Ok, this was the best bolt on hitch I could come up with while on the road. I bought some angle iron, Lowes had a 4 foot section on clearance for $1.50.
I also got a male/female quick connect airhose coupling set so that I could make it quick release. The problem was that the threaded end of the couplers was fairly large, and the thread was different than their largest nut we could find. So I ended up using the actual female/female threaded coupler as the nuts. Was a bit pricey, and bulky, but it was a quick fit.
I cut two pieces off the angle iron as my mounting plates. I figured it would be a little faster to use my angle grinder with a cut off wheel, rather than my sawzall. But I am staying in a hotel so I didn't have a place to grind, or power. So I found a vacant/abandoned car park lot nearby. Drove my transport van over there, pulled out my race generator and made an impromtu machine shop.
I was a little worried about the dry grass when I was grinding. Didn't want to catch it on fire with the sparks. It was bad enough making a bunch of noise, but to burn down the neighborhood on top of that. :lol:
I used a u bolt to attach the female mount bracket to the seat post area.
I figured that I would put the female coupler on the bottom, so that when I pulled back the sleeve it would stay in place. Nothing more frustrating to be trying to push the connection down, while also having to pull the sleeve up. Seems kind of counter productive.
I then added the male connector to the other mount plate.
They do connect together like I had planned.
But the height is slightly higher than I would like, but it is still a definately usable angle.
Another problem that I see is that the plate connecting the handle where I attached the male connector mounting plate is part of the folding part when putting in storage. With the bolts through the handle plate, the cart will not fold down when I need to pack up. I will have to take out the bolts each time I need to put it away. Not a big deal, but I want to make that part better when I get home. I want to grind out the pivot posts and use those points to bolt down the male connector mounting plate. That way the handles can fold with the plate in place. But I don't want to accidently screw it up and not be able to use it as a cart for these next two race weekends. So I will leave it as it is now and just unbolt it the two times I need to pack it up. Then, when I get home and have more time on my hands then I will try to fix it as a permanent deal.
