Quest for "super stealth"
Re: Quest for "super stealth"
Postby Drunkskunk » Fri Feb 04, 2011 1:12 pm
jbond wrote: The catch in making it stealth is hiding the battery. I'd really like the battery in the triangle for weight distribution but it's pretty obvious there.
It doesn't have to be obious. A frame bag looks perfectly normal there. Its a harder trick to hide the controller. But the thing that attracts attention is anything that looks hand made, or has wires sticking out of it.
Drunkskunk
Postby cell_man » Fri Feb 04, 2011 1:15 pm
jbond wrote:
ChinaPhil wrote:They are not Bafang hub motors - both are 350W geared hub motor kits from cell_man who is a member of ES. They are rated for 36V but seem to be OK at a nominal 44V (12s LiPo).
Ah, ok. Dug around on cell_man's thread in for sale. They appear to be Cute QR-100 I was looking at Cute motors as they are very light but was put off by warnings of unreliability. I'm also a bit bothered that the axle doesn't go right through but is 2 piece. None of this may be a problem.
They are not Ananda/Cute motors.
http://www.emissions-free.com/ has just come online. It's a bit naff at the moment, but it can only get better :)
Drop me a line on emissions-free_worldwide(at)hotmail.com if you want to discuss any products I stock or you would like to source in the future.
cell_man
Postby ChinaPhil » Fri Feb 04, 2011 11:31 pm
I always carry batteries (4 off 6s 5,000mAh 25C) in a backpack, easy to hear the LV buzzers.
Just climbed some 15% inclines and the speed is higher than the 500W Cyclone bike with all of its gearing - guess 15km/h versus less than 10 km/h - the inclines are narrow so there is no time to look at speed readouts.
At this stage I am content with the visual stealth, audible stealth, hill climbing ability and top speed.
Cyclone 500W, SRAM DualDrive, hardtail; 8s Lithium Iron Phosphate, 38A
Cellman 350W geared hubs, 2WD, hardtail; 12s Lithium Cobalt Oxide, 2 x 17A
Cellman 500W Mac rear geared hub (upgraded gears), full suspension; 12s Lithium Cobalt Oxide, 59A
ChinaPhil
Postby cell_man » Sat Feb 05, 2011 4:12 am
Hi Phil,
That sounds pretty good, those figures aren't bad at all. Who would believe it, a couple of hub motors can beat a non hub setup on an incline :) I recently supplied a dual Mac setup, both were low speed winds, about 200rpm loaded at 36V, so no faster than your setup. Difference is the rear is running a 500W Mac and the Front a 350W Mac, 12 fet (about 40A) infineon on the rear and a 9 Fet (30A) on the front. Should make for an interesting ride at 48V.
How did you get on with the throttle? Are you still using 1 throttle for each controller or have you tried the mod'd throttles I sent you to run both controllers simultaneously?
Cheers
Paul
cell_man
Postby ChinaPhil » Sat Feb 05, 2011 4:23 am
Will try one throttle as soon as possible and maybe fit a switch to give one throttle or two. At the moment I have the front wheel throttle on the right and the rear on the left to match the braking.
ChinaPhil
Postby cell_man » Sat Feb 05, 2011 5:26 am
Sorry Phil,
don't want to get personal :oops: but how heavy are you? The bike and battery pack is what, somewhere between 25 & 30kg? It's just good to have some figures in mind, unfortunately there are no hills around here to check the hill climbing ability.
Cheers
Paul
cell_man
Postby ChinaPhil » Sat Feb 05, 2011 7:01 am
Paul,
it is a good job that we both live in the East where this sort of question is the norm. I am 95kg fully dressed, so a total of 125kg sounds about right. And, before you ask, I was born in the year of the rat.
Phil
ChinaPhil
Postby GrayKard » Sat Feb 05, 2011 3:59 pm
cell_man wrote:Hi Phil,
People are starting to see the the advantages of dual hubs. Set up right it's really hard to beat.
I'm liking the stealth you have going on there Phil, nice looking bike. I still plan on doing more to hide my controllers and wiring to try and achieve super stealth status. 8)
Gary
GrayKard
Postby ChinaPhil » Sat Feb 05, 2011 8:31 pm
Just been out on a ride with one throttle driving both controllers. Now I can't decide which I prefer, one or two throttles. Suspect that for audio stealth two throttles are better as only one motor can be used but, for steep hill climbing, when I am just trying to hang on, one throttle is best. Tending to think that a switch to select 1 or 2 throttles is the way forward.
ChinaPhil
Postby MadRhino » Sat Feb 05, 2011 8:45 pm
ChinaPhil wrote:J...Tending to think that a switch to select 1 or 2 throttles is the way forward.
Why not one throttle, with a switch to select 1 or 2 WD :idea:
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby dogman » Sun Feb 06, 2011 8:19 am
My inclination would be 1 throttle, and a simple switch to cut it off to the rear controller. Ride front hub till you need more, then switch on the rear.
Actually, two switches would be neat too, so you could run front only or back only. Why? so you could cool a hot motor, and run on the other awhile at your choice. So on a really long trip, you could alternate which motor every 30 min or so keeping em nice and cool for miles and miles.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby ChinaPhil » Mon Feb 07, 2011 9:59 am
Found that the supplied throttles are too visible, especially at night with 3 lights per throttle (the red button is for cruise control):
DSC_2510 throttles.jpg (83.22 KiB) Viewed 297 times
so I have removed them and fitted one no bells/whistles 3 wire throttle.
As the controllers are connected to the battery via a "Y" lead I do not connect power to the front hub motor controller when I want one wheel drive. I really do not mind the delay before 2 WD can be engaged but should get a handle on the efficiency of this bike's drive permutations before making a final wiring decision - CA time!
ChinaPhil
Postby ChinaPhil » Tue Feb 08, 2011 11:17 pm
Dogman and MadRhino,
you really made me think, thank you. I liked the idea of 2 switches, one to select rear WD and the second for front WD so, I used 2 cheap bicycle lights (just removed the batteries and accessed the button switches:
DSC_2513 twin lights.jpg (79.52 KiB) Viewed 281 times
Visually it just looks like 2 lights, "switch on" the left for rear WD, right for front WD and both for 2 WD. Now I just need to get power to the 2 sets of LEDs.
ChinaPhil
Postby miuan » Mon Feb 14, 2011 9:32 am
dogman wrote:My inclination would be 1 throttle, and a simple switch to cut it off to the rear controller. Ride front hub till you need more, then switch on the rear. Actually, two switches would be neat too, so you could run front only or back only. Why? so you could cool a hot motor, and run on the other awhile at your choice. So on a really long trip, you could alternate which motor every 30 min or so keeping em nice and cool for miles and miles.
Actually, on my dual 9c setup, I prefer to always run both hubs except when I want to save energy on slower straights. I have dual switches, one of them wired to an ebrake rather than power, because the controller needs to power the single throttle (remain ON) all the time.
Switching to a "cooler" motor is not a good idea IMO. I'd rather have both motors on, instead of putting high load into a single motor...
miuan
Postby SamTexas » Mon Feb 14, 2011 12:24 pm
Interesting set up, Phil.
One naive question for you and Paul: I know that the controller has a 17A limit, so definitely insufficient to provide power for both hubs. But if it was a 34A controller, could it be used to power and control both hubs?
Sam
SamTexas
Postby Drunkskunk » Mon Feb 14, 2011 5:41 pm
SamTexas wrote:Interesting set up, Phil.
Sam
No.
You couldn't use 1 distributor to run 2 gas engines, you can't use 1 controller to run 2 motors.
Drunkskunk
Postby ChinaPhil » Mon Feb 14, 2011 8:02 pm
miuan wrote:Actually, on my dual 9c setup, I prefer to always run both hubs except when I want to save energy on slower straights.
This is how I am now riding, normally both hubs but only the rear when I want to ride as quietly as possible. Must get some instrumentation to see which is the most efficient one hub motor or two.
Sam
No.
The controllers are small and I prefer some redundancy so I have not considered one controller - leave it to the gurus to say whether one controller will work.
ChinaPhil
Postby SamTexas » Tue Feb 15, 2011 8:06 am
Drunkskunk wrote:No.
Of course it's possible with 2 identical brushed motors. What I would like to know is why it might be a problem with identical brushless motors. Appears to be HAL synchronization related.
SamTexas
Postby ChinaPhil » Fri Mar 11, 2011 12:01 am
A couple of videos (I hope):
cows, dogs and people do not notice the approach:
http://www.youtube.com/watch?v=y1grWWx0H0s
mountain path:
http://www.youtube.com/watch?v=WDm7lIHih8U
ChinaPhil
Postby SamTexas » Fri Mar 11, 2011 6:36 pm
ChinaPhil wrote:cows, dogs and people do not notice the approach:
Thanks for sharing. Is this Hong Kong? I've never seen it from this angle. Are cows allowed in residential area?
SamTexas
Postby ChinaPhil » Fri Mar 11, 2011 9:53 pm
SamTexas,
the cows are free to roam where they want, villagers fence their crops to prevent bovine destruction.
Phil
ChinaPhil
Next
Who is online
Users browsing this forum: crossbreak, henni001, loco13, Sunder, The fingers and 19 guests
