I don't know what's wrong with Hubmonster's factory controller. I thought I could get away with doubling the current with a 200lb lighter vehicle and the controller much more exposed to the wind, but it couldn't handle it and I wasn't even riding it near max performance.
Everyone seems to have trouble once you cross the 100A barrier, and further evidence is the Chinese going to monster size motors so they don't have to cross it. Arlo1 has had the best luck pushing them well beyond that, but that's with an X5304 which is a far easier load. I have an X5304 that was running fairly conservatively, and I took the controller off of it to run on one of my main hubbies in a 20". It took off way stronger than the X5 was running, but the controller blew the first time I gave it full throttle, a result that still baffles me.
The Sevcon's Luke has for brushless are apparently up to the task, but the setup is a mountain I don't have the tools to cross.
I've had luck with my Lyen 24fet 4110 controller...realiable since Sep of last year, but I did tone the settings down to 80A after running at 110A for a little while to make sure it stayed reliable. I beefed up the traces, doubled up the 10ga phase wires, and halved the shunt resistance to double the regen current. I was planning to add to blowers to bring in fresh air and keep the insides cool as well as almost double the surface area for FET cooling, all with plans to run Hubmonster with it, but now I need to put it back on my daily rider since I'm out of controllers. Blue is down for a quick overhaul (better batts, new wiring harness and bearings, and some beautification) while we're in the meat of rainy season, but I'll keep it conservative until I get another bike going.
I thought I was done with controller problems after learning hard lessons about current limiting, partial throttle, and hills. A year of zero problems really spoiled me, but now that I'm reaching for more performance controller popping is back and it sucks.
