by dogman » Fri May 27, 2011 6:10 am
I agree, the cost of the panels is what makes other ways of spending money to be green a better way to go. For example, change to led light bulbs, get a more efficient fridge, insulate, or more efficient AC or Heater for the house.
But again, if you have other reasons to desire solar energy that make the setup make economic or practical sense, then the tiny bit you use on the bike won't hurt. I'm thinking of course, of places where there is no power, or you'd have to listen to generators running to have some.
Nothing at all wrong with going grid tie, if you are going big. I'd only want to be off grid with a very small size PV setup.
Personally I'm getting tempted to set up an off grid 200W panel. Then run my TV on the lead acid battery bank. Stupidly expensive per KWH, but I get a back up power plug for those too frequent outages without dragging out the generator from the garage. At least the TV will still work during outages, as well as a charger for batteries. It would get me more power daily than I'll ever use on the bike, thus making the claim possible that my ebike fleet is completely carbon neutral. So what if I still plug the bike into the grid, if I took the TV off it? What matters is that I'm using that much less grid power, not that I actually plug the bike into the actual solar panel.
Soon as the house payment is gone, I want to power the whole house 80% solar. With grid tie. About 7 years from now.
Ya posted while I typed my post. Cool setup on the roof of the school. I'm fuzzy on one thing though, does the pole you plug into ever cut the amps when you are charged? or does it just keep feeding 42v at whatever amps the panel is producing at the moment? I thought that kind of trickle charging once charged was bad for lithium, so that is why the chargers either shut off entirely, or in the case of lead acid chargers, cut the amps to near zero.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
