3.2mm dia.
For my rotary charger switch, in the werks.
J
docnjoj wrote:Yes belts are availible. Contact me off line if U desire to sell the motor only!
otherDoc
Dee Jay wrote:I have other news on my 4011 but will save it for another post
pwbset wrote: Talk about leavin' me hangin' there!
docnjoj wrote:Thats some horror story DJ. I tried way back on a WE 409 to pop the covers like that and BANG, I popped the center out of the cover. Seems U gotta remove the screws first!My machinist welder fixed it and its still in use. I dont use wheel pullers on those motors any more, just my machinists 12 ton press and metal support plates for the bearings. Works fine!
otherDoc
So Dee Jay, what's this brilliant idea you've come up with this time?
But Dee Jay, what if you kill a cell? That means you'd have to tear the heat shrink blah blah blah...
Dee Jay wrote:Sometime last autumn, Pack A which was hidden inside the Revive frame tube disconnected at the first cell. I pulled the pack out and I wondered if the frame tube pack idea was worth the trouble. I hadn't touched Pack A until now because I'm short on range. I thought it's time to get crackin' on my swing arm pack using my new enclosures.
The original cells tabs were weak so I decided to tear them out and solder fabbed copper tabs.
The negative tabs were welded really well and was a bit tricky to remove. I was left with sharp bits on the negative that need to be filed down. The positive tabs positive tabs pulled off effortlessly.
I found it odd that, if you remove the cell's paper insulation, that the whole cell body is positive and the negative is just a tiny island separated from the positive by just millimeters apart.
At first I couldn't decide on whether I should hold the pack together with duct tape or glue. I never liked the idea of committing the cells with glue and didn't want to wrap the whole pack with large and expensive heat shrink. What I want is to have the cells accessible (if I ever kill a cell again) and not have to tear into the pack and having to wrap it again with more expensive heat shrink. Duct tape was almost doable if kept to a minimum but it still gets sticky gunk all over the cells that gets stickier in summer heat. Well I shat me a brilliant idea so I brokedown and hopped on the hotglue bandwagon. Yep!
I've never used hotglue before and always wondered what the advantage of it is over using only a tube of silicone sealant. So I buzzed down the hardware store still wondering if I should pay 23 bucks for the hot glue kit or pay 3 bucks for a tube of silicone.. me being a cheap bastard..I asked for a tube of clear silicone. The clerk searched high and low, out of hundreds of sealant, silicone, glue products and he couldn't find one that was clear. I thought it might be God's way of telling me to go for the hot glue kit. And I'm an atheist! Well I was blown away by the convenience of not having to wait forever for it to cure. Instant gratification is so King. Shoot, now I have to find other uses for it to justify owning it... hell, I'm knee deep into this hobby so fuggit...
Earlier, I checked the height of the cell and it fitted nicely in the enclosure but my dumbass didn't bother to see if two cells fit side-by-side. I found that two cells were few a millimeters too wide and the enclosure wouldn't shut flush. So I staggered them and I'm in there like hardware leaving me with just enough space on the sides of the cells for the charging harness. shweetness!So Dee Jay, what's this brilliant idea you've come up with this time?
After pulling Pack A out of the frame tube, I was left with the 1 meter long heat shrink tubing that I used to loosely insulate the pack and
Solid!But Dee Jay, what if you kill a cell? That means you'd have to tear the heat shrink blah blah blah...
Fnck no! I can simply cut the tabs and viola! Slide that sucker out, and slide another one in! Tee hee hee!
~ Tra ~ la ~ la ~ I am the man..![]()
Tuck the boys in bed. Nite-nite.
J
Doctorbass wrote:That's a nice idea Dee Jay for the shrink tube!
now just pay attention to the cell that can have direct contact with your alluminum case!.. these cells can deliver current of 550A when shorted!.. that would garanty you that you could never be able to open up your case dur to perfect weld!!!..
Doc
Dee Jay wrote:Doctorbass wrote:That's a nice idea Dee Jay for the shrink tube!
Doc
Hey, thanks Doctorbass!
Yeah, I'm a bit nervous about a tight metal enclosure. I'll need thin bullet proof sheets for the ends of the cells and then to ensure the cells don't shift back and forth maybe use a tight fitting blocks of wood (or something light weight) to fill the ends of the pack
J
ps: new mix is up, please enjoy!
viewtopic.php?f=1&t=2997&p=133426&sid=6a93eb61e7e86813677e0be92984885c#p133426
Users browsing this forum: No registered users and 11 guests
