urbancommuterstore.com said:
I'm thinking of using an Amped Bike Geared Hub motor for my mid-drive set-up, Im not sure if this will work, but since it should technically have more torque, it looks ideal on paper. I will find out once I have set it up. I don't have the new frames yet, I will have them by next week. What do you think is a good gear to start with the freewheel? 14T or 16T? The biggest cog in the back will be 34T. Thanks.
I think the motor cog vs the rear cog is mostly a question of speed. Say you have a Shimano 14t-34t Megarange on the back. A 14t on the motor will give you the same gearing as if the hub was rear mounted. 14t-14t. 14t-34t is ~1.0-2.4 gear range. If you run a 16t on the motor, then you have ~0.875-2.1 gear range.
Let's say you pick a geared hub motor with a bolted down cover (Mac, Bafang BPM) rather than a spin on cover (Bafang QSWX). Then you work out some way of fitting a 16t fixed and 16t freewheel. Chainset to rear derailleur will be the same as stock. Motor to rear will be geared up slightly for a touch more speed when in 7th. Motor to rear will be 2:1 when in 1st for loads of hill climbing torque. Apart from mounts, chain runs and so on, the big problem is how to securely mount a fixed and freewheel on the motor. There's limited space and thread depth on the freewheel mount. And the thread direction means it will try and undo itself. I feel sure there's a solution though with a keyway or a grub screw or something.
