Ebike Project 72V HS3540 UK "build thread" +Videos!
Re: Ebike Project 72V HS3540 UK "build thread"
Postby pchen92 » Wed Apr 25, 2012 8:47 am
Did you modify the charger so it can charge your lipo up to 4,15V/cell ? Or do you use it @ 83,6V ?
Thanks
pchen92
Postby rui_fujino » Wed Apr 25, 2012 9:03 am
pchen92 wrote:Did you modify the charger so it can charge your lipo up to 4,15V/cell ? Or do you use it @ 83,6V ?
Thanks
I didnt make any modification so yes they are just charge to 83.6v...but in case your wondering about the individual cell then I've got battery medics to balance them while bulk charging :wink:
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby pchen92 » Wed Apr 25, 2012 11:39 am
And you plug the battery medic everytime you use the batteries ? ie when charging and discharging them ?
How many of them are you using ? 4 ?
What's your range ?
thanks
pchen92
Postby rui_fujino » Wed Apr 25, 2012 11:45 am
pchen92 wrote:And you plug the battery medic everytime you use the batteries ? ie when charging and discharging them ?
What's your range ?
thanks
yea i use them once in few charges not all the time. ( I've never discharged my batteries lol)
yea i've got 4 of them so that i use one per 5s2p.
I've got 10Ah but I use only 8Ah, since I pedal quite alot and I dont go WOT so i get range of about 20~30miles
rui_fujino
Postby pchen92 » Wed Apr 25, 2012 11:55 am
Ok thanks you. I'm gonna make a Giant DH Team w/ HS3540 @ 74V 45A (max but in town I'll set it to 25-30A) w/ 20S2P of lipo on a 24" wheel.
pchen92
Postby rui_fujino » Wed May 02, 2012 7:24 pm
got little update today! I've finally decided to upgrade my rear disc brake to 185mm! it feels so much better! :twisted:
185mm Avid G2CS
also since I had taken out the rear wheel off I've decided to clean it :wink: So far, my speedometer tells me I've done + 500miles and no problem!
I was worried about the Nord-lock and my cheap torque arms but they are holding on well. No damage on both axle and drop-out :D
also, I had little more time so I've taken picture of all the things I have as a spare...quite a lot lol i believe 2 spare motors, 3x BMS bulk chargers (dead), 3 controllers and 52v lifepo4 battery...etc :p
my junk yard
Oh, also I finally decided to weigh my bike! and OMG! it weighs like 35kg! :shock: heavier than i thought...
I've been thinking of upgrading my headlight soon and I want to use CA to provide the power to it....anyone got good cheap idea which are as good as Cycle Lumenator?
rui_fujino
Postby rui_fujino » Wed May 09, 2012 6:23 pm
little update here.
Good news is that BMSbattery guys are sending me a new 600w alloy shell for free :twisted: But no double it'll blow up soon...
Bad news...I believe my new 185mm Avid G2CS is little warped and cant quite get it right... :roll:
oh and i've fixed on/off master switch to FalconEV bag which is great!
rui_fujino
Postby rui_fujino » Fri May 18, 2012 9:02 pm
I've made more upgrades in last few days.
I've upgraded to Doc's torque arm on one side and I've glued my original torque arms together to make one thicker torque arm to apply on the opposite side of the drop out. (I didn’t like the Doc's torque arm with derailleur since I wasn’t sure if it works well with my setup.)
I've also programmed my controller to do regen so i'll inform you guys with how much regen i got from fully charged battery!
i'll upload some more pics tomorrow with all my setups. I've decided to power my headlight from the CA so got few things from china coming sooN!
(216.37 KiB) Downloaded 5 times
rui_fujino
Postby rui_fujino » Mon May 21, 2012 7:28 pm
little more updates.
I have been meaning to add the light switch and horn/controller switch to the handle bar but the one I got from ebay came with side signal switch which looked useless for me so i've customised it to look like this!
the original (replaced horn button to On/Off switch)
customised switch
I've replaced the signal switch to 3way switch which allows me to change the power setting of the controller from 30%, 60% and 100% (I've been using it with 30% 100%120% but I've realised I dont really need to use 120% at all...)
Some point this week, My 12~94v ebay light will arrive so hopefully I'll be able to attach the light switch to this as well! :mrgreen:
PS: since i've added regen setting on, I hardly need to use brake! I guess i didnt really needed to upgrade the rear disc brake...lol It does feel great having regen on tho, so far, I'm getting about 5% of battery back! i'll update all the stats when my battery is empty! :wink:
rui_fujino
Postby rui_fujino » Fri May 25, 2012 7:51 pm
My ebay headlight has arrived :mrgreen: I've tested with 52v and OMG :!: they are sooo bright :shock:
the light i've got can take upto 90v so i'm planning to feed it with my CA so keep the wires looking neat
I'll have to come up with good mount but it's looking very good!
Also I've bought ebay VDR and hoping to get some London riding videos going soon!
disassembled light
rui_fujino
Postby rui_fujino » Tue May 29, 2012 8:08 pm
okay, I've been riding it around at night time and the light works like a charm! :mrgreen:
So here is what i've done.
I've soldered wires into CA to get battery voltage straight into the end of light wires. (this made my handlebar looks neater than wires going back and forward)
Inside CA
oh, does anyone know what does that yellow wire do? it was like that when I opened it....
I had to shorten alot of wire from the light since the original cable was very long....
I've connected the light to the light switch so I can turn on and off the light with my left hand :wink:
switch and the mount
Here are some night photos!
its hard to tell whether its bright or not but I have no trouble cycling at 30mph with this light
garden
rui_fujino
Postby rui_fujino » Fri Jun 22, 2012 7:50 pm
I've got my first few videos of my rides but the quality is not very good and I haven’t done much video editing before :? anyone got good advice on software and camera?
Here is a good picture of London this week and upgrade i've made on the handlebar
London
This is good grip from ebay!
rui_fujino
Postby rui_fujino » Wed Sep 05, 2012 7:13 pm
Not really big update since but my rear wheel got slow puncture recently nd proved me that specialized anti-puncture tire are not very puncture proof...tho the puncture was done by an inch long sharp thorn :cry: its never easy replacing a new inner tube with heavy hub with tight torque plates
I did replace it with a new self repairing tube :D
rui_fujino
Postby rui_fujino » Sun Sep 16, 2012 2:32 pm
Couple news, I hated my fullface helmet so got new one!
MET parachute
This helmet is so awesome :mrgreen: very light(560g?) and comfortable!
I got it for 85 quid on ebay :wink:
Also since I've been trying to make some videos of my rides I got this action cam.
RD32II
I should now be able to take 60fps videos in good quality (I had one other cheap action cam but it was so poor that I decided not to post it)
rui_fujino
Postby Trackman417 » Sun Sep 16, 2012 5:11 pm
Nice updates mate!
Looking forward to seeing some videos of your bike in action. Have you opened up your motor at all to see how crispy the windings are? I've been running my bike at about the same power as you, and my motor still has some nice looking windings! Maybe you should check it out and see if your running your motor into the ground or not, like I did :D .
Nice helmet btw. I got a full motocross helmet for $100. Which is probably right around 80 some odd quid.
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Postby vodk1c3 » Mon Sep 17, 2012 1:09 am
Very nice build, and thanks alot for posting so much info it help me choose my gear for my next bike!!!
Good luck with your next charger ;)
EDIT : No question about charger anymore, I made my order!
First bike (Nitro XT) :
Vpower 1000w 48v 26" rear kit
Vpower LiFePo4 48v 12a battery / 5a charger
20km+@35km/h | 45km/h max speed
Second bike (Everything working, snow is fun ^^) :
Crystalyte HS3540 24" rear
25s1p 5000mah LiPo @ 100v / iMaxb6 charger / Hua tong 72v 35a instant start controller
65+ km/h and lot of torque; battery sag alot; http://www.youtube.com/watch?v=nqf8drRaj9k
Currently working on my first high power build with DH frame / A123 pouch
vodk1c3
Postby rui_fujino » Sat Sep 29, 2012 9:13 pm
Trackman417 wrote:Nice updates mate!
i've got my camera yesterday so I'll charge it up nd get nice video some point soon!
I havent taken my motor apart yet tho I dont wot for more than 10min plus UK is very cold all the time :wink: But i'll definitely take a look at my motor soon!
vodk1c3 wrote:Very nice build, and thanks alot for posting so much info it help me choose my gear for my next bike!!!
good to know my posts can help! I've actually fixed one of my charger so now i've got one spare :D
good luck with your build!
rui_fujino
Postby marcos7007 » Sun Oct 14, 2012 9:39 am
tks a lot for post. So, a conhismotor, can really hold up 72volts?
I was afraid to use 2 x 7S in serie. lol
Did you think in do holes in the motor to decrease the temperature?
marcos7007
100 µW
100 µW
Postby rui_fujino » Sun Oct 14, 2012 9:51 am
marcos7007 wrote:tks a lot for post. So, a conhismotor, can really hold up 72volts?
Conhismotor is well capable of pushing 72v but UK's average temp is like 15c so motor don't get too hot...
14s should be perfectly fine without drilling the holes but if you go beyond 18s I would drill vent holes :wink:
rui_fujino
Re: Ebike Project 72V HS3540 UK "build thread" Video*
Postby rui_fujino » Mon Oct 15, 2012 7:57 pm
Here is my first Video!!! :shock:
It took me a LOOONG time to make it (film) but finally I've got the right camera (RD32II) and got it working!
Enjoy!
Edit New Video coming soon!
rui_fujino
Postby rui_fujino » Sun Oct 28, 2012 9:04 pm
New Video From London!
The accident was VERY close call but managed just scuff my front wheel and no damage at all :wink:
Last edited by rui_fujino on Mon Oct 29, 2012 9:48 am, edited 2 times in total. View post history.
rui_fujino
Postby whereswally606 » Mon Oct 29, 2012 6:56 am
I think you were lucky there. That driver had indicated properly in time for the corner and you were on the pavement. The fact that they did not try to get you details for that is probably because you didn't stop around to give them the chance.
Also you tend to ride over the pelican crossings when people are on them, and only just after they are out of your way. Cars can do this and I don't know if you shouldn't be more careful. The last thing we need to do is alienate the general public by driving to close to them on something which has the power of a 50cc scooter.
Really like your build threads btw but don't want to see you getting arrested.
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby rui_fujino » Mon Oct 29, 2012 8:50 am
whereswally606 wrote:I think you were lucky there. That driver had indicated properly in time for the corner and you were on the pavement. The fact that they did not try to get you details for that is probably because you didn't stop around to give them the chance.
yes, I agree that was partly my fault as well but don't forget that video is slowed down to half the Speed. also I was travelling at average cyclist speed at the time. Given that I think he could have slowed down before the turn as well. I'll upload the real time video later. Nevertheless I was lucky then :)
I don't ride it like this all the time, it was due to massive traffic on the road :wink:
Last edited by rui_fujino on Mon Oct 29, 2012 8:52 am, edited 1 time in total. View post history.
rui_fujino
Postby kentlim26 » Tue Nov 06, 2012 2:41 pm
my greentime charger Look like yours !. It Blew from the Plugs to the controller fuses, I have replace them many times until all had BLEW up again. they are Indeed a rubbish product. SURE 100% blew, so My guess from the same manufacturer Look like alloy could be in very high possible danger to getting it blew very soon or in no time. My vpower charger 48v is still good since 2years ago I have been using it. There is a product Name BC168 in ebay, had been used by many es members I think they are not bad. however I have already order One charger from Hobby king to charge 5cells 10amps, maybe I will parallel them to 20amps. my Imax Bc is not bad, still working from the first day I used. about the Bc 168 charger is capable to charge them individually and balance all, or say 90v all in One go.
ken
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby rui_fujino » Tue Nov 06, 2012 6:52 pm
kentlim26 wrote:my greentime charger Look like yours !. It Blew from the Plugs to the controller fuses, I have replace them many times until all had BLEW up again. they are Indeed a rubbish product. SURE 100% blew, so My guess from the same manufacturer Look like alloy could be in very high possible danger to getting it blew very soon or in no time. My vpower charger 48v is still good since 2years ago I have been using it. There is a product Name BC168 in ebay, had been used by many es members I think they are not bad. however I have already order One charger from Hobby king to charge 5cells 10amps, maybe I will parallel them to 20amps. my Imax Bc is not bad, still working from the first day I used. about the Bc 168 charger is capable to charge them individually and balance all, or say 90v all in One go.
ken
Actually, Since I took them apart and fixed few parts off and on, my Alloyshell 600w chargers are all good :mrgreen: i've got one for spare and one for every week use and it hasn’t let me down for a good year! :pancake:
rui_fujino
PreviousNext
Who is online
Users browsing this forum: Bing [Bot], capo and 7 guests
