RyanTo wrote:Do I need the DNP removal tool or is that something I could pick up locally? I'd rather get the one off eBay but it doesn't look like they have the tool..
Any of these should work, 11T requires longer reach.
$10
$7.60
$8.99
Two possible solutions:
1. Seal all joints, I used duct tape, to keep grinding residue out of freewheel. Grind notches down, about half way. Remove tape and install.
2.(Recommended method!) Insert a 3/8" standard washer as a spacer, clearance is very close, 1/16" might be enough, 1/8" thicker than necessary.
anarce wrote:Great post! I ordered the 16T freewheel and I'm getting ready to mod my eZip Trailz. Unfortunately I couldn't find the chain link kit at the local bike shop and had to order one online, so I'm waiting for parts again. I'll try to take some pictures along the way to add to this thread.
I'm a little confused by this part of your instructions:Two possible solutions:
Do you mean 3/16" thick washer? 3/8" seems like a lot, and if I'm following you, you say that it should be 1/16" plus another 1/8" for safety, so 3/16" total. I figure once I start putting it together I can pick up a handful of different washers at Home Depot and see what fits, but I wanted to confirm.
anarce wrote:OK, I successfully completed this mod last night! Thank you for all the great info, DrkAngel! I rode to work this morning and was running at 18-19 mph on the flats with just the motor.
DrkAngel wrote:If you spin the removed, OEM freewheel, does it still feel like it is filled with tar.
Does your motor have the "C" insignia, or the inverted triangle?
Check your sprockets, are they still nicely aligned?
Shifts easily?
(2008 is nice but 2009 shifter is almost painfully stiff)
DrkAngel wrote:Still waiting on my machine shop buddy to finish my 11T motor drive sprocket.
Searched till I found a possible 12T item!
Users browsing this forum: crossbreak, Observator and 16 guests
