sk8norcal wrote:^ hi, docnjoj, where did find that info? or is it just ur guess?it is a tadpole the lean is controlled by springs and shocks.
John in CR wrote:A bit of youtubing shows that both BMW and Mercedes have leaning 3 wheel deltas with non-leaning rears, so I think I'm on the right track.
John in CR wrote:I couldn't find the bit again about the Carver rear turning. It was in a write-up about the development history as part of the son's computer controlled lean steering system.
Excellent point regarding the pivot axis and the front contact patch, so any difference higher or lower will create some rear wheel steer, and if I'm visualizing it correctly we only want the pivot axis at or lower than the contact patch or the rear wheels will turn in the wrong direction...at least that feels like the wrong direction to me unless you're just changing lanes, not turning.
sk8norcal wrote:Excellent point regarding the pivot axis and the front contact patch, so any difference higher or lower will create some rear wheel steer, and if I'm visualizing it correctly we only want the pivot axis at or lower than the contact patch or the rear wheels will turn in the wrong direction...at least that feels like the wrong direction to me unless you're just changing lanes, not turning.
the gyro's pivot appears to be horizontal..
sk8norcal wrote:another thing I have concerns about is all that unsprung weight..
and the need for a differential..
(not sure if the gyro have a diff..)
http://tiltingvehicles.blogspot.com/201 ... ta-12.html
veloman wrote:http://www.schultzengineering.us/chap6.htm
Not sure if this was posted before, but it's very thorough.
purplepeopledesign wrote:If you want one, I'll can build it for you. The trike in the signature video is the original Magic designed by my late mentor Paul Smith in 1992. The frame was welded by Georgiev in trade for help designing one of his early speedbikes. The new trike has a video that is listed in my YouTube faves that was taken by Ray of Blue Velo. It has a low modified Magic pivot, slim rear track and handles the same as Magic on smooth surfaces. It's even better on the road and rough surfaces because it has a longer wheelbase and fatter tires.ensen
John in CR wrote:I'm sorry, but if it really is that good then sharing the tilt mechanism now would honor his legacy. One of the great things to come out of the internet age is the concept of open source. Too bad it still hasn't caught on with people who build mechanical things. If an idea is worthy and you know you won't bring it into mass production yourself, then share it freely with the world. If someone does take it into production hopefully they will have the honor to include a small royalty % for you.
Will you at least say, is it the angle of the pivot that is critical, or is what's so special the slick pivot mechanism itself?
sk8norcal wrote:is this the same trike at 1:28 ?
Users browsing this forum: Bing [Bot], Diamondback, jbalat, mm7827, Sunder, wesnewell and 17 guests
