Full suspension longtail bicycle (Folding)
Re: Full suspension longtail bicycle
Postby amberwolf » Sat May 22, 2010 9:30 pm
So you mean, run the bottom chain *over* the joint instead of under it, riding on the ENO as an idler?
Assuming the ENO spins the right way or you take out the pawls, it should work, but:
--It won't allow the sideways movement across the cassette that the other idler does.
--I think it'll change the derailer tension differently (less?) than if it were spanning the bottom naturally, as the shock pivots.
--Won't you need another idler roller under the chainstay forward of it, to keep it off the frame as it goes down to the front chainrings, especially the smaller ones?
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby grindz145 » Sat May 22, 2010 9:40 pm
I just got a Monty trials bike. If you REALLY need to know I can take it apart and figure it out :mrgreen:
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby spinningmagnets » Sun May 23, 2010 9:15 am
The idea is to tave two separate chains instead of one long chain. When the bike is rolling the chains will be near in-line, and when folded, they will be shaped like an upside down V, with the two-cog Dos as the joint. The derailleur on the rear provides some slack, so the rear chain could be a normal one.
The front chain would not neccessarily need a sprung idler wheel, so if using a half-link style chain, a chain could be made in the proper length to run from a large single chainring onto the Dos while being just the right length to fit the ENO joint into the drop-outs. Just a thought...
The trials crank is about $25 and the ENO Dos is $110 so I'm not going to rush into it. Certainly a small idler wheel on the bottom of my chain will work for now.
Last edited by spinningmagnets on Mon May 24, 2010 4:52 pm, edited 1 time in total.
spinningmagnets
Postby amberwolf » Mon May 24, 2010 5:09 am
OH! I totally did not grasp that possibility when looking at it before. :shock: :oops:
amberwolf
Postby gogo » Mon May 24, 2010 7:35 am
spinningmagnets wrote:I have an idea I could use some input on, to see if I'm missing something. I like how the bike folds up when I pull a pin from the rear shock. I'm likely to use a locking ball-pin on the rear-most shock joint.
When the bike folds, the bottom half of the chain droops a lot. Several ways to deal with this, but...I'm thinking I'd mount an ENO "Dos" to the suspension pivot. Run one chain (a half-link style) from a big single front chainring to the ENO joint, and then a second conventional chain runs to the rear gear-cluster and derailleur.
http://sickbikeparts.com/catalog/product_info.php?cPath=21&products_id=35
I don't think the dos allows two chains at the same time. Also, the lever action on the shock absorber link seems a potential problem. Can it compress far enough to "pop" into a reverse position? It looks like you really need a shock that will go all the way to your plate.
I've followed this thread since you started it and only this time caught doc's SM reference. :oops:
gogo
Postby docnjoj » Mon May 24, 2010 1:42 pm
Not my fault, Gogo! John started it!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby docnjoj » Mon May 24, 2010 1:46 pm
There are true dual frewheels that allow 2 chains at a time but the Eno is not one. I think Cyclone uses something like you (SM) want. As you said there are BMX types with different gears and reverse freewheels on opposite sides of the wheel. The folder is really brilliant!
otherDoc
docnjoj
Postby docnjoj » Mon May 24, 2010 1:50 pm
Oh yeah! the Mongoose CX240 uses a 2 sided reverse freewheel so they may sell the part (hub) or wheel at reasonable cost. I made a double sided one from an old SA 3 speed hub for my grandkids CX240 and it worked fine. Close machine fit and JB weld held the freewheel on the left side. I may be able to find the prototype if any interest.
otherDoc
docnjoj
Postby vanilla ice » Mon May 24, 2010 1:52 pm
I want a FS stokemonkey..
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby John in CR » Mon May 24, 2010 3:04 pm
SpinningMags,
Thanks for throwing that picture up of how it will fold. I hadn't thought about making sure I have clearance to make sure the rear will pivot all the way under and to the front, and I definitely want to copy that folding. With the front wheel off and that folding, my 2 wheel land rocket will be quite compact (for a big bike) for tossing in the car.
John in CR
Postby spinningmagnets » Mon May 24, 2010 5:11 pm
I now believe that the ENO "Dos" will allow a chain on one sprocket or the other, but not two chains at one time. Thanks for the warning, Gogo/docnjoj. You both just saved me about $135 (plus shipping) for a failed experiment. I may have gotten $50 for the used ENO-Dos, but the cut trials crank to make the mounting adapter would have been trash.
John-in-CR, I wasn't even thinking about folding it in the beginning, though I've always very much liked how my front disc wheel with quick-disconnect skewers pops off easily without tools (V-brakes choke fat tires when removing them). Dogmans posts about a bike being useful to fit on a bus rack got me thinking about it, and the first time I folded it up I got a big smile. I now feel this is an important feature.
If someone was interested in this, but found this particular lay-out a little too long/large/heavy...you can start with a 24" aluminum-frame mountain bike on the front and add a 20" suspension arm. If you are on a budget, it is quite easy to find trash-day BMX frames (some are even aluminum) and the back half of a BMX could easily be cut to become a smaller/lighter FSLB rear-suspension arm.
A 24"/20" FSLB would be longer and lower than a stock 26" hardtail, but shorter/lighter than this 26"/26" FSLB. If you can braze or know a welder, a shock mount could be made that looks more professional, my criteria for this shock mount was that...it had to be removable to restore the bike to original form if the experimant failed, and...it had to be adjustable once installed to compensate for unexpected issues concerning shocks and bike-handling. (DAMN, air-shocks are expensive!!)
Last edited by spinningmagnets on Wed Jun 02, 2010 12:03 pm, edited 1 time in total.
spinningmagnets
Postby amberwolf » Mon May 24, 2010 10:48 pm
spinningmagnets wrote:I now believe that the ENO "Dos" will allow a chain on one sprocket or the other, but not two chains at one time.
I have an idea. Not thought out but just an "inspirational flash". :) So it might be worthless. But... take the other ENO that SBP has, with the 5-hole ring. Attach your desired jackshaft sprockets to adapter rings that will bolt to that ring, with the adapter rings on opposite sides of that ring, facing each other. Now there is clearance for even wide chains if you need it. Possibly the space you have available is too small to put all this in there, though.
Yes, they are. The AirRide industrial types (firestone/bridgestone 4001) that were used for the Autospeed trikes ran around $150 each last time I tried to price them. That's one reason I never built the first trike I started designing, because it requires those to work, being based heavily on the Autospeed trikes.
If you have space for it, though, you can make your own airshocks of a sort. ;)
Take a small diameter but wide tire, like some of the ones for dollys. Turn it inside out. Build a pair of (aluminum) clamping plates for each end, machined to be secured around the bead of the tire for an air seal. Use adhesives or sealants wherever necessary. Drill mounting holes in the end plates or bolt mounting hardware to them as needed. Drill a hole in an accessible spot on one end plate for an air valve. Install, and inflate to desired pressure.
I have four old gokart tires I found in a small pile of trash in a Walmart parking lot, which I would like to someday test this theory with. I also have two small powerchair tires about the same 10" diameter but only 3" wide that would probably work as well for lesser displacement, after I pull them off the "airless" tubes inside them.
amberwolf
Re: Full suspension longtail bicycle (Folding)
Postby John in CR » Tue May 25, 2010 8:11 am
Yeah stuff for bikes like $150 shocks and $80 freewheels pisses me off to no end.
John in CR
Postby vanilla ice » Tue May 25, 2010 11:09 am
That pivoting idea is great. Less storage space than a standard bike! I'm trying to imagine a swing arm design that would allow me to pivot on a hub motor axle.. or maybe modify an xmart swinger and your dropouts do it.
vanilla ice
1.21 GW
1.21 GW
Postby John in CR » Tue May 25, 2010 11:20 am
vanilla ice wrote:That pivoting idea is great. Less storage space than a standard bike! I'm trying to imagine a swing arm design that would allow me to pivot on a hub motor axle.. or maybe modify an xmart swinger and your dropouts do it.
I'm in the process of that. My swingarm will have dropouts on both ends. At the pivoting motor end, they'll be clamping dropouts 1/2" thick steel on each side. The attachment to the frame that holds the outer race of the bearings will have to bolt to the frame, since the axle pivoting point is fixed instead of sliding out like motorcycle pivots. The axles on mine are 20mm thick. I'm not sure the skinny axles of typical hub motors are up to the task if you go with mono-shock, because the forces on the pivot are quite leveraged.
John in CR
Postby spinningmagnets » Tue May 25, 2010 5:20 pm
Amberwolf, this one (the 22T-ENO) ?
I think that would work, I could easily attach a second sprocket (in a more desirable tooth-count too) to stand off enough to allow two chains at the same time. Cheaper than the "Dos" also. Great idea, might do that later...I noticed having a small chainring allows me to have good curb-jumping clearance, while the jackshaft gear-up would still allow me to pedal at higher motor-speeds (Instead of adapting a 52T chainring)
Rodney Dangerfield: "I tell ya, I get no respect!...I was talkin to my wife on the phone, and she happened to mention she wanted to try some S&M today...I started to get a little excited, so I left work early. But when I got home and opened the bedroom door, I found out she meant Salesmen & Mechanics" (cue rimshot)
spinningmagnets
Postby TylerDurden » Tue May 25, 2010 5:41 pm
Depending on your installation, you might be able to fit a small auto airshock. Airshocks for Super-Beetles are still available for about $80/pair. :lol:
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby amberwolf » Tue May 25, 2010 5:51 pm
Actually this one:
http://sickbikeparts.com/catalog/produc ... ucts_id=62
I guess it's by White made only for SBP.
They also have this one:
http://www.sickbikeparts.com/Products/Freewheel.html
http://sickbikeparts.com/catalog/produc ... ucts_id=34
But the one you're looking at would work too.
amberwolf
Postby Grinhill » Tue May 25, 2010 8:09 pm
Hi Spinning, some great ideas happening on this build.
I have a feeling you will have many more challenges ahead once you start looking at the drive side of things as well :D .
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
Postby spinningmagnets » Mon May 31, 2010 3:56 pm
I made a "fast and ugly" idler wheel on the chains bottom-run from a bolt with two wide washers as side-plates, and several plastic washers as the roller. I will likely buy a more professional-looking idler sometime later.
I wanted the bike to roll easily when folded up, and the rear tire was rubbing up against the BB. Also, when loading/unloading from my truck or bringing it indoors, the rear flopped around. So, I made a fold-up pin-latch out of organic composite fiber (wood).
I dug through my pile of bike parts, and the kick-stand I liked most was tubular aluminum from a 24" bike (too short). So I cut it in half, bought a $5 tap to cut ID threads and added a section of all-thread-rod and two locknuts.
All the mechanics at Big Poppi bikes were very helpful and encouraging. They sold me derailleur cable housing at $1/foot (any length) and threw in some aluminum housing-tips for free so I could experiment. They would have crimped two cables together for free, but I ordered a 10-ft continuous cable from a recumbent site (coiled up in picture at the derailleur). So now I have 6 gears on the rear, and I didn't really need the front derailleur for the BB as its pretty flat terrain here.
I really like having my feet flat on the ground at stops. There's a lot of potholes and rough sidewalk in Junction City so the fat tires and full-suspension are well worth the effort for me. The red seat tube is from a trash-day steel BMX, and soon both the seat tube and shock mount will be completely changed into something that looks more professional. I'm envisioning a four-legged spider for both seat/shock that frees up the space under the seat between the stays, with the shock being horizontal.
The left/right edges of the flat aluminum shock mounting plate occasionally brush against my ankles when pedaling, so if I was in a hurry to do this again, I would use an aluminum squared C-channel section attached between the seat stays, with the four U-clamps coming in from the sides. The most pressing need right now is a cup-holder and music.
Ft Riley, Kansas was home to George "I aint afraid of no Indians" Custer, and Patton. The stone pillar in the pic is one of the many 130-year old hitching posts here. Originally for horses, they are now used for decoration.
Last edited by spinningmagnets on Tue Jun 01, 2010 10:27 am, edited 3 times in total.
spinningmagnets
Postby ngocthach1130 » Mon May 31, 2010 4:07 pm
Wouldn't the bike be very squirelly at high speed with the short wheel base and the front fork standing straight up like that?
Worse part of waking up...is having to stay up!
Thach(Tut)
ngocthach1130
Postby spinningmagnets » Mon May 31, 2010 4:24 pm
At higher speeds, a longer bike may be a little more stable. My main interest was a more comfortable seating position that is lower and farther back (semi-recumbent?). I would only ride it when its stretched out.
Also, Dogman mentioned that it would be useful for a bike to be short enough to fit on the bike rack located at the front bumper of his city busses. The folding position is useful for the bus, and also when transporting this bike in the trunk of a car, or when moving the bike in/out of storage.
The front disc brake and "skewer" style front axle means that the front tire pops off-and-on easily without any tools.
spinningmagnets
Postby docnjoj » Tue Jun 01, 2010 6:45 am
That is really classy work, S/M! Oh yeah, I just noticed the drill bit "shaft" for the shock!
otherDoc
docnjoj
Postby spinningmagnets » Tue Jun 01, 2010 10:23 am
"...I just noticed the drill bit "shaft" for the shock..." Ha!...yeah, back brakes aren't hooked up, wood for spacers, derailleur cable held in place with tape...pretty much "salvage yard" engineering right now. I was just in a hurry to get it ridable. I am going onto night-shift, so hopefully I will have some time to upgrade the drill-bit pin and wood bracket!
Between the fat tires, old-skool cruiser seat (springs under seat) and the rear suspension, it rides much more comfortably over the pot-holes and rough sidewalks. My other commuter bike looks Dutch-style and has fat tires, but no suspension at all.
spinningmagnets
Postby John in CR » Tue Jun 01, 2010 1:01 pm
Spinning mags-
Unless I missed something solid, the seat tube is going to need serious strengthening. Sure I'm heavy, but with pedals front almost all weight is on the seat. Mine is much shorter and it bent right away with a cromoly seat tube. Then I welded 1/2" solid steel rod inside with a reinforcement fillet in the corner, and it still bent somewhat. I'm surprised the seat tube on the frame never broke off with the leverage I put on it.
Red seat.JPG (30.56 KiB) Viewed 436 times
Yours is so long, even a featherweight is going to put serious stress (thousands of lbs with that kind of leverage) on the lowest parts of that seat tube.
John
John in CR
PreviousNext
Who is online
Users browsing this forum: Melbourne and 10 guests
