Planky
I have an ordinary bike that I put in a hub motor from Alien Ocean. It is only a 250W and struggles a bit on hills. Though has helped me to start cycling to work again, a roughly 20 mile round trip on a cycle track, it is nice to know after a 12 hour shift that I don't have to peddle too hard to get home!
But I now have caught the electric power bug.
So I bought a second hand KMX X Class with the intention of powering it with a more powerful electric motor. I am looking to a maximum of 25 to 35 mph but also the ability to climb a 10% hill with ease.
I wanted to have a motor that drove through the gears so that it could go uphill as well as fast. Some sort of mid drive that allowed the motor to run without turning the peddles and allowed you to peddle without turning the motor. I found a site with cyclone motors on that looked like they would do the job.
Then I discovered this excellent forum and all the helpful people here.
After reading lots of threads here I think I am leaning towards a brushless hub motor again because of low noise, simplicity, "stealth", and I did not know that such powerful ones were available.
I have some requests for help and advice from you knowledgeable people.
1. I have set the steering on the KMX to the factory settings of 2mm toe in measured at 20cm from the ground. I find the steering to be very twitchy and sensitive. Is there a better setting or is it because I have not had a tadpole trike before and am not used to the steering?
2. I think that I will buy a Crystalyte HS3540 for the rear but don't know which controller to use. I want a hand throttle and the ability to run from 36 to 72 volts (LiPo) to give flexibility, I don't want to have to peddle for the motor to run.
3. I am in the UK so I would like to source the parts locally to avoid import duty, any suppliers you would recommend?
Many Thanks
Edit: Added Trike to the Title - Thanks Gordo!
Many Thanks
