If you have any link to any shop to do that, that would be great.
cwah wrote:Thanks
Could you recommend any switch or whatever I can buy (in the UK) to prevent this? I'm going to purchase it immediately after
3nslav3 wrote:Hi all,
I've recently purchased a speedict, I love the product but i'm missing a mode on it
in my Country the max speed limit on public roads for pedelec bikes is 25km/h, the max power is 250 watt (i know there is a mode for that)
but when I get on private property I would like to set my bike from pedelec to e-bike with 2000watt but that is a problem...
when I originally ordered my speedict I thought it was possible to easely change those settings using my phone but I've found out that I have to switch some wires on my speedict
with just having a throttle out, throttle in, pas in, speed sensor => so going from throttle only (full power) mode to a road legal mode (pas only, 250watt 25km/h) without switching ports but only a few screentaps on an android device would be a awesome!!!!
I think a lot of people in the Netherlands, Belgium would be intrested
Thanks for listening,
Kind regards Niels
3nslav3 wrote:Hi Danny,
Thank you for the fast answer!
I've solved my problem in a more "simple" way lol, I jut hooked my speedict up to the ebrake input of my controller,
I can switch between throttle / pas sensor, set up the current on my controllers display (crystalite APM) and use the ebrake output of the speedict as a speed limiter when the cops show up (bike is set up with pas and 250watts on public roads but not speed limited), I think it is a lot safer that way.... my bike drove away without me on it when I was fiddling with settings in road legal mode(I blame the crystalite throttle), that changed my mind to use the "simply cut" mode
it drives ridiculous but it works
3nslav3 wrote:the android speedict app switches bluetooth on/off when changing settings, during synchronizing etc.... It's really annoying sometimes as it disables bluetooth when it needs to be enabled (I have it enabled all the time on my phone and I have to switch it back on after I exit the Speedict app) so an option to disable bluetooth override would be massive!
3nslav3 wrote:battery saving option:
-possible to dim the screen during liveview, maybe a night mode (black on grey insead of black on white liveview or adjustable colors) like a lot of GPS devices have,
3nslav3 wrote:-screen always on option instead of a default setting + for safety reasons => don't get blinded by the bright display of the smartphone at night (i know some phones have a lightsensor but still......)
3nslav3 wrote:-the usage of GPS...
please make it possible to switch it on or off, it uses unnecessary battery life of the phone => sometimes you just want to log some system data instead of the route
speedict wrote:on function mode settings whenever we need to update new settings we have to reset MCU so bluetooth connections will also be reset
"during synchronizing etc.... It's really annoying sometimes as it disables bluetooth when it needs to be enabled" i don't get it, can you explain ?
speedict wrote:dim the screen, do you mean we control the brightness of display ?
speedict wrote:the liveview or multi-screen liveview screen are always on now, do you want an option to let it sleep ?
speedict wrote:yes we can add an option for on/off ...
speedict wrote:adjust font color will be in next release
cal3thousand wrote:I can't wait to get my Speedict back, I miss it!![]()
USPS is not doing it's job well enough. 3 Weeks and it says "at sorting facility"
3nslav3 wrote:speedict wrote:adjust font color will be in next release
Woohoo!!!! Thank you very much!!!![]()
about my "bluetooth problem" : after some testing I noticed that it doesn't happen during normal use (liveview etc)![]()
it's mostly caused by loosing connection with my phone so it's not a big problem, I think that the problem is my phone and not the speedict so sorry for that
PeeHell wrote:Hi Danny,
I was wondering if it would be possible to implement a "battery gauge" function in the next release. The user could input the min. and max. voltage of his battery pack and the function could return the percentage that's left on the display screen. You could also add a battery type parameter to make it more universal.
Is such a function possible on the speedict next firmware release ?
Xanda2260 wrote:Would be cool to have an option for a percentage remaining guage in live view, or maybe a bar that reduces as battery is depleted.
On a seperate note, is anybody else finding the gps speed to be miles off? Using various speedo apps, the top speed for my trike is 42mph (verified using 2 other gps devices). But in the speedict software its totally off. I was trying to calibrate the speed sensor so I put sensor speed and gps speed on live view, and went for a ride. Sensor was about 3-4mph off the speed listed by my other gps devices and the speedo apps, but the gps speed in the software was consistently less than half the sensor speed!
What gives?
speedict wrote:Xanda2260 wrote:Would be cool to have an option for a percentage remaining guage in live view, or maybe a bar that reduces as battery is depleted.
What gives?
hi xnda2260, sorry ! do you mean speedict's gps or speed sensor incorrect ?
Xanda2260 wrote:speedict wrote:Xanda2260 wrote:Would be cool to have an option for a percentage remaining guage in live view, or maybe a bar that reduces as battery is depleted.
What gives?
The GPS is incorrect, its reading very low.
3nslav3 wrote:
same problem here, very low GPS speed, the speedsensor works perfect!
Users browsing this forum: anpate, DrkAngel, Google [Bot] and 15 guests
