DrkAngel wrote:1-8S Lipo Battery Tester Low Voltage Buzzer Alarm
24hr report:
4.32ah battery
Drained .1v - 24 hours
Draws power from S1 and S2 only
.1v might not seem like much, but that is more than 10% capacity of 2 banks, which would lower entire pack usable by 10%
Of course, with a 20ah pack, that would be a mere 2% per day ...
Still, I would have to recommend, that item should be used only during pack usage, or to check pack occasionally.
A switch or momentary contact button, on neg pin, would easy on-off or allow quick check.
DrkAngel wrote:Great new price on, 1-8S Lipo Battery Tester Low Voltage Buzzer Alarm. $3.29 w/shipping
Half the price of previous best price! I ordered another 5.
Displays total voltage and well as that of individual cell-bank.
Programmable low voltage alarm, audio-visual. (2.7-3.8v)
1-8S Lipo Battery Tester Low Voltage Buzzer Alarm RC 1S - $3.29 w/shipping$3.29
Note: Claims accurate to within 1/100th Volt, actual, from several, is a few 100ths.
Total voltage accurate, cell accuracy varies.
I use one as an "on bar" volt-fuel gauge. Rigged into throttle, (voltage to battery level leds).
Up to 30v 1S meter, just attach to neg - pin 1 and pin 2.
Use multiple to monitor, larger than, 8S packs.
liveforphysics wrote:Those devices are what's known as a battery-unbalancer.
Floont wrote:Why would they do that?
Sorry, lipo no0b here. (Ask me about SLA's and I'll talk your ear off; and yes, SLA's are not fashionable and eventually I will be ditching them).
FA
DrkAngel wrote:Floont wrote:Why would they do that?..
The meter draws power from S1 and S2 only, (bank 1 & 2)...An alternate draw on 2 banks will cause those 2 banks to recharge to a lower voltage, every cycle becoming worse...
FA
Good condition Li-ion - Lipo tend to discharge and recharge at a fairly constant rate.
Meaning?
A Li-ion Lipo pack will discharge-recharge back to the same "equalized" voltage, (all cells same voltage), without a balance-equalization device.
An additional draw on 2 banks will cause those 2 banks to discharge and recharge to a lower voltage, every cycle becoming worse.
Unless ... you use a balance-equalization charger.
DrkAngel wrote:...If wired into throttle meter LED voltage, it will disengage when power to controller is disconnected...
bobale wrote:Will those 18650 batters be able to provide enough current to drive such powerful tools?
DrkAngel wrote:Li-ion is 14.8v 5.2ah and, as I tested, capable of 10 amps continuous 20 amps surge.
Users browsing this forum: biohazardman, o00scorpion00o and 7 guests
