
I use this screw on adapter. It's cheap, decent quality and allows you to use any standard disk. It even comes with a 6 inch disk should you need it. All for just 25$
http://www.bicycledesigner.com/defaulth ... r%3D505202
ebikes.ca also sells an adapter, but its more expensive (35$) and doesn't include a disk:
El_Steak
Postby icecube57 » Mon May 03, 2010 6:48 pm
Mark_A_W wrote:If it doesn't fit 7 speeds and a disc, it's useless.
From what I read on the net the virgin stock hub was centered it allowed for disk an 1 speed freewheel.
I just purchased this front and its being shipped 2 day FedEx. I hope to have it Thursday or Friday. Ill post a full review.
icecube57
1 GW
1 GW
Postby doc007 » Mon May 03, 2010 11:05 pm
icecube57 wrote: I just purchased this front and its being shipped 2 day FedEx. I hope to have it Thursday or Friday. Ill post a full review.
nice :!: if you make a thread in the reviews and testing area please post a link here
doc007
Postby icecube57 » Thu May 06, 2010 7:47 pm
Apparently my item shipped. The weight. 24.3lbs?!?!?!? Im supposed to be getting motor only? wonder what else is in the box....
icecube57
1 GW
1 GW
Postby chroot » Fri May 07, 2010 5:09 pm
take pictures for us, We are eager to see how it goes when you installing your new 1606 9c motor hub and ride.
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby wasp » Fri May 07, 2010 6:15 pm
icecube57 wrote:Apparently my item shipped. The weight. 24.3lbs?!?!?!? Im supposed to be getting motor only? wonder what else is in the box....
24.3 lb must be packed in lead...
wasp
Postby johnrobholmes » Fri May 07, 2010 6:25 pm
My beef with such large diameters- lacing up a wheel with 1 cross spokes is a nightmare. Just isn't going to build up a long term reliable and serviceable wheel.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby icecube57 » Fri May 07, 2010 9:32 pm
What causes a motor to draw more current. I just got my motor in and its factory sticker say 36v 600w 10x6. My GM pulled about 1800-1900w under load. This new 1606 is pulling about 2400w-2600w under load. Its actually causing my controller to heat up vs the GM I could run several 15-20 miles and it get luke warm.
icecube57
1 GW
1 GW
Next
Who is online
Users browsing this forum: cal3thousand, Exabot [Bot], Google [Bot], Heritrix [Crawler], kentlim26, runonpre and 10 guests
