Emoto wrote:Hi Danny i think i will wait to see how this new product looks, before i order.
I like your product, but if you were able to plug into controller [ for hubmotor ] and use the hall signal for speed sensing, this would eliminate the speed cable + magnet, cycle annalist uses this technique.
Would be a cleaner installation
cwah wrote:Congratulation for your new product MERCURY. I've seen it's limited to 70V?? Damn, you're going to miss a lot of customers in endlessspehre. Why not increase the max voltage? The Cycle analyst has a good limit of 150V and that's nice.
Erikjan wrote:do you talk about this http://www.bosch-ebike.de/en/service/service_1.html ?
cwah wrote:Thanks Danny.
Is it this one the so "speedict controller" that we were all waiting for... or is there another one coming out? Please don't forget the high voltage guys!
speedict wrote:Emoto wrote:Hi Danny i think i will wait to see how this new product looks, before i order.
no, this is not for hub motor, it is for bosch type approach.
i think you can use hall signal instead of speed sensor, all you need to do is hand make this cable, i need to confirm it as i remember i was told by customer he did that
Emoto wrote:speedict wrote:Emoto wrote:Hi Danny i think i will wait to see how this new product looks, before i order.
Sorry Danny i meant the new version of the original speedict,i believe you said would come out in December any more news on that release ?
And on using the hall signal from the controler for speed, instead of the wheel wire /spoke magnet, it was more of a request for official support/ development, im sure it would be popular with users as it is with the Cycle Analist.
Erikjan wrote:Today recieved tracking code, hope the cabels arived before 29-aug then i have somthing to do at my vacation
Danny do you know if it is possibel to mount the speedict inside the controller case.
I don't know if the bleutooth signal will pass the alloy case
I will be much cleaner installation with all the cabels inside the controller case
My controller runs not verry hot, i use only 15A 44.4V and have good airflow.
I dont thing heat inside the controller is a problem for the speedict.
And i can use the temp sensor for cutoff if it runs to hot.
speedict wrote:cwah wrote:no, this is not speed controller, it is a device for bosch system, let them to test or change the bosch system top speed e.g. 25km to 40km ... for bosch system therefore 70v is good enough
cwah wrote:Hello Danny,
I'm very happy with the speedict, I have 2 questions if you don't mind:
- Every time I close speedict I loose all the data on the software. Data are not lost in the speedict, but is there a way to keep track of the previous session on the speedict? The only way to keep track is to never close the software, but sometime it's a bit annoying when I need memory in my phone.
- I have a small sensor on my Mac motor. It is just a red wire giving 1v=1°C. Is there a way to plug that to the speedict? Is the standard temp sensor works the same?
Thanks
cwah wrote:Every time I close speedict I loose all the data on the software. Data are not lost in the speedict, but is there a way to keep track of the previous session on the speedict? The only way to keep track is to never close the software, but sometime it's a bit annoying when I need memory in my phone.
cwah wrote:- I have a small sensor on my Mac motor. It is just a red wire giving 1v=1°C. Is there a way to plug that to the speedict? Is the standard temp sensor works the same?
cwah wrote:I just mean the screen on android. If I turn the application of, all the data (wh, km, etc...) is reset. Was just wondering if there is a way to keep that when the application is off (in android)
cwah wrote:Also, is there a simple way to add a voltage divider? Is there anything I can solder in series to divide the voltage?
cwah wrote:Yeah, the session are a bit annoying because I always disconnect the battery when the bike is not in use to preserve the battery. Would be great for next update to keep the session until user decides to have a new one.
cwah wrote:I have a temp sensor directly plugged inside my mac motor when I purchased it. So I'd like to be able to see how it goes
This sensor goes in line directly with my hall sensor plug (I have 6 pin). So it's maybe 5V? I'm not sure I have to ask cellman for that. Could you recommend the voltage divider in order to achieve that? I also don't have another plug to go into the speedict, so I may have to buy another temp sensor from you and strip the voltage divider in it.
Thanks
Thanks
cwah wrote:Cellman told me that:
"The temp sensor output signal is on the unused wire on the hall sensor plug. You can measure DC voltage reference to the hall sensor ground (black) wire."
I've found this thread talking about it:
"These motors are fitted with an LM35 temperature sensor.....Cell_Man selected this device over the passive devices which Justin suggested to enable folks without CAs to use a simple voltmeter to measure temperature (the LM35 outputs 10mv / °C, so it reads nicely on even a simple $5 voltmeter.) However the internal architecture of the LM35 is such that it won't work properly with a pullup voltage applied to its output- it can only source current, not sink it."
viewtopic.php?f=4&t=37964&start=270#p573801
So I may be able to use the temp sensor as is? Just need to buy the temp sensor adaptor to the speedict from you then
Users browsing this forum: Drunkskunk, Martin A, neptronix and 17 guests
