Please help me electrify my trike...
Re: Please help me electrify my trike...
Postby corkscrew » Wed Apr 06, 2011 7:04 pm
Gordo wrote:WAIT, That is wrong. You have 22V+ from one set of 4 on the left terminal and 24V- from the other set on the same terminal.
Try this one. Sorry for the spazout on paint, never used it before.
THIS is why I'm figuring this out before my batteries arrive. :)
Thanks for the edit, mspaint is good for this stuff.
It makes a lot more sense now.
Actionbent T1 Tadpole Trike - 2806 9C Motor in a 700C wheel. 30AH 48v LIPO powered!
--Build thread: viewtopic.php?f=3&t=26520
corkscrew
Postby Gordo » Wed Apr 06, 2011 7:19 pm
Maybe do a little more reading on series/parallel circuits? Play around with some alkaline "AA" that are almost dead? Do you have a multimeter?
http://www.ted.com/talks/annmarie_thoma ... dium=email This is not meant for you, just something I found entertaining and great for my wife and daughter.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
Gordo
Postby corkscrew » Wed Apr 06, 2011 7:27 pm
I believe I've got it down now. I do own a multimeter. I really shouldn't try to design circuits when I should be working...
Ha! I like it. I have two brothers about to graduate in Electrical Engineering, I think they might find this fun. :)
Well, ordered a 1420I charger last night, as well as GGoodrum's 12S charging cable + 2x6s parallel + LVC kit. Sent the pdf to my brothers and one replied saying as long as I get it to him while he's still in school for EE, that he'd solder it up for a bottle of good vodka. So that's covered.
Spent WAY to much money on buying anderson power poles last night too, but hopefully will have enough connectors to complete this build + some extras for whatever I add later. Ordered 25 feet of their 10 gauge zip wire too. Hoping to run all the primary power wires as 10 gauge with 45amp anderson connectors. I bought a fuse too - it comes with two 40amp fuses, but am I going to want to run higher rated fuses due to having a 40amp peak controller?
Just sent my payment to ebikes.ca - hopefully in the next week or two I can start assembling this whole mess. :)
I started with 1300 set aside for all of this - I went over by 344.65 - Not terrible in the long run I suppose.
corkscrew
Postby corkscrew » Mon Apr 11, 2011 5:40 pm
Random update to keep this alive until all my parts arrive.
Got an update from ebikes.ca - they ran out of the 2807 700C kits in between when I placed my order and when I sent my payment.
So they are building a 2806 rear hub into a 700C wheel for me with Sapim 13ga spokes @ half the price of normal wheel builds + spokes.
So faster hub and sturdier build for meeeee!
Other than that, everything is in the mail, but with hobbyking not issuing tracking numbers, and the wheel build delay, who knows when it'll all come in!
corkscrew
Postby corkscrew » Thu May 12, 2011 12:33 pm
Thought I'd give this an update finally.
All the parts are in for the most part. Have my stainless steel battery boxes made and mountable to the side of the trike, right behind where the seat sits. Just have to find some aluminum to make some custom covers for them. One will have my 48V->12V Dc converter in it, along with 4 of the 6S 5AH turnigys. The other will have a 100amp circuit breaker along with the other 4 batteries. The TPpacks LVC board and 8 12" 6S balance extenders mounts under the trikes tube, in between the two stainless steel boxes. The main charge plug will be secured out of that radioshack project box, once I get some better heat shrink wrap. (Do you know how hard it is to find sheets of shrink wrap in Boise ID???).
Mounted the controller just in front of my seat (power leads made more sense that way) with a piece of plywood and some 2" u-bolts. It works for now, but will be finding a piece of aluminum or stainless to exchange for the plywood. I like that I'll be able to reach the controllers power button when riding.
So now just figuring out a few things on the boxes before I label them as "complete". Mainly where I want the powerpole panel mounts to exit. Also wondering if I should add a 12V computer fan - I have room in the boxes to add an 80mm fan on each one to act as a vent, but not sure if it's a good idea or not as far as waterproofing goes. Will have to see how hot the boxes/batteries get come summer.
(Two paralleled bricks of 4 turnigy's per side, so 22.2V @ 20AH - then a serial connect line will run between the two boxes, finally equaling a 44.4V 20AH setup.
One point of confusion - is that a 12S2P battery, or a 12S4P battery? I have two packs making up the battery, so that makes me think 2, but I have 4 sets of serial connected batteries technically, so that makes me think 12S4P.
I'm short on pics, but I did shoot a little video last night when I was testing the setup after I got the battery pack all wired up.
http://www.youtube.com/watch?v=-vtPrfcZne4&feature=player_embedded
I'm a bit irked though - after shooting this vid I was discharging the entire pack down to 60% (storage charge), since they might be sitting for awhile before I get it on the road. 40 minutes in, something sparked in the charger, and left me SOL. Hyperion USA has already said they will replace it though, so I sent my receipt, RMA form, and the charger back this morning.
corkscrew
Postby corkscrew » Tue May 17, 2011 9:46 am
Snapped some pics - thought I'd put them up here to help document my progress. :)
corkscrew
Postby rscamp » Tue May 17, 2011 11:09 am
Cool!
A few comments based on the pics:
The controller appears to be up front but the motor and batteries are near the back. This makes for long runs and associated greater voltage drops when currents are high for these the main power wires.
The batteries will need to be protected from abrasion and held in place. Will you be using compression or double sided tape or... ?
The torque arm is lever is projecting a very shallow angle between the motor axle, the intermediate pivot point and the attachment point on the arm. Therefore, it won't be very good for resisting torque. The closer this is to 90 Deg. the better.
Nice low positioning of the battery boxes!
Rob
Trice QNT with Astro 3215 8T & V4 Drive
Trice Q with eZee (EZ-R-09001-32)
rscamp
Postby corkscrew » Tue May 17, 2011 11:38 am
rscamp wrote:Cool!
On the controller - With the supplied cable lengths from the e-bikes.ca kit - nearly everything lines up to not need extended and is not pulled taut, but not need shortened either. I first attempted mounting the controller under the rear rack (it clears rather well), however I would have had to extend my e-brake, throttle and cycle analyst connections. Should I bother shortening the motor cable & hall sensors a bit? I like having the controller in front of where my seat will be, as it grants access to the power button for the system while sitting.
The boxes are a work in progress - they are mounted as is stuck together with heavy duty 3M double sided tape. Before I go and start running them, there will be a lining of a wide gasket style sealing tape around the boxes, and they will be compressed in when the side panels mount on. I'm also hoping to order some shrink wrap sheeting to wrap both battery groups, I just can not find any locally so far, and need to wait till payday to order some. :) Then again, I'm tempted to run without the LVC kit and add another two batteries (1 per side) for a 25A/H group.
On the torque arm - should I just move the attatchement point to more of a 90 degree angle, say maybe to the seat stay vs the chain stay? I won't be able to move the pivot point and still connect to the frame.
Thanks for the comment on the boxes! With the seat installed you can hardly see them. I'm lucky to have buddies with stainless steel and tig welders. :)
corkscrew
Postby rscamp » Tue May 17, 2011 11:48 am
Whether or not shortening the wires is worthwhile from a functional viewpoint depends mainly on current draw and how fussy you are about reducing voltage drop. If you have a beefy controller and run at high currents, you would probably notice the difference. If not, you probably won't. I shorten wires as much to avoid bundling wires or routing them the length of the bike as anything. My controller is behind/under the seat and it is easy to reach too.
Regarding the torque arm, if you flip the base portion over won't the pivot point end up close to 90 Deg?
Rob
rscamp
Postby corkscrew » Tue May 17, 2011 12:05 pm
rscamp wrote:Whether or not shortening the wires is worthwhile from a functional viewpoint depends mainly on current draw and how fussy you are about reducing voltage drop. If you have a beefy controller and run at high currents, you would probably notice the difference. If not, you probably won't. I shorten wires as much to avoid bundling wires or routing them the length of the bike as anything. My controller is behind/under the seat and it is easy to reach too.
Ah ok. The controller is a 40amp Infineon, and I'll be running a 12S setup. Batteries are paralleled with 12gauge wire (need to upgrade to 10gauge and 75amp Andersons), and then serially connected with 10gauge wire, which is what the rest of the system will use. I'll probably leave it as is for now since everything is lining up rather neatly - once it's put together, if I see any drastic voltage drop, I'll look into moving it/shortening the power wires.
I seem to remember having problems flipping the pivot point (as far as getting the screw/nut to clear), but I'll play with it when I get home tonight.
corkscrew
Postby rscamp » Tue May 17, 2011 12:15 pm
corkscrew wrote:I seem to remember having problems flipping the pivot point (as far as getting the screw/nut to clear), but I'll play with it when I get home tonight.
Spacer washer maybe?
Rob
rscamp
Postby corkscrew » Tue May 17, 2011 12:19 pm
Perhaps. This is why I post these things. :)
corkscrew
Postby chvidgov.bc.ca » Tue May 17, 2011 12:44 pm
I would consider the torque arm from amped-bikes on there. I think it is stronger than the one you have, and very adjustable. It has no pivot point, just an inner star cut into multiple 16? points that slots into the outer main piece. Extremely hard material. I think it would work well. Perhaps put it on the other side. The dropouts are the heart of these bikes and there is great peace of mind from having massively over-designed torque reinforcement.
CatrikeRoad Rear9C 2805 KU123Sensorless CA
DevinciVancouver Front9C Disk
Rebike 20"R/16"F Bent C404 Front 48V 20A Crystalyte Pedal First
CCM 26" Cruiser Nexus 7 C406Front 48V 35Amp Crystalyte Start Imm
Sun EZSport CX 26R/20F LWBent C405 Front 48V 35Amp Crystalyte Start Imm
Giant Revive DX 20" Nexus 7 RearSusp with 9C Front 48V KU123
Actionbent T1 trike with Rear9C2806 KU123Sensorless CA
Vision R40 Recum USS SWB EZEE
CannondaleHooligan Cute100 48VHead 60T ring KU63
chvidgov.bc.ca
Postby corkscrew » Tue May 17, 2011 12:49 pm
chvidgov.bc.ca wrote:I would consider the torque arm from amped-bikes on there. I think it is stronger than the one you have, and very adjustable. It has no pivot point, just an inner star cut into multiple 16? points that slots into the outer main piece. Extremely hard material. I think it would work well. Perhaps put it on the other side. The dropouts are the heart of these bikes and there is great peace of mind from having massively over-designed torque reinforcement.
I've seen that one before, and do like the design. However I'm running low on funds, and with the steel dropouts on my Actionbent I'm thinking one should be enough. (Am I wrong?) - Also - with the plastic connector on the left side of the 9C motor - does it come off to slide a torque arm onto the axle?
The pivot point on the one I have is locked rather tightly with a large bolt and nylock nut.
corkscrew
Postby chvidgov.bc.ca » Tue May 17, 2011 4:36 pm
Yes the little black plastic thingy around the wire entry to axle point does come apart easily, and can be snapped back together by hand. You could have to remove your Andersons though and/or your Hall connector to get it through the torque arm hole. Which isn't necessarily a bad thing as you would then have to solder up those connections (the Halls) which removes a point of failure if any of those pins in the connector went down or corroded. I think the Andersons from the phase wires would go through, one at a time. The peace of mind is definitely worth 15 lattes! I'm glad to see that your build is nearing completion. Its going to be awesome. I suppose it depends on how much peak power you are anticipating. Anything over 1000 watts I think I would put on a couple of torque arms.
Chris.
chvidgov.bc.ca
Postby recumpence » Tue May 17, 2011 4:56 pm
Nice clean install. I like it. :)
I am glad to see more tadpoles on the forum lately. They are truly a crossover between light weight EV and bicycle.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby corkscrew » Tue May 17, 2011 5:36 pm
chvidgov.bc.ca wrote:Yes the little black plastic thingy around the wire entry to axle point does come apart easily, and can be snapped back together by hand. You could have to remove your Andersons though and/or your Hall connector to get it through the torque arm hole. Which isn't necessarily a bad thing as you would then have to solder up those connections (the Halls) which removes a point of failure if any of those pins in the connector went down or corroded. I think the Andersons from the phase wires would go through, one at a time. The peace of mind is definitely worth 15 lattes! I'm glad to see that your build is nearing completion. Its going to be awesome. I suppose it depends on how much peak power you are anticipating. Anything over 1000 watts I think I would put on a couple of torque arms.
Chris.
Makes sense. I'll order an amped bikes torque arm for the other side (or maybe for the right side, and the e-bike kit one on the other side. We'll see. The ebikes.ca simulator shows my setup peaking around 1200 watts, so I'm just barely over the 1000 watt limit lol. My OCD side sorta wanted to replace the black andersons with color coded ones for the phase wires anyway... For that matter - I sort of want to replace the wiring going into the motor, I mean, what is that, 14 or 16 gauge? :|
@Recumpence - Thank you sir! That's an honor coming from an internet legend such as yourself. :) I have covers for the sides that cover just the box - figure those will work for now, and I'll have different covers made that match the lines of my seat better once I find the material and money. Might also make one a "winter" set - with more insulation, and a "summer" set, with ventilation holes and maybe some computer fans.
I have to agree on the trike thing though - it's the closest pedal powered vehicle that I have to a car.
corkscrew
Postby hekdude » Tue May 17, 2011 5:39 pm
Maybe you can flip it like the attached picture. It will be pushing, not pulling on the arm, but at least it is going in a better alignment. The ampedbikes torque arm you can rotate 180 degrees so you can position it for the best alignment. I did have to take apart the wiring connector since it had clearance issues with the derailleur.
I have electrified my catrike and use it for a 20 mile commute. I have speed issues with the 20" wheel, with an ampedbikes 36V lithium battery, and am dreaming about increasing my speed via extra voltage. You shouldn't be having those problems.
When I lived in Michigan, I ended up having rust issues after riding my bike in the snow/salt. (I had an EZ-Tad with a steel frame) Something to think about. In Southern California I don't have to worry about that any more.
hekdude
Postby hekdude » Tue May 17, 2011 6:01 pm
Here is how I mounted my thumb throttle. There is a little interference with the brake and the throttle mount. I need to keep my brakes adjusted properly. I also can't see the battery level, but with the small wheels, I am not drawing a lot of power.
hekdude
Postby chvidgov.bc.ca » Tue May 17, 2011 6:08 pm
I'm a bit sceptical of that. I think it is best oriented the way it presently is (matching design of the arm). If reversed, the end of the arm, while pushing into the frame, your way, would have a very small contact point with the frame and could maybe slip a bit "around" the frame, inside the pipe clamp, especially if there is rubber in there to prevent frame scratching. As it presently is, the arm is pulling the wheel against the main counter-torque, as designed, not being pushed into the frame. I suppose as it presently is, the pivot point could pull the clamp along the stay a bit or there would be a force vector operating that way, toward the axle, although as the pivot point moves up, it should tend to tighten the clamps hold on the stay simultaneously, as the angle on the arm changes as well. You wont' have this debate with the amped bikes one.
Actually, the clamp wouldn't tighten up at all after I look again at it. So that part of thinking is not right.
chvidgov.bc.ca
Postby corkscrew » Wed May 18, 2011 12:20 pm
hekdude wrote:Maybe you can flip it like the attached picture. It will be pushing, not pulling on the arm, but at least it is going in a better alignment. The ampedbikes torque arm you can rotate 180 degrees so you can position it for the best alignment. I did have to take apart the wiring connector since it had clearance issues with the derailleur.
I'm more concerned about torque issues than speed with the 2806 motor and 700c wheel @ about 48ish volts of LIPO. :)
On the rust issues - I'll be giving this trike a good coat of wax before I complete it (if not a new powdercoat - I HATE red bikes, but the price is always right!) The winters here in Boise ID are fairly mild, and the they use sand, not salt for icy days.
Considering the Torque arms - does the axle really end up spinning backward from the forward direction of the bike, or is that only during regen? Also - on the ebike kit one - that is not a pivot point once it is tightened properly. So it might make for a funky curve, but with that thick bolt and nylock nut, it's not going to pivot separately from the second arm.
corkscrew
Postby Gordo » Wed May 18, 2011 5:14 pm
corkscrew wrote:Considering the Torque arms - does the axle really end up spinning backward from the forward direction of the bike, or is that only during regen?
Yes, the old elementary school physics still holds. For every action there is an equal and opposite reaction. From the right-hand sided of the bike, wheel turns clockwise, force on the axle is counterclockwise. Under regen the axle force is clockwise.
Gordo
Postby corkscrew » Thu May 19, 2011 9:56 am
Makes sense. I will play with it later, in fact, would the alloy rack I have installed make a good place to secure the p-clamp on the torque arm? Otherwise I might flip it like shown above.
Fiddled around with cleaning up my wiring harnesses last night. Reduced the length of all the wires, and bumped it up from 12ga to 10ga wire. Also added some strips of adhesive backed foam padding (meant for HVAC work) under the batteries, and behind. Just need to order some shrink wrap sheets for the packs now.
In other news, my replacement 1420I charger is due in the mail today. :D
corkscrew
Postby corkscrew » Sat May 21, 2011 2:25 pm
Any better?
I'm shortening the motor wires, and moved the torque arm to the NDS of the trike. Thinking it will work for now and Ill look into making some torque plates.
corkscrew
Postby corkscrew » Mon May 23, 2011 10:46 am
Just a quick update. :)
Spent most of Saturday working on the trike. Shortened the motor and controller wires - color coded the andersons on the motor phase wires. Made the wiring harness to connect the batteries to the 100amp circuit breaker. Also used some epoxy to mount some panel mount andersons to take the power to the controller, and across to the other box that houses the 48-->12v DC DC converter. Then in bicycle news - I have the new chainline/with chain tubes mocked up and 3 new 8 speed SRAM chains installed.
On the circuit breaker - The two sides of batteries are unfused before they are serially connected. The 100amp circuit breaker stands between them and everything else. Should I bother putting some MAXI fuses on the individual two sets of four batteries? The output from the DC-DC converter will have an automotive style fuse box on it eventually.
Hoping to take the boxes down to my buddies shop today. Want to get the box covers mounted (since my battery shrink wrap is due to arrive today), and a new plate to mount the controller made. Hoping to get a tube welded to the controller plate to mount my Cycle Analyst too for a nice centered position. We shall see how it goes.
corkscrew
PreviousNext
Who is online
Users browsing this forum: Beagle123, Chalo, Miles, patrix, Tommy L and 18 guests
