cwah wrote:I tried the governor setting with speedict. I tried different maximum speed and power but it doesn't do anything on my bike.
I limited to 25kph and 700W but I can still go over 40 kph and 2000W. How do I use this governor thing?
Thanks
cwah wrote:I also just tried the throttle mode.
It works but it's not smooth at all. I have small "acceleration bump" every second.
Also, is it normal to have a small delay between the moment I move the throttle and the moment the motor moves? The motor runs immediately without the throttle mode.
Thanks
cwah wrote:Thanks.
I tried to set to road legal 2 but it's asking me the number of magnet on my PAS sensor disc. I don't have any pedal sensor for now. How could I manage that?
cwah wrote:I think I melted the speedict. I was at 79,4V and when I connected the speedict to the battery and the controller there was a spark.
No more light anymore now...
cwah wrote:Thanks Danny,
To what address should I send back the speedict?
Also, is it because of the voltage 79.4V is too close to the max voltage that it melted? Is there anything I can do to make sure it won't happen again?
Thanks a lot
cwah wrote:Thanks
Could you recommend any switch or whatever I can buy (in the UK) to prevent this? I'm going to purchase it immediately after
cwah wrote:Thanks
3nslav3 wrote:Hi all,
I've recently purchased a speedict, I love the product but i'm missing a mode on it
in my Country the max speed limit on public roads for pedelec bikes is 25km/h, the max power is 250 watt (i know there is a mode for that)
but when I get on private property I would like to set my bike from pedelec to e-bike with 2000watt but that is a problem...
when I originally ordered my speedict I thought it was possible to easely change those settings using my phone but I've found out that I have to switch some wires on my speedict
with just having a throttle out, throttle in, pas in, speed sensor => so going from throttle only (full power) mode to a road legal mode (pas only, 250watt 25km/h) without switching ports but only a few screentaps on an android device would be a awesome!!!!
I think a lot of people in the Netherlands, Belgium would be intrested
Thanks for listening,
Kind regards Niels
3nslav3 wrote:Hi Danny,
Thank you for the fast answer!
I've solved my problem in a more "simple" way lol, I jut hooked my speedict up to the ebrake input of my controller,
I can switch between throttle / pas sensor, set up the current on my controllers display (crystalite APM) and use the ebrake output of the speedict as a speed limiter when the cops show up (bike is set up with pas and 250watts on public roads but not speed limited), I think it is a lot safer that way.... my bike drove away without me on it when I was fiddling with settings in road legal mode(I blame the crystalite throttle), that changed my mind to use the "simply cut" mode
it drives ridiculous but it works
3nslav3 wrote:the android speedict app switches bluetooth on/off when changing settings, during synchronizing etc.... It's really annoying sometimes as it disables bluetooth when it needs to be enabled (I have it enabled all the time on my phone and I have to switch it back on after I exit the Speedict app) so an option to disable bluetooth override would be massive!
3nslav3 wrote:battery saving option:
-possible to dim the screen during liveview, maybe a night mode (black on grey insead of black on white liveview or adjustable colors) like a lot of GPS devices have,
3nslav3 wrote:-screen always on option instead of a default setting + for safety reasons => don't get blinded by the bright display of the smartphone at night (i know some phones have a lightsensor but still......)
3nslav3 wrote:-the usage of GPS...
please make it possible to switch it on or off, it uses unnecessary battery life of the phone => sometimes you just want to log some system data instead of the route
speedict wrote:on function mode settings whenever we need to update new settings we have to reset MCU so bluetooth connections will also be reset
"during synchronizing etc.... It's really annoying sometimes as it disables bluetooth when it needs to be enabled" i don't get it, can you explain ?
speedict wrote:dim the screen, do you mean we control the brightness of display ?
speedict wrote:the liveview or multi-screen liveview screen are always on now, do you want an option to let it sleep ?
speedict wrote:yes we can add an option for on/off ...
Users browsing this forum: animal, Google [Bot], Icewrench and 13 guests
