stanz wrote:liveforphysics wrote:There are no LiMn 26650 size cells with 4Ah of capacity. They are either cobalt dioxide, or ~3Ah to maybe 3.5Ah if they really have awful impedance.
Maybe they are "creatively" labeled.
Um, I just checked the Li-ion charger you recommended, and it has a negative rating, but I cannot read the review. So, I'm not sure if the web site shows ratings which do not require a review. Irregardless, its only 1 rating, although its poor. I know I wont be a guinea pig and find out. I never purchase products unless they have several good ratings.DrkAngel wrote:In regard to charging Li-ion - Lipo battery packs:
Previously, I have always "recommended" - "highly recommended", the implementation of a PCB\PCM\BMS, recent trials with a dedicated Li-ion charger, seems to prove it, an unnecessary item! ... ?
(Tenergy 25.9v 2A charger - <$30 each, shipped, if buy 2.)
Floont wrote:Um, I just checked the Li-ion charger you recommended, and it has a negative rating, but I cannot read the review. So, I'm not sure if the web site shows ratings which do not require a review. Irregardless, its only 1 rating, although its poor. I know I wont be a guinea pig and find out. I never purchase products unless they have several good ratings.DrkAngel wrote:In regard to charging Li-ion - Lipo battery packs:
FA
PS I am putting my 'shopping list' together for my switch to Lipo and stumbled on this thread. Caveat emptor.
DrkAngel wrote:Floont wrote:...I am putting my 'shopping list' together for my switch to Lipo and stumbled on this thread. Caveat emptor.DrkAngel wrote:In regard to charging Li-ion - Lipo battery packs:
Better now!
DrkAngel wrote:Got me 4 more of the Tenergy 25.9v Li-ion chargers. Ganged 2 together for a 4amp charger. Now I can charge my 31.2ah pack, while I sleep! Worked great, last night!
Oh yeah. Floont pointed out that I hadn't left any rating on the web site, so I tacked on my 6 Positives!
Reviews not available for several days ... review by moderator ... standard procedure.
DrkAngel wrote:Next up? ... RC Lithium-ion Polymer, stuffed into an EZip battery pack!
2 viable options:
25.9v - 22.8ah
4 banks of 7 cells.
2 - 2 cell packs, will be split, to provide 7th cells.
37v - 17.1ah
3 Banks of 10 cells.
Each bank comprised of 3-3packs(9cells) plus a single cell of the 10th 3-pack.
Sadly, my source has dried up, (shipping mah limitation on Lipo? ), and I only have enough for 1 pack.
So I might save my 11 3-packs + 2 2-packs for a more demanding project.
Packs are rated 20C surge:
456 amps from 25.9
or
342 amps from 37v
and:
15C continuous:
342 amps from 25.9
or
256.5 amps from 37v
JoramsWeapon wrote:
I've used that brand of cell before bought from China and a pretty good price at the time. Terrible experience. They were rated for 20C sure but when put to the test they barely pumped out 10amps without heating up quickly. I put 12 of them in a 10S6P setup and they overheated very quickly under 35amp draw and had that tell-tale smell of cooked Lipo. I hope your experience turns out differently.
A few questions:
12 - 11.1v (3 cell) packs would be 36 cells, would not a 10S6P pack be made of 60 cells? 12 - 18.5v (5 cell) packs?
Were your packs the older, copper wire, or the newer, silicone wire, type?
"They barely pumped out 10amps without heating up quickly", "35 amp draw and had that tell-tale smell of cooked Lipo," - from a 5.7ah pack?
JoramsWeapon wrote:The packs I had used silicone wire at 14ga. Each brick was 5S 5.7ah 20C, 12 of those bricks were arranged as 10S6P. I'm counting by lipo brick not cell, but yes 60 individual cells total. Each brick had trouble delivering 10amps, I got about 3/4 capacity on the discharge but the amount of heat generated was alarming. Even so I figured that in 6P configuration the bricks would hold together fairly well under ebike conditions, failed miserably. I actually did the same thing you're doing now by stuffing them into an Ezip case, everything was cool until I hit the throttle.
The batteries that managed to survive that quick run now power my laptop for many hours, a much more sensible application i think.
DrkAngel wrote:JoramsWeapon wrote:The packs I had used silicone wire at 14ga. Each brick was 5S 5.7ah 20C, 12 of those bricks were arranged as 10S6P. I'm counting by lipo brick not cell, but yes 60 individual cells total. Each brick had trouble delivering 10amps, I got about 3/4 capacity on the discharge but the amount of heat generated was alarming. Even so I figured that in 6P configuration the bricks would hold together fairly well under ebike conditions, failed miserably. I actually did the same thing you're doing now by stuffing them into an Ezip case, everything was cool until I hit the throttle.
Big question!
How did you manage to fit 60 cells into an Ezip case, when I can barely squeeze in 30, of the same size cells?
justadad1957 wrote:the tinned copped braid looks like it can take some amps
keep your tire pressure gauge outta there
Starson wrote:Wouln't a 6 pack cooler bag be insulated and trap any heat generated and ruin the batteries? Also, it may look inoccuous, but I'd be worried that instead of someone looking to steal batteries, kids & cops would be looking for the beer, except for Yogi Bear of course, who likes to steal the "picinic baskets".
Gary
Gary
Users browsing this forum: agniusm, dnmun, ErikDK and 7 guests
