Hey everyone I'm getting started on my first electric build, I've built a gas bike before but I'm wanting to put together an electric to ride on the bike paths... you get tired of the loud 2-cycle engine noise after awhile. I've decided to put together my own system using a large 36v scooter motor. I will also be using a controller pulled from an electric scooter. As you can see in my pics below I plan on mounting the motor on the downtube in front of the crank. I plan on putting together a front freewheel so the pedals won't spin when using the motor. I would love to have a dual front freewheel, but after doing some research here and and on google I don't think anyone sells components to easily make a dual front freewheel. From what I've read the only place to get semi-inexpensive parts to build a front freewheel is here: http://www.sickbikeparts.com/catalog/index.php?cPath=21&osCsid=eb2665b9bd0b9a0d057357d5f359fbec is that the only place? Or is there somewhere better/easier/cheaper? OK so on to my questions... First of all I don't understand how to build a front freewheel with the parts listed on that page. Which specific parts do I need? I have never taken apart bicycle gears/cranks/shafts so I'm a complete noob in this department. If I buy the right parts from that page are they all going to bolt together and install without me having to weld or do anything hard? Is it that simple or will it require more work than I'm thinking? My next question is will I be able to find a sprocket that fits on this motor that will fit a regular bicycle chain? The motor shaft is shaped to fit a sprocket with a dual D-bore like this:
So I'm thinking if I can put together the front freewheel crank setup, find a sprocket for the motor that I can use with a bicycle chain, and figure out a good way to mount the motor I'll be set. The motor is just taped on right now so you can get an idea of what I'm thinking. Do you think this setup will work? Am I missing anything? I realize that when I'm pedaling only I will have added drag because I'm turning the motor, I am fine with this. That is unless I had a dual front freewheel, I don't think that is available anywhere though.
Ok so give me some tips Sphere! I think the hardest part for me is goung to be setting up the freewheeling front crank so the pedals don't spin when the motor is running. Any insight here would be MUCH appreciated. Here are the pics:
