Is the "Volt-Up, Gear-Down" Theory Justified???
Re: Is the "Volt-Up, Gear-Down" Theory Justified???
Postby wineboyrider » Sat Sep 10, 2011 10:56 pm
A watt is a watt no matter watt. 8)
wineboyrider
Postby The Mighty Volt » Sat Sep 10, 2011 11:02 pm
John in CR wrote:That is correct. The higher the voltage the higher the speed you need to maintain at that throttle position to avoid overheating. If you're looking at sims, then you want cruising to be at or above the point of peak power to be in the band of better efficiency for the motor, and out of currently limiting to make life easier for the controller. Especially with the higher Kv scooter hubbies, you want to avoid partial throttle under heavy loads like big hills, because it's a quick death for controllers unless you can get above the safe point of speed. If you don't maintain that safe speed, partial throttle just chops of the phase pulses even more, which is harder on the controller.
Okay then! Now I know I am not cracking up!!! :lol:
Thats why I asked about the "Volt Up, Gear Down" philosophy.
Clearly the user has to be prepared to match their system with a particular style of riding to avoid damage to the system.
In other words, there is no point in having an X5303 with 72v unless you have the guts to open the taps and hang on in there.
This is news to me. I confess...with my X5305 I like to travel up very steep hills with a partial twist, at 500w or so, watching, as I travel up the hill, the watts rise to around 1500 or so.
But by rights I should be attacking that hill flat out, and letting the motor hit the top speed??
Cheers. 8)
The Mighty Volt
Postby The Mighty Volt » Sat Sep 10, 2011 11:05 pm
wineboyrider wrote:A watt is a watt no matter watt. 8)
It is....but the duration of time for which the system "see's" the higher Watts is critical.
It seems now that this "gently gently" philosophy could be false, especially in the area of steep hills.
The Mighty Volt
Postby dogman » Sun Sep 11, 2011 7:48 am
Re my nit pick. I figure you do know what I was saying, as well as the others posting. I just repeat stuff ad naseum because 90% of the readers don't know, didn't understand another similar post, or are just noobs. Sorry, I do get tedious and clutter up threads. But for every time I repeat myself, ther'es 50 ads that talk about a speed model and a torque model. No such critter. Want more torque, either watt up or gear down ( smaller wheel). Or both hee hee!
Another nit pick though, Somebody mentioned cruising at 72v. But the sim you showed was no cruise. 8.5% grade will never be a cruise. So of course that produced conditions of heating that are waaaay different than a cruise on flatter terrain.
On hills, it's a matter of can the motor radiate the heat fast enough to not overheat. Slower windings help keep the motor from stalling at such a fast speed. Less stalling, less heat. This works fine if you also limit watts somewhat. At some point on a really steep grade, more watts doesn't get enough faster, it just makes more watts avaliable to the heater. The key on a long hill is keeping the heat produced balanced with the heat you can radiate in that days weather, somehow. If you can keep watts really low, and use the motor as just an assist to pedaling, you can slowly climb a long hill with just about any winding. Even if the motor is making 400 out of 500w into heat, it still can keep up with radiating that 400w of heat. The 100w left is sure a lame assist though.
More watts in the form of more volts can keep the motor from stalling as much by speeding up. Your example quite correctly points out the problem with this approach, stalling speed gets faster. This could be part of why my DR motor smoked. The speed up the hill approach does work great on a shorter hill. Anything under 1 mile length, charge it WOT, if you have time for the motor to cool before the next one.
I played with the new sim for awhile this summer. I put it the conditions of all the stuff I have personally tested, and found it quite right on. It seemed to really confirm everything that I saw actually happen. Some of the seat of the pants rules of thumb I've been using to climb hills seem to be confirmed. For example, you mentioned limiting watts to 1500 climbing a big hill. That's just about where I am too. I think in most weather, motors can radiate the heat ok at 100-1500 w. Above that, you start having to look at limiting duration. Cover holes help, but only up to a point. Past a certian wattage, they mainly let the smoke out better.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Postby wineboyrider » Sun Sep 11, 2011 10:31 am
Well put Dogman. That's why I limit my watts to my 9c to around 1200 and I haven't had any problems with it yet. But, my BMC motor has a fried hall wire somewhere, because I was running it a little over 1500w. The winding doesn't help either as it is wound for more efficiency at speed and not climbing....?
wineboyrider
Postby John in CR » Sun Sep 11, 2011 10:43 am
Dogman,
No wonder you continue to melt hubmotors. I've never melted one... not even darkened the color of the varnish on the windings, and 95% of the time I ride a bike with a sealed hubmotor.
After the last debate on this topic, I tried partial throttle on one of my regular climbs. Luckily I stopped to check the motor after just a few hundred yards, because it was much hotter than it gets at WOT on the same climb, and I hadn't even gotten to the steepest segment yet.
Speed is the target not some power level. I could melt my motor at 1000W if I was so inclined, however, if I can maintain 30mph on my primary bike, the motor can handle multi-kilowatts as long as the battery will last regardless of the grade or how much extra weight the bike is carrying. The minimum safe speed at WOT factors in everything but the ambient temperature.
For those playing with the simulator, Justin is still working it, and since it doesn't factor in the fact that cooling is better at higher rpms and higher speed, those overheat times can't be relied upon to make valid comparisons.
John in CR
Postby miniebiker » Sun Sep 11, 2011 10:46 am
miniebiker
Postby John in CR » Sun Sep 11, 2011 11:57 am
miniebiker wrote:I guess this is the answer.
http://www.youtube.com/watch?v=EZ2_sXwdaiw
Variable gearing is definitely better for hills, but only at moderate and lower power can "through the gears" using bicycle components be reasonably reliable.
What we really need is a proper multi-speed geared hubmotor with proper metal gears and cooling system for the smaller motor enclosed. The reasons we don't have them already are:
1. I'm not a mechanical engineer
2. Ebike design is dominated by pedalists
3. Motorcycle companies either don't understand how fun 5-10kw can be with a lightweight silent bike, or they're stuck in the box with a motor driving a chain because that's what they know. At least we have a member inside one plugging for what's really needed and being ignored.
I have no doubt that a 5kw 2 speed actively cooled hub motor is possible in the 5-8kg range, and if I could, I'd build one to prove it.
John in CR
Postby dogman » Sun Sep 11, 2011 4:09 pm
I'd like one of those too I'm sure.
I'm not quite sure what you meant, but every time I ever melted a motor I was definitely riding it WOT up steep hills or racing. My guess is your motor got hot because it slowed into that stalling speed range. The less throttle trick only works when you pedal till you puke keeping the bike traveling fast enough after lowering motor watts. In other words, replace motor watts with equal human watts. No fun, but it can be done. It's a trick for those who use a motor just as an assist.
I think it's quite possible your motor was still making more heat than it could radiate. For the slow down to climb thing to work, you have to lower watts to at least no more than 500-800w. Otherwise the hub can't radiate it as fast as it gets made.
My best bikes so far have been slow winding motors run at 1200-1500w. Slow but steady, and I can climb all I want WOT with few worries. Same motor on 3000w melted fairly quick.
I bet a motor designed to the same speed but built for 5000 w would very quickly become my favorite! It's not that I like low watts, it's just that these bike motors are designed for low watts.
dogman
Postby John in CR » Sun Sep 11, 2011 8:02 pm
The point was that it's not the power you have to watch, but the speed you have to maintain. The race bike meltdown was different, and the repeated accelerations bit you. What you needed there was a second motor.
John in CR
Postby 999zip999 » Sun Sep 11, 2011 9:16 pm
I run 55v (61.3v) I would like to bump it up 72v (82v) on a bmc 600hs and 30amp. crsyt. Will be turn down to 20amps. Tomorrow.
999zip999
Postby The Mighty Volt » Sun Sep 11, 2011 9:19 pm
John in CR wrote:Dogman,
This is what I am talking about!!!
Here is how I look at it.......go for a jog. Notice how you break into a particular stride.
Now try to artificially limit that stride, taking shorter "steps" as you move along.
Notice how tiring and uncomfortable it feels??
Your body is designed to jog at a certain rate, a certain length of stride.
Step it up into a sprint, and you burn out. Reduce it to an exaggerated fast walk.......you cramp up.
That's what I was saying about the speed with the X5303. There is clearly an argument which can be made that letting that sucker rip into a certain speed bracket makes more sense than inching along.
I understand the sim is very "2D" as it were, it can't accurately represent everything in a "real-world" sense. But what it does seem to be saying to me is that holding the bike at 15Mph is potentially far less efficient and far more likely to result in overheating than bringing her up to 28Mph.
What struck me then as odd was that 28Mph seemed to be the optimal speed for a 60v system but that 35mph was the optimal speed for a 72v system.....which caused me to query the logic of "Volt Up-Gear Down". LFP then pointed out, accurately, that the motor is in fact ignorant of the system and the voltage it is being fed.
Its obviously a question of not taking the sim too seriously, it needs to be combined with real-world data, which if course is what it was intended for- namely a guide.
The Mighty Volt
Postby miniebiker » Mon Sep 12, 2011 7:52 am
Hey, think outside the box and design one that runs cool and does not waste power making extra heat :)
That is a for sure sign of a well designed system ! :)
And I hear you about bicycle components. Those cost money.
A good chain can cost as much as a Walmart bike.
I think I can design a bracket to hold the geared motor on the bottom bracket.
miniebiker
Postby sn0wchyld » Mon Sep 12, 2011 8:08 am
ive been hunting for a clear answer on this for a while now... do you mean that so long as you get to around 70-80% of no load speed for a particular throttle position then the efficiency will be quite high? or, to put it another way, the efficiency curve (and peak) of a given motor moves according to the position of the throttle, not according to pack voltage?
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby dogman » Mon Sep 12, 2011 2:55 pm
I think you just stated what I have been poorly trying to say. John is totally correct that motor speed has to be fast enough or it will make heat. That's why you should pedal your guts out to keep most stock kit motors above 15 mph when climbing a hill ( when used at 36v). Below that speed, they will get hot. In the 5303 example, 15 mph would not be fast enough I think.
But I think you just said the crucial thing. 80% of no load speed , at a given throttle setting. Take a typical 1000w ebike. Ride it half throttle on flat ground and it will go a certain speed, and likely won't overheat. Then go climb a 10% grade hill, ride it half throttle, and pedal enough to go the same speed you went on flat ground. I bet the motor does not overheat. As you pedal the motor fast enough, the load on it drops just the same as it drops as you reach cruise speed on flat ground. The catch 22 is can you add enough watts to get the motor up to speed on that grade. At some point, you can't. But you might be able to lower the throttle some more, and then be able to reach the now slower minimum speed by pedaling. That is, provided the hill is not too steep. For most typical dd motor kits, that critical grade is around 8%
The cruicial thing is not lugging it. This won't work if your half throttle watts is 4 times what the motor was designed for. Nobody can pedal hard enough in that case. Nor will it work if the speed you need to reach is beyond what you can reach by pedaling.
As for pack voltage, changing it will change the curves for the motor. So will changing the throttle position, but in a different way. You can see this if you imput 50% throttle into the sim. In either case, the "sweet spot" will be at different speeds.
dogman
Next
Who is online
Users browsing this forum: Bing [Bot], Google [Bot], ian.mich and 19 guests
