There's a new sheriff in town (new pics on p5)
Re: There's a new sheriff in town (new pics on p5)
Postby John in CR » Fri Aug 26, 2011 3:59 pm
Are the lockouts on DH type forks with easy switching, so the racers can easily lock the fork for better pedaling briefly on level sections, or are the lockouts on rear shocks? It's the front I need to lock.
I do like the double pull lever, though I'd want hydro. I understand the better feel of good mechanical, but all I care about is braking power and low maintenance, so hydro all the way for me, since they adjust themselves and even the cheapies work fine. With regen providing so much of my braking force, I haven't touched my brakes since January, and I do use the brakes on almost every stop or turn. That's bringing 375lbs to a halt from traffic speeds. Before regen brake assist I was replacing pads at least every six weeks, and that was with a big rear drum (no maintenance) helping too.
The only problem now is that I have to change the front disc on my daily rider, and 2 allen wrenches snapped last time I tried to remove it....any suggestions (an AL hub)?
John in CR
Postby FMB42 » Fri Aug 26, 2011 5:23 pm
Try heating the hub up a bit before you attempt to remove the disc allen screws ( you can heat the hub up with a hair dryer/heat gun). Just don't heat it up for too long or get it too hot...
As for the "air or spring" shock debate: I had reservations about air shocks years ago when Fox first started making them for Moto Xers (thought for sure that they'd leak and/or suck). However, I bought a used 80' Husky 390 CR w/Fox airs and they worked out quite well (this was 1984ish). Well, some 25 years later I'm still happy running air shocks (I've got a '06 Manitou on my XC that still holds air far better than I do these days).
Anyway, I'm head over heels on that build of yours.
FMB42
Postby John in CR » Fri Aug 26, 2011 6:03 pm
Thanks FMB,
Yeah, I'm sold on air shocks too. This tiny Fox Float is performing unbelievably. Today I was in a rush and took the washboard + pothole section of our main road leaving the house with abandon after getting hit with a couple of big rain drops maybe 10min before I knew for sure real rain was coming. With rain coming any second on the way back from the store I took the sidewalk, curb drops and all when the road I needed to go left on had too much traffic both directions and I couldn't waste even seconds. I needed video of both ways, because it was the most aggressive and fun ebike ride of my 3 year career (not most pleasurable which is reserved for low tide beach riding).
I pushed it too hard though. The F%@#ing controller crapped out turning into my street. :cry: :cry: :evil: Gotta figure out a way to get the glued-in board out, but the symptoms aren't typical with no big heat in the housing and no short in the phases, so hopefully something small. If I can get it apart I have 30 real 4110's itching to climb aboard, and the controller gets ventilation. I have a feeling this one isn't a mosfet failure though. I just hope I can repair it, or repair it locally.
Now my delemma is whether or not to steal the 24 fet controller with proven high power durability and ready to go regen off of my daily rider for the Super V. Let me get on with the other needed mods before deciding, but the answer is obvious since Blue is now uber boring to ride, so a lesser controller is ok.
Luke- HELP! I need to buy one of those super controllers from you. Can we reasonably program the controller from afar? I don't need to push the limits in performance. 400 phase amps will do the trick nicely, especially if I can ramp up current over 0.5-1 sec. :twisted: :twisted: :twisted:
John in CR
Postby etard » Fri Aug 26, 2011 7:39 pm
Impact wrench, electric preferably. I got a Dewalt 18volt impact 6 months ago and that thing drives and snaps frozen bolts and nuts like nobody's biz.
Dh racers never lock anything out, the only reason would be for more efficient pedaling, and I guess the added complexity is not worth it for that tiny little section in each run. I don't believe I have ever seen a dual crown fork with lockout, but there are some sturdy all mountain and dirtjumper forks with adjustable hieght and lockout.
You should get that front scooter brake Thud linked somewhere. I think he used it for his death race bike. Another option could be 2 mechanical disk brakes on the front. My Willow Springs race bike has a dual disk mount hub, I think it's from one of the chopper bike sites.
I will pm you about the shock when I get home John.
etard
Postby John in CR » Fri Aug 26, 2011 7:55 pm
Since the Sheriff is now on vacation, it's time for a new sheriff to step in and take over. Since no normal ebike hubmotor can cut the mustard, who's is going to be? Etard with his scooter hubbie, Luke with his 110mph bike, the silent lurker like who took the 2011 Death Race...? Whoever it is don't take too much time, because I do have other controllers and 2wd on my mind, so the vacation won't be long. 8)
John in CR
Postby Harold in CR » Fri Aug 26, 2011 8:14 pm
RE;Stuck bolts. Using the hair dryer might work, but, after getting things hot as possible, I would squirt some liquid wrench type release agent on and at the area where the bolt heads or washers are. You probably have corrosion, and, if you try to turn the bolt out very far, you stand a good chance of stripping the threads in the Aluminum.
After a couple times with the juice, try an electric hammer drill. It's not as aggressive as a regular impact tool. Just get the bolts to turn, then liquid then tighten a little, and repeat. This is from many years of working on Aluminum Outboard motors in Salt climate.
Thanks to Justin, the forum is open source and NON-commercialized.
http://www.costaricacraftwood.com
Harold in CR
Postby Arlo1 » Fri Aug 26, 2011 8:50 pm
Yup heat is your friend if you have a steal bolt in aluminum you heat them both but the aluminum has a greater thermal expansion rate so it will losen on the bolt as it gets hotter! I have unseized 10s of thousands of bolts in aluminum (motorcycle mechanic) and heat is my best trick the second best is welding a nut to a broken bolt the weld will shrink and pull the bolt loose and the heat will help it come out as well! Third best is the outer bearing race trick when you weld all the way around inside the outter bearing race then the weld shrinks as it cools and the race just falls out! Ok enough rambling!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUFF Incl. Mosfets, Current sensors and Nomex paper.
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
Arlo1
Postby mat h physics » Fri Aug 26, 2011 9:44 pm
I agree w/ Harold, an impact wrench has a great chance of popping the head off. Have some doubt about pen lube though.
Arlo, is on the right track w/ heat.
Try my father's trick, he serviced the equipment at auto shops and service stations. Strike the head of the bolt to loosen it. Use a brass rod to help prevent deformation, esp on socket head cap screws. On a socket head cap, you can use a broken allen wrench. USE SAFETY GOGGLES, AS HAMMER AND WRENCH ARE HARDENED AND CAN SHEAR SENDING HIGH ENERGY SHRAPNEL :shock: Known more than one person to lose an eye striking a chisel w/o eye protection, and even embedded under skin from 20+ ft away.
If that fails, put the hub in the freezer to reduce the bolt temp. Using a lite torch or heat gun, heat the aluminum (I seriously doubt a hairdryer will work, not enough heat diff). A good soldier gun may even work for better control on small surface.
Should you have to resize the hole, don't drill a hardened brake rotor it will shatter the bit.
Specialized Hardrock, still conventional.
Schwinn Avenue, still conventional.
mat h physics
Postby John in CR » Sat Aug 27, 2011 3:17 am
Thanks guys. Hopefully heat does the trick, because these little brake disc bolts are way too small for impact wrenches, striking, and welding. Plus I don't have a freezer that will fit a 24" bike wheel.
John in CR
Postby The Mighty Volt » Sat Aug 27, 2011 7:33 am
@JohnCr or LiveforPhysics.....how many watts are you guys seeing on these motors with the 20" or so wheel?? I am only seeing 2800w or so with an X5305 at 72v, how about yourselves??
The Mighty Volt
Postby mat h physics » Sat Aug 27, 2011 8:26 am
Seriously John, take a good hammer and whack the bolt head a time or two. The vibration helps separate the surfaces. W/ the rotor in place it will be ridged enough to w/stand the impact. Just don't deform the hex hole, hence the broken allen wrench suggestion.
Pen oil won't hurt, but aluminum is soft and will "seal" off any fluid. Steel on steel has a natural molecular "fracture" to help pen.
If you have access to dry ice, it will help. Or find a friend w/ a chest freezer.
When turning the wrench, support the back side (right) to keep the forces in the rotational axis. Using rt hand, support the vertical hex shaft w/ the thumb to the right side pulling the wrench w/ the pinky, ring, index force in that order. Improper alignment of the forces maybe why you broke the wrenches in the 1st place.
Breaking a frozen bolt loose can be a real art form.
mat h physics
Postby Arlo1 » Sat Aug 27, 2011 8:59 am
Yes one thing I forgot to mention shocking the bolt will help tremendously so if you smack it with a hammer it will usually loosen it that's a big reason why impact drivers work so well.
Arlo1
Postby hillzofvalp » Sat Aug 27, 2011 11:25 pm
I don't know what you guys are talking about precisely, but here's something I tried recently on a caliper bolt that was torqued down too much:
get a thin cut dremel wheel and cut a notch for a flat head screw driver.. not too thick. The point of the slot is to have a good surface to impact. If you impact an stuck hex bolt then you can very quickly strip it out..
THEN: impactor + flat head bit. Got to make sure though that the flat head is snug and you press with just the right amount of force or you'll strip out the nice slot you made Basically saved my $300 fork
hillzofvalp
Postby LI-ghtcycle » Sun Aug 28, 2011 11:13 am
Wow, great project you have going here! :shock: :D :twisted:
Now if I could just figure out a way to make something like that legal in the US ... :roll: :mrgreen:
Great work John, look forward to seeing it in action, and stats from the drag strip! 8)
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby The Mighty Volt » Thu Sep 01, 2011 9:24 am
I just took delivery of 1 of these 1500W rated moped hubs and a rather shoddy looking 48v controller with IRF1407 Mosfets. I will try to take apart the controller and run its guts past people in the know.
Unfortunately, the delivery people may have dropped the box at some stage, as the motor rim has some damage to it.
I will try to get a photo up soon.
EDIT: Not my own photo, but this is the motor in question.
The Mighty Volt
Postby John in CR » Thu Sep 01, 2011 12:02 pm
Mighty Volt,
Excellent. Run the factory controller in stock form before modding it for higher power, so you can get a baseline performance. Be sure to include actively ventilating it in your mods. That should enable you up to fun levels, though not eye popping with those fets. 60V nominal if the caps are up to it, and double the current by coppering half the shunt length should be fun. I can't wait to see how you use it.
After blowing SuperV's big controller I was forced to do an inventory of blown controllers and find one I thought I could repair myself to put on my cargo bike, freeing up that 24fet4100 brick to install on SuperV. Heat damage, other than blown fets accounted for almost half of the failures, and 3 out of 5 of the modded factory controllers. Mostly it was melted phase wires that either shorted to each other or to caps. From now on I will ventilate any controller I take to higher power, including my one remaining 24fet that I'm going to dial up to 150A battery side in gradual increments.
Blown controllers has been the achilles heel of just about everyone's high power pursuits, but the only ventilated controller I've blown was my last remaining factory controller that I was pushing past triple the factory settings, and that occurred on the first hill I encountered after forgetting to turn the fan on. Ventilation works well, and we've been pushing a 4310 based controller at 80A for months as proof, though we really should get in there and beef up the primary wires and traces to minimize unnecessary heat, since the air blowing out of that controller is quite warm.
I successfully repaired one of my factory controllers, YAY, so I'm moving it to my daily rider which isn't fun anymore thanks to the Sheriff. It's will still get 5kw via the new and improved ventilated stock controllers. The 24fet will get dual blowers, doubled up wiring, and thickened traces. It's been dependable at 100A, so with mods, 150A should be no problemo.
I'll do a post soon about ventilated controllers.
John
John in CR
Postby The Mighty Volt » Thu Sep 01, 2011 12:11 pm
John in CR wrote:Mighty Volt,
John
Thanks John.
Because the controller came with no throttle, I hooked up a 24v Ananda controller to it and immediately encountered some grinding action. The motor was drawing 15A under no load.
I test the motor with Lyens controller and there appeared to be no phase or hall issues.
Could it be that the motor will only work with the stock controller?
Unfortunately the stock controller has only a few components I can recognize, 3 phase wires, 2 power wires and the halls/throttles.
Can I put a big enough tyre on this motor to make sure it comes out at around the same circumference as a 20" BMX front wheel?
Thanks again for your support and encouragement. Ultimately I want to run this baby at 72v.
The Mighty Volt
Postby John in CR » Thu Sep 01, 2011 12:47 pm
Grinding action, just wrong wiring combo I hope. Until you are certain about correct wiring, only try small throttle pulses.
Does the axle turn with grinding, or only cogging resistance?
Don't you have a working ebike to just borrow the throttle from?
How are you doing a run test, clamping axle flats in a vise with some flat stock protecting the axle from the vise's teeth? Be careful, it ain't no puny ebike motor.
Tires, I would think so, but I'm no expert.
John in CR
Postby The Mighty Volt » Thu Sep 01, 2011 1:28 pm
John in CR wrote:Grinding action, just wrong wiring combo I hope. Until you are certain about correct wiring, only try small throttle pulses.
Hi John, the flat of the axle is to the flat of the vise, the teeth are OK, but I might wrap the axle just in case.
With no controller, just with a part of the axle dropped into a clamp/vise......it spins smoothly and freely by hand, no issues at all, either direction. If I spin it fast enough by hand, I get that reassuring motor "whine" sound.
I do have a working ebike to borrow a throttle from, but I don't use connectors, I always solder my wires together, braid them, solder them, heatshrink them, that way there is no issue with dodgy connections or water getting into them. Salvaging a throttle now would be a PITA, but I could do it, sure.
I might just strip off the Ananda twist-throttle, as long as it is hall-effect, thats fine.
The Mighty Volt
Postby John in CR » Thu Sep 01, 2011 1:59 pm
There are ways to hot wire the throttle wires, but I don't know of an easy one to give you good throttle resolution, and the last thing you want is a barely held motor and hitting it with big chunks of throttle trying to find the correct wiring combo.
I've posted many times the easy way to find the correct wiring, so please don't go the hard route. As long as the phase angle is correct or you have a controller that auto senses the phase angle (your motor tester tells you the phase angle of the motor halls.) Then you prove the motor works within 6 attempts, actually 5 more since you know the current one is incorrect. You'll get a good forward or reverse simply by trying either the other 5 phase combos without changing the halls, or the other 5 hall combos without changing the phases, whichever is easier. Do not change both.
You may not even decide yet which way is forward, since you might want to put the drum brake on the left. I've done it both ways, and the only trick about putting it on the left is that you have to pull the lever the clockwise. At least mine are definitely directional and if you pull the wrong way, yes the brake shoes still engage, but it has very little braking power.
John in CR
Postby The Mighty Volt » Thu Sep 01, 2011 2:48 pm
GOT IT!!!
It actually snaps the unsecured clamp around on the workbench like it was a bit of wood or foam, not like the cast-iron that it is. Not even the 5305 was doing that at 72v.
Damn it is torquey on just 55v!!!!!!
Like a Lyen, it has a red wire which needs wiring to the controller positive.
My cheapo pedelec Ananda throttle has a massive flat-spot in the first 1/3rd of the twist...then bang.
Incredible wallop and RPM on just 55v.
I got the motor and controller for around $250, all in.
Now as soon as i can I will upload some photos for identification of the remaining controller terminals.
The Mighty Volt
Postby John in CR » Thu Sep 01, 2011 3:44 pm
The Mighty Volt wrote:Like a Lyen, it has a red wire which needs wiring to the controller positive.
After routing it up and back thru a keyswitch within easy reach while riding.
Glad to hear everything works. Now you too can laugh at X5's, but at less than half the price. We expect to see some videos of you tearing it up in Ireland. Showing off the capabilities of a high power ebike is one of the best things we can do to forward the cause, and as long as we're extra courteous to cars and peds there's no downside. :mrgreen:
John in CR
Postby The Mighty Volt » Thu Sep 01, 2011 4:46 pm
COurteous ? :D
When I am on the trails on an X5305 BMX, the people on horses take pity on me, and offer to let me pass.
I accept their invitation, and promptly disappear up a hill at a rate of knots.
Have to say that there are controllers, and there are controllers.
At 55v, and just jerking the throttle, the controller does seem to be a bit warm
I'm not sure the stock controller is worth a damn, and I would LURVE to see this motor at 72v on 4110 Fet's
What sort of motors are these anyways? What sort of windings do they have, do they burn out controllers at high-Amps or are they kind like a 5305??
The Mighty Volt
Postby Harold in CR » Thu Sep 01, 2011 5:42 pm
$250.00 all in, EH ??? That include shipping and other Govt fees ??? Is yours the 72V model ??
Looks like I need to sell some more wood. :roll: :lol: :lol: :lol:
Harold in CR
Postby The Mighty Volt » Thu Sep 01, 2011 6:35 pm
Harold in CR wrote:$250.00 all in, EH ??? That include shipping and other Govt fees ??? Is yours the 72V model ??
No Government fees, as it was England to Ireland.
Shipping was a cheapo $25 2 day DHL special.
Needless to say they dropped it and now there is a flat-spot on the rim which we need to get out, we think we can, without too much effort.
The Hub was advertised as a 48v 1500w model, so it's not the super powerful version like JohninCr's, but at 55v it is demonstrating some pretty sick power.
I got the motor and controller off a guy who seems to have some left-overs, replacements or something and is selling them off.
Price does seem to be a bit low to be true but I got mine and hooked it up and away I went, eventually.
My brother is the fabrication king, he will have a look at it tomorrow and decide where we go. with it.
The Mighty Volt
PreviousNext
Who is online
Users browsing this forum: Deadmul3, Hero_004, Ian, ilovehotshot, pjgold, sacko and 12 guests
