999zip999 wrote:I think you well love the headways at lest it is 16 cells not 64 or more. and a high c-rate. What bms ? What a bms ? Would that be a 60amp. ? If one is used ?
BIG BEAM wrote:I use 12 Headways in a sealed wooden box and also use a 9c and draw 25A max .The batteries never even got hot.The black box got hotter than the batteries.I'd say that the hottest they got was 90F and the outside of the box was the same.
But I'm changing to 2 saddle bags from leather up.Going for that elitist professor look.Now all I need is a pipe!
DON
Mark_A_W wrote:At 25-30A continuous, my 20 headway cells sealed in a fibreglass box get very warm to the touch. You can hold your hand on them, but they are really quite warm (IR thermometer is on it's way).
But they are over 2yrs old now (12,000km) - the old paper wrapped 10Ah cells.
I wouldn't really pull more than about 40A peak/24A continuous out of a 10Ah cell - unless they have drastically improved.
999zip999 wrote:I had many problems with 40 amps. on my bmc it would give a hmmmm. in a graling tune. It finnaly got a c.a. turn it down to 25amps. I would ask how many amps a 9c can take a solwer high torque would take more ? If using on hills and that is it use or a tailor not speed. I think if you over amp. it will not only over heat but it has some rambling inside the motor hmmm. Of coarse I just made that of but I do beleive it ? I do hear it. Yes ?
knoxie wrote:8)
Hey looking awesome! very nice indeed! did you get it laser cut? or CNC? or water jet maybe? be interested to know how the battery build is coming on.
billsy wrote:knoxie wrote:8)
No he used an angle grinder with cutting disc to cut them out and then his Dremel to tidy up. Is this correct Kevin?
gwhy! wrote:billsy wrote:knoxie wrote:8)
Yes , 2mm wide cutoff disc on a grinder ( would have been quicker if I had a 1 or 1.5mm cutoff disk )for the big straight cuts then a small cutoff disk on a dremel for the smaller cuts then a milling bit in the dremel to tidy up the small cuts, and to finish off a small sanding drum on the dremel .
billsy wrote:
That does it, I'm getting a Dremel!
Users browsing this forum: Majestic-12 [Bot] and 8 guests
