Hi GC,
The 5-speed 14-28t freewheel is 31mm in overall width/thickness, from the back of the threaded freehub to the outside of the lockring. The thickness of the cog stack only (from the back of the largest cog to the front of the smallest cog) is 26mm. The 7-speed 11-32t freewheel is 38mm in overall width, or 32mm if you're measuring just the cogs.
These measurements might be a few tenths of a millimeter off, since my calipers weren't long enough to reach over the large cog. But yes, the 7-speed freewheel is wider.Let me know if you have any other questions,
- Cycle 9
Alan B wrote:Spent some time with Google Maps and their new bicycle routing system. It found a route that I suspected but never had worked out. Shaved 3 miles off my commute! That would make it under 10 miles!!!![]()
Then I tried to get the vertical profile. That did not work.![]()
Then I looked up the rules for these old roads in the park. Human powered bicycles specified. Electric bikes only for the disabled. SHUCKS!.![]()
This route is really excellent. It takes 3 miles off and a lot of that is very narrow twisty 2 lane mixed with cars and makes it a pretty gradual climb. I suspect at
commute time it is pretty empty on these trails as well. But pedalling a 60 pound bike up this in the morning commute would not be practical I suspect.
In the evening going downhill it might be okay to pedal it (mostly coasting anyhow).
Of course if they don't allow an electric bike, does it matter if it is turned off?????
ronnieb52 wrote:I have a rear geared from Ampedbikes and it's doing fine.
Personally I like the small motor as no one notices it ...
Evoforce wrote:...
Could you be considered mentally or physically disabled? After all, you are one of those wackos riding an e-bike.
Alan B wrote:Well, the hub motor/wheel kit is ordered. 9C 26".
Alan B wrote:
If a Headway cell dies do we call it a deadway?
Alan B wrote:Next is to decide on battery setups. Made a foam triangle to test fit 16AH Headways. Not an easy fit.
Users browsing this forum: GiantEV, pradeepswain, sigimem and 17 guests
