Speedict Ebike - Anybody seen/tried this?
Re: Speedict Ebike - Anybody seen/tried this?
Postby speedict » Fri Apr 20, 2012 3:28 am
We just uploaded the new Android Client 2.4 with configurable multi-data layout screen and port status view features.
Multi-Data Layout
Port Status
Speedict Technology - Drive . The . Future http://www.speedict.com | http://www.facebook.com/speedict.technology
speedict
Postby clunden » Mon Apr 23, 2012 1:24 am
Hi,
i've just started playing with my logger (firmware 2.2) and wanted to syncronize the logs to the phone to check them on the PC later
(the way the logger is mounted it's difficult for me to get at the USB port)
but, the transferring is taking ages!
there is one log on it now of about 15minutes, and it has been transferring for half an hour now and still isn't finished..
Is it supposed to take this long?
Has anyone else experienced this?
Some kind of % data transferred bar in the display would be nice to se how far along I am in the data transferring.
Otherwise super product!
love the app to!
//Christian
clunden
Postby speedict » Mon Apr 23, 2012 1:58 am
clunden wrote:Hi,
love the app to!
//Christian
Hi Christian,
I think the log somehow damaged, nothing you can do now please connect speedict ebike to pc with pc suite to erase the logs inside, then please simply record few minutes data and see if you still need long time to sync to android device, orherwise you have to send it back for replacement because data flash component may damage.
speedict
Postby clunden » Mon Apr 23, 2012 2:32 am
speedict wrote:
clunden wrote:Hi,
love the app to!
//Christian
Hi Christian,
Just downloaded the logs to the PC with USB no problems.
-but there was one log on it of ~8H, I had forgotten to turn it off.... :oops:
Maybe that's why it was takning so long...
erased the logs on the logger and will try a new run soon.
thanks for the quick reply as always!
//Christian
clunden
Postby speedict » Mon Apr 23, 2012 3:11 am
clunden wrote:
speedict wrote:
clunden wrote:Hi,
love the app to!
//Christian
Hi Christian,
//Christian
speedict
Postby Ebikeman » Mon Apr 23, 2012 6:34 am
Is it possible to use gps with maps that I have installed on the android phone rather than having to use google maps on line? I use Pay as U go phone and data transfer costs money when I already have maps on the Phone SD card. The gps works on the phone but unless I connect to data I can’t see any maps.
Chris
Ebikeman
Postby speedict » Mon Apr 23, 2012 6:40 am
Ebikeman wrote:Is it possible to use gps with maps that I have installed on the android phone rather than having to use google maps on line? I use Pay as U go phone and data transfer costs money when I already have maps on the Phone SD card. The gps works on the phone but unless I connect to data I can’t see any maps.
Chris
yes we have offline map request and it is on our enhancement list but don't have solid schedule on it ! when on route plan feature we will likely to have offline map ...
speedict
Postby cwah » Sat Apr 28, 2012 10:42 pm
I'm on windows 7 and I'm trying to get the device recognized.
I unzipped Speedict PC suite, saved the driver folder to the desktop and "Update driver software".
Then I browsed on the driver software to update it:
But after that it doesn't recognized the driver:
Image*
Any idea how to solve it?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby speedict » Sat Apr 28, 2012 10:45 pm
cwah wrote:I'm on windows 7 and I'm trying to get the device recognized.
Image*
sorry ! at this moment we support Windows 32 bit only !
speedict
Postby cwah » Sun Apr 29, 2012 12:32 am
Is there a way to make it work on a 64 bit without having to reinstall the complete system?
cwah
Postby speedict » Sun Apr 29, 2012 12:35 am
cwah wrote:Is there a way to make it work on a 64 bit without having to reinstall the complete system?
no, or wait for our paid for 64 bits digial signed certificate !
speedict
Postby nopap1 » Sun Apr 29, 2012 1:52 pm
Hi to all,
I just started to play with my recently purchased Speedict, and i'm quite happy about the product and the support provided by Danny, thanks !
A quick question about the speedo connection, the Magic Pie 3 provides a connector for a 'speedometer display'
see below
Could this be hooked to the speedict speedo connection in some way to replace the magnet ?
I have no idea what kind of signal is getting this plug, any Magic Pie expert advice ?
Thanks !
Emmanuel
nopap1
10 µW
10 µW
Postby speedict » Sun Apr 29, 2012 1:59 pm
if the speedometer connector provide on / off type signal, you can hook it up to speedict's port 1 because speedict port 1 just simply measure on / off signal !
speedict
Postby o00scorpion00o » Sun Apr 29, 2012 5:34 pm
Hi Danny,
Can power be taken form the usb port on the speedict box to power phone via cable ?
Mark
o00scorpion00o
Postby speedict » Sun Apr 29, 2012 8:31 pm
o00scorpion00o wrote:Hi Danny,
Mark
hi mark,
sorry the usb port can not provide power, just for data transfer only !
cheers,
danny
speedict
Postby cwah » Tue May 01, 2012 6:34 am
I tried the governor setting with speedict. I tried different maximum speed and power but it doesn't do anything on my bike.
I limited to 25kph and 700W but I can still go over 40 kph and 2000W. How do I use this governor thing?
Thanks
cwah
Postby speedict » Tue May 01, 2012 6:44 am
cwah wrote:I tried the governor setting with speedict. I tried different maximum speed and power but it doesn't do anything on my bike.
Thanks
can you send us your port status log ?
with both firmware and android client is 2.4 you have feature called "Port Status" under option menu.
1. go to port status page, you can see all of your 4 ports' status, press the menu button and select "record", then press the start record button, throttle up and see if speedict ebike govern your speed to 40 kph, and after that stop and send the log to us !
cheers,
danny
speedict
Postby cwah » Tue May 01, 2012 7:34 am
Hello Danny,
Just sent you the report on contact@speedict.com.
Cheers
cwah
Postby cwah » Tue May 01, 2012 1:05 pm
I also just tried the throttle mode.
It works but it's not smooth at all. I have small "acceleration bump" every second.
Also, is it normal to have a small delay between the moment I move the throttle and the moment the motor moves? The motor runs immediately without the throttle mode.
cwah
Postby speedict » Tue May 01, 2012 1:11 pm
cwah wrote:I also just tried the throttle mode.
since it's involved some parameter such as soft-start value, could you please either send me your logs or post it here together with your comments therefore we can examine it and see if it's caused by setup parameters ...
speedict
Postby cwah » Tue May 01, 2012 1:37 pm
Ok, going to do that.
Do you know what's a good value for soft start and speed gain in order to have immediat start (without delay) and not having "bumpy" acceleration?
cwah
Postby speedict » Wed May 02, 2012 12:31 am
cwah wrote:Hello Danny,
Cheers
hi cwah,
i think the main reason was the mode you used, according to your log, the function mode you selected was "Multi-Sense", with this mode speedict ebike can't govern speed (without throttle output cable function) ...
on unit setting, you use Celsius for temperature and KM/H for speed
on function mode, you selected Multi-sense
on governor setting, you set with following parameters
speed = 10 km/h
voltage set to 70v
current set to 10A
temperature set to 70c
watt set to 50w
so please focus on road legal 2 mode at this moment with both cables connected, and you can try with different speed throttle, current throttle, governor settings ... whenever you like just send us you logs for examinations because it can improve our software and we can know more about customers' practice ...
cheers,
danny
speedict
Postby cwah » Wed May 02, 2012 8:48 am
Thanks.
I tried to set to road legal 2 but it's asking me the number of magnet on my PAS sensor disc. I don't have any pedal sensor for now. How could I manage that?
cwah
Postby speedict » Wed May 02, 2012 8:55 am
cwah wrote:Thanks.
if you don't has pas installed you can leave it by default value, and don't connect any sensor to port 3 because port 3 is for pas sensor for road legal 2 mode, just want you focus on road legal 2 mode first to let you take a look of how governor and throttle mode works.
speedict
Postby cwah » Wed May 02, 2012 2:11 pm
I think I melted the speedict. I was at 79,4V and when I connected the speedict to the battery and the controller there was a spark.
No more light anymore now... :(
cwah
PreviousNext
Who is online
Users browsing this forum: Alan B, MD., mdd0127, nomoreice and 7 guests
