John in CR wrote:I have no experience with decent bike shocks. Should I go ahead and order replacement rubber parts now...seals, rings, whatever? That Fox Float is like a cloud for me, and my greater mass must counter the effects of all that unsprung weight on the small bumps I've been hitting. The rear seems to take them better than the front, though I avoid big stuff.
John in CR wrote:D Keep in mind I want to retain a hand/arm position where I can push back to counter brake dive, which I really hate. I definitely need to experiment with one of the no-dive type of front suspensions.
MadRhino wrote:...no need to open it until it start losing air.
amberwolf wrote:John in CR wrote:D Keep in mind I want to retain a hand/arm position where I can push back to counter brake dive, which I really hate. I definitely need to experiment with one of the no-dive type of front suspensions.
I wonder...on a fork with a lockout, would it be possible to put a servo activated by the brake lever on there to engage the lockout, and disengage once the lever is released? (or by a separate button on the lever, in case there is a situation like braking during a driveway entrance or speed bump where you don't want the suspension locked out)
Or for pneumatic systems without a lockout, a tank/compresssor and valve system that is activated the same way, so it pressurizes the system to it's max, stiffening it greatly, during braking, and lowering it back to some preset value afterward? (the compressor would kick on every so often to keep the tank above the pressure needed).
John in CR wrote:MadRhino wrote:...no need to open it until it start losing air.
With my big load and the shock pumped to 250psi, would it gradually worsen or can something go all at once? ie Order a set now?
Also, can it run on little to no air on a smooth road or is that sure to cause damage? eg When I go to make a run at the strip, lower will obviously be better, so as long as it won't damage the shock I could bring my pump along to the track and let the air out to make some runs. Then just pump it back up afterward. I guess I could just drop the pressure way down and get the same lowering result without bottoming out the shock. Recommendation?
John in CR wrote:.. It was my understanding that pressure was really to adjust the ride height when loaded, with the goal to put the shock at about half travel when you're on the bike, so the wheel can move up or down for holes or bumps...
Users browsing this forum: docnjoj, gmrviper, neithermovingnorstill, seanrosepdx and 16 guests
