Commuter E-Bike from Novara Hardtail MTB
Re: Making a Commuter (&Fun) MTB 9C 6x10 75V
Postby adrian_sm » Wed May 04, 2011 9:54 pm
Would be interested to see if it ups the voltage on the main leads based on what it measures on the balance leads. But I wouldn't hold my breath. These are pretty cheap chargers. I did this testing ages ago, so can't remember if I looked at that. Easy to test though.
For me it just convinced me to go for as short, and fat power cables for charging as practical. 10 guage is what I had at hand, and still use.
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby Alan B » Wed May 04, 2011 10:02 pm
That's what I expect it would do. It is a pretty simple microprocessor controlled setup, reading the balance lines and controlling the charger PWM. If they didn't do that it would be a major mistake in their software. Would not cost any more to do it right, and it is worthwhile to get the software right when they're making lots of copies. But that is no guarantee they did!
Alan B
1.21 GW
1.21 GW
Postby Alan B » Thu May 05, 2011 5:36 pm
eBike Keyswitch
Well, I've been working on a printed circuit board for the keyswitch. Pretty much along the lines of the schematic posted here a few articles back.
The basic layout is done. Quad parallel FETs should handle the current. You can always mount fewer FETs. Need to sort out the connector details and get the hole sizes right, and figure out what to put on the rest of the pc board space. I already have the Magura interface on it - need a better place for those parts than they have on my bike now.
So what else would be handy on this board? Maybe a motor temperature interface?
Other suggestions?
Alan B
1.21 GW
1.21 GW
Postby ryan » Thu May 05, 2011 7:22 pm
Alan, do I understand from your photos that you charge 3 packs of 6s in parallel at a time? And that you have 3 sets of 3P6S to charge? And further that you have one charger, so you charge the entire pack manually in series?
I love what you're doing and after my own battery problems I'm considering the move to LiPo, likely modeling your setup. My concern is that I use my bike every day to commute so I'd hate to have to spend so much manual effort charging every day. I love the way (if I understand correctly) you charge 3P at once. So elegant. I might head over the bridge for a visit to cheat off you and get some boards made myself.
(I'm looking at building a 20S4P pack of Turnigy nano 5Ah 10S packs for roughly 75v20Ah)
Marin DH Electric Mountain Climber. Crystalyte 5304. 72v20Ah (Dual 36v20Ah 12S2P LiFePO4 Headways). 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller. (See Build Thread)
ryan
Postby Alan B » Thu May 05, 2011 7:37 pm
Hi Ryan. I can charge all three "groups" at once if I have three 6S chargers and separate power supplies. Which is certainly do-able.
If I were to break the series connection between the "Groups" I could charge them all in parallel. So far I'm not doing that.
I plan to commute with it, so I may get tired of plugging in one charger three times, though it doesn't take a lot of effort. This is just the first step in a journey to the final system.
One other way to charge this pack is with two 36V meanwells in series and a current limiter board. Bulk charging. If I were to alternate between balance charging and bulk charging, doing one at work and one at home, that would keep things balanced pretty well.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Thu May 05, 2011 10:28 pm
Keyswitch Control Board
Here is the layout at the moment, traces are not shown. The left 2/3 of the board is the keyswitch circuit, the upper right corner is the Magura throttle interface. The Magura interface provides variable resistors to adjust the range for the full rotation of the throttle, and it has a connector for remote clamping of the throttle such as used by LVC boards. Shorting the pins will take the throttle to zero.
There is still room for something in the lower right.
Not everything is sized correctly, but most of it is close. Not sure I like those connectors at the top for the keyswitch and throttle, they were library Molex parts. So need to think about what to use there.
The current carrying wires are quad #12 wires which equals a number six. Soldering a number six wire to this board seems unlikely, but a few #12's would be manageable.
The keyswitch needs two contact closures, one for precharge, and a separate one for operate. They must be two separate poles, one operates at pack negative and one at pack positive.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri May 06, 2011 1:45 am
Motor Temperature
So let's assume for a moment that I put a motor temperature sensor on the board. What to do with the data? A display is nice but a lot of trouble. What is really essential here? Perhaps the motor temperature should do something to the throttle. I already have the throttle on this board, so perhaps that's the way to handle it.
What would the algorithm be? Turn the throttle off for a short time every little while when the temperature exceeds one value. The higher it gets, the longer it stays off each cycle. Finally, it stays off altogether when the high limit is reached. Perhaps have jumper to disable all this when needed.
One of the difficult things to do is get 5 volts to power the circuit. Might be able to borrow that from the controller's throttle power. Hmmm.
Alan B
1.21 GW
1.21 GW
Postby adrian_sm » Fri May 06, 2011 1:51 am
Can you have it just pull the throttle signal down, like a CA throttle override.
Temp < T1: Throttle left alone
T1 < Temp < T2: Throttle is progressively limitted to less than full throttle.
T2 < Temp : Throttle Off.
adrian_sm
Postby Alan B » Fri May 06, 2011 8:14 am
adrian_sm wrote:Can you have it just pull the throttle signal down, like a CA throttle override.
That is possible, too. It would not be as clear to the rider, though. But with software not hard to do. It would require slightly more complicated hardware. A few more parts.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sat May 07, 2011 1:58 pm
What temperatures to use for thresholds, hmmm..
Alan B
1.21 GW
1.21 GW
Postby pdf » Tue May 10, 2011 8:43 am
Sorry to jump in to this thread late, but I have been out of the loop a while. I have just started playing around with a 6x10 for my son's 26' MTB so we can ride together. This is my first hub motor. I am looking at batteries and controllers. Forgive my battery ignorance.
I think it is true that I can't simply get two 24v lithium chemistry packs and put them together in series without somehow tying the charging and BMS functions for the two packs together. (Does the BMS effect BOTH charging and discharging?) The battery on my bike is a pouch cell 36v LiPO4, but might do something different on this one. I have heard a lot about the batteries for the RC market and might go that way, if I can figure it out. I like the simplicity of the one plug for charging, if that can be done.
Jamis Commuter 1.0/Xtracycle Stokemonkey 36V LiFePO4, 15 ahr
Giant Boulder 9C 6x10, 18s1p LiPO, 5 ahr, 18FET Lyen edition
pdf
Postby Alan B » Tue May 10, 2011 9:21 am
I started (earlier in this thread) with a pair of 6S 5AH Lipos in series. This can be charged with a 12-14S charger, and there are a couple of those out there. Wire up all the balance leads to a DB25 for a two-plug charging setup. The second plug could be a PowerPole for the charging current. The DB25 cable wires are too small a gauge for the charging current, but are fine for cell balancing.
When you add 6S packs, just parallel the power and balance leads for each of the two 6S banks. Never mix up leads from the two banks or BANG.
I find that 18S works well on the 9C 6x10. That is what I am using now, and since there are no 18S chargers I'm using a 6S charger and plugging in 3 times.
Some BMS's affect both charge and discharge, depends on how they are configured. At the moment my "BMS" is watching the Cycle Analyst amp-hour and voltage for end of charge, and using the RC balance chargers for the management of the charge cycle. I will be adding Low Voltage Cutoff to the bike and this will control the throttle for simplicity.
Alan B
1.21 GW
1.21 GW
Postby mr.electric » Tue May 10, 2011 2:50 pm
I would personally enjoy a buzzer and or light for overheat. Another approach would be a two step throttle clamp. Limited current available at the first threshold followed by no throttle for the second higher threshold.
Cars used to have various cut offs so the engine stopped before it was damaged. Later it was decided that stopping the motor was dangerous and confusing. Modern cars always have a light or buzzer but no cut off.
I remember some of the early Vespa sized e scooters had a series of safety interlocks including one where the scooter would not run with the kick stand down. This system caused more harm than good and resulted in a bunch of unsatisfied customers.
I think blinking light and or buzzer would work well and add little complexity and cost. Whatever you decide to do I would buy one of these circuits when they are available.
-Fat Sand Bike with 9c and 29ah pack
-Giants mascot scooter
mr.electric
Postby Alan B » Tue May 10, 2011 6:41 pm
mr.electric wrote:I would personally enjoy a buzzer and or light for overheat. Another approach would be a two step throttle clamp. Limited current available at the first threshold followed by no throttle for the second higher threshold.
Thanks for the input. I may have room for a buzzer on this board, I'll look into it.
One trick with the throttle I've been thinking about is to "blip" it to send a message, just a quick interruption to let you know that something is wrong. Not enough to stop you, but enough to be unmistakeable. A buzzer might be good too!
Alan B
1.21 GW
1.21 GW
Postby Alan B » Tue May 10, 2011 10:40 pm
eBike riding Gloves
Went glove shopping a couple of times, didn't really like the regular bike gloves. The other day stopped by Cycle Gear and looked at motorcycle gloves. Found a pair I like, Sedici Corsa gloves.
These are not insulated, but have good protection on palms and knuckles. The feel of the grips through them is nice. They have some blue on the back, and some light tan on the palm so if you do give a hand signal they are not "invisible black gloves". Especially the palm. If you ever needed to smack something they would give pretty good protection. They may be too warm for some riding, but commuting tends to avoid the heat of the day so I suspect they will not be too hot. Cold weather would probably require warmer gloves or liners could extend the season for these.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri May 13, 2011 12:38 am
Keyswitch Current Surges
Today I fired up LTSpice, a free electronics modelling program. With some typical values I observed 1200 amp surges when the controller was connected to the battery. :shock: Clearly this is hard on the connector or switch, or the FET in this design. By making adjustments to the network feeding the FET gate I was able to drop this to 18 amps peak. Even in this slow turn-on configuration the FET was fully turned on in well under 100 milliseconds. :idea: Under these conditions the resistive precharge is not required. I modified the PC board design to reflect this. During the precharge (switch position two) the FETs are turned on, but the controller and secondary loads are not; in the operate position both the FETs and the controller as well as the secondary loads are energized.
The remaining question is how much heat is deposited into the FETs during this linear turn-on period. The duration of the current spike is about 0.01 seconds, and at 18 amps the worst case power dissipation would be half the voltage in the FETs, or 18 * 75 / 2 which is about 700 watts. :shock: However the duration of this current is less than 0.01 seconds so the total energy is about 7 watt seconds. In fact due to the shape of this pulse the actual dissipation is closer to half of that value. :)
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri May 13, 2011 10:29 am
Keyswitch Positions
There are three positions on my keyswitch. Position one is off/key removal. The question is how to best use the other two:
Set 1:
2) precharge
3) operate (precharge is automatic)
OR
Set 2:
2) accessory only (motor not powered)
I wonder if the second set is more useful. This would send power to the accessory output, and the controller logic (since this powers the Cycle Analyst), but not the main power to the controller, so the motor could not run. This way you could pedal the bike and see speed, etc, but the throttle would be inactive.
This would be analagous to the keyswitch in most vehicles, less the "start" momentary position.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri May 13, 2011 1:47 pm
It might also make sense to bring the kill switch into this board and turn off power to the motor while leaving power on to the controller and Cycle Analyst.
Alan B
1.21 GW
1.21 GW
Postby johnrobholmes » Fri May 13, 2011 2:01 pm
I really like the keyswitch module idea. I too hate unplugging things over and over, but I know better than to leave things plugged in for a period of time :lol:
I like option two since the precharge is automatic for running anyway. Maybe have headlights and the CA turn on with it.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby Alan B » Fri May 13, 2011 9:10 pm
Well, I was making changes to the design to make it have position #2 Accessory power when I remembered why this won't work. The power FETs are in the negative lead, so connecting the positive to the accessories won't help. I think trying to switch the accessories negative leads is likely to lead to other problems. Most things don't expect switching in the negative lead.
So perhaps the best way to do this is to power the controller main and the accessories from position #2 and the controller logic from position #3. The problem with this is the Cycle Analyst DP is usually powered by the controller logic. So it won't come on in position #2 unless rewired.
In other news the Cycle Analysts are still on delay but may ship in another week or two.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri May 13, 2011 9:26 pm
Keyswitch FET Heat
did some calcs for IRFB4110's at 50 amps DC (assuming equal current division, P = (I/N)^2*R):
1 FET 11.25 watts
2 FETs in parallel 2.8 watts each
3 FETs in parallel 1.25 watts each
4 FETs in parallel 0.70 watts each
So at the 50 amp level 3 FETs with very minimal heatsink would do, four is excellent! (my board layout has four) :D
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sun May 15, 2011 12:31 am
Marin Headlands ES Ride
Survived the ES ride today. Made it up the "steep hill" to the peak. Motor got fairly hot due to the rough deeply rutted gravel and dirt road and grade. Need to have a motor temperature sensor!
Met lots of fun ES folks, some of whom have seen this thread. Thanks!
Thanks again to all who have contributed to this thread, both by making suggestions and asking questions!
This morning I mounted a CellLog onto one of my DB9 charging boards. So it just plugs into a battery bank and reads out the cell voltages. Really handy for reading cells in the field!
One Plug Charging Solution
I also received some of Geoff57's SMD LVC boards on friday. They are small! I think the bike should have LVC onboard. Balancing and full BMS is a bit much for an ebike with so little space. One way to go is to use the SMD LVC onboard, and then use the TPPacks BMS with a bulk charger (or power supplies) to make a single plug (or 2 plug) charging solution. The (somewhat large) TPPacks boards can stay with the charger and not be on the bike!
Typical "ES eBike Look"
Extremegreenmachine told me that my build looks too "ES" like. Instead I should empty the triangle and put the batteries and controller in the trunk pack and hide the wiring so it didn't look like an "ES Bike". I'm trying to keep the trunk free for gear, and keep the "stuffings" near the CG. Hopefully when I cover the triangle it won't attract as much attention as the waterfall of wiring in the triangle does now. :D
I did get a lot of complements on the build and we discussed various ways of handling the wiring and connectors. Some folks had problems with connectors and BMS's. One suggestion I have is to make sure you can bypass your BMS easily if necessary. Today it was necessary and it was not easy so it took time and made it difficult for one rider to get his ebike up the steep hill.
A couple of other comments on connectors. Make sure that your connectors have a good solid physical connection as well as a good solid electrical connection. (Note that Solder is a poor conductor and a marginal physical connection). Make sure connectors are being used well within their ratings. Make sure the plugs cannot easily be plugged together wrong (proper polarization). Make sure they have covers that prevent accidental shorts. That's my advice. Deviate at your own risk. :shock:
The other day a tree fell and took out our power drop. PG&E came out and re-connected it. They did not solder the wires. At work we have hundreds of high powered magnets to control the electron beam we use to make intense light for science experiments. These power supplies and magnets have hundreds of amps flowing continuously, in some cases nearly a thousand amps. They do not use soldered connections. Some of the cables and many of the magnets have hollow conductors with cooling water flowing inside them. They do not use soldered connections. Just a thought.
I used about 5.5 amp hours (of 10) on this ride. Most on the way up. We climbed over 1,000 feet as I recall in about 5 miles. Total trip was about 10 miles for me. At one point I looked and it was running 44 watt hours per mile. That was on pavement. It was worse on the dirt.
The rain held off nicely for today's outing. But it is making up for it now.
Alan B
1.21 GW
1.21 GW
Postby mr.electric » Sun May 15, 2011 6:03 pm
I Like the key switch board idea very much. It reminds me of the component on a modern car called the gateway ecu. On an ebike the controller is more similar to the engine ecu. A gateway ecu controlls all the communication between the bigger ecus that are dedicated to controlling a large complex system like transmission ,engine or hybrid system. The gateway ecu brings everything together and reads the smart key to authorize the driver to start the car.
I made a nice on/off precharge circuit with Fechter's help. One cool feature was the on/ off sequence. Flip a switch to "on " then press and hold a button to enable now the ready light comes on and you can drive. Precharge starts when you flip the switch to on. The contactor/ relay closes when you press the momentary button. Once you flip it to off it will not accidentally turn on by flipping a little handlebar mounted switch since you still need to press the button to enable. The light reminds you that it is on.
mr.electric
Postby Alan B » Sun May 15, 2011 7:03 pm
mr.electric wrote:I Like the key switch board idea very much. It reminds me of the component on a modern car called the gateway ecu. On an ebike the controller is more similar to the engine ecu. A gateway ecu controlls all the communication between the bigger ecus that are dedicated to controlling a large complex system like transmission ,engine or hybrid system. The gateway ecu brings everything together and reads the smart key to authorize the driver to start the car.
Great analogy. Sort of like a pushbutton starter, like the new cars where the proximity is the "enabler" and the pushbutton is the starter.
I thought about the proximity approach as well but it is a bit expensive and complicated. Maybe get to that later!
Alan B
1.21 GW
1.21 GW
Postby mr.electric » Sun May 15, 2011 7:55 pm
As long as the battery in and out and throttle in and out plugs are matched with the stock plugs you could easily bypass the circuit if anything went wrong. The hill climb race provided a telling lesson when Ryan had a BMS failure and spent significant time bypassing the permanently installed BMS circuit. I think the key switch circuit could add safetey and reliability by providing things like temp sensor throttle cut back, precharge circuit , current limiting ,dc-dc for lights and other features and if all else fails an easy way to bypass everything and plug the throttle and battery directly into the controller would be good.
mr.electric
PreviousNext
Who is online
Users browsing this forum: badhorsie, NeilP and 14 guests
