Got this reply from tncscooters:
The T3630 controller can not be run at 48 volts. This would burn up the controller. The internal capacitors are not designed to work with the higher powers you will see at 48 volts.
We do not suggest you use the 36 volt version of this controller on a 48 volt system. The low voltage cutoff is
set to a higher value so that you don't over discharge your batteries when riding.
The only controller we offer that does not have a low voltage cutoff is the ZY-KK70 controller. [$90]
This controller is capable of running from 24 volts to 60 volts.
very disappointing
So, to summarise:
1. If I buy a 48V controller it will almost certainly have a (roughly) 41.5V LVC which is too high for SLA batteries.
2. If I buy a 36V controller it's likely to fry quite quickly.
After about an hour of looking, I found this post
http://visforvoltage.org/forum/2973-building-own-emoped About half way down a guy says that his YK40 (36V) controller works at 48V. Hardly scientific evidence but all I've got at the moment.
Can anybody help me find a controller?
