ryan
UPDATE - This thread started out as a battery pack building thread, but I'm converting it to a build thread to get help along the way.
The final outcome will be a high powered, stealth Yuba Mundo, powered by a Crystalyte 5404 and 18S4P (66.6v32Ah / 2.1kw-hr) of Zippy LiPo hidden in the running boards. There's lots more to figure out, but it's coming together. I'd appreciate any help along the way.
Estimated budget is about $3500 all in.
Inventory list:
Original start of the thread, saved for posterity and to help others considering different battery packs and cargo bike builds...
I'm looking to upgrade my battery pack from my 72v20Ah headways to something better. One of my 36v20Ah packs is constantly failing and even after replacing every cell and BMS it still gives me trouble. Time to move on and start again.
I have a Yuba Mundo v2 but will likely upgrade to a Mundo v4 with this battery. Along with a new Crystalyte 5404.
Ideally I'd like to place the battery in the freeloaders as sort of a thick running board. Essentially I'm looking to put a base on each sideboard, fill it with lipo, and put another board on top. That way the packs are evenly distributed, low to the ground, and super stealth. But this also means I can't be opening up the pack all the time to charge individually. I need a reliable charging scenario.
Also, I'm not in this for the speed. If I can go 35mph I'm happy. 40mph is bonus. But when I go out I'm more interested in being able to charge up any mountain road in my way, and go for as long as I can stand it. If I could go 20-30mph for 60 miles (including two 1000ft climbs and descents) I'd be very very happy.
Please help me choose from the options below (or suggest an alternative).
Pack One - 18S4P of ZIPPY Flightmax 8000mAh 6S1P 30C
66.6v32Ah or 2131W-hr
12 packs x $83 = $996 ($0.47/wh)
12 packs x 1256g = 15072g (33.3lbs)
Pack Two - 16S8P of Turnigy 5800mAh 8S1P 25C
59.2v46.4Ah or 2747W-hr
16 packs x $98.40 = $1574 ($0.57/wh)
16 packs x 1216g = 19456g (42.9lbs)
Pack Three - 20S5P of Turnigy nano-tech 5000mah 10S 25~50C Lipo Pack
74v25Ah or 1850W-hr
10 packs x $108 = $1080 ($0.58/wh)
10 packs x 1305g = 13050g (28.8lbs)
Pack Four - 20S2P of A123 30C LiFePO4 (40 cells)
66v40Ah or 2640W-hr
40 cells x $50 = $2000 ($0.76/wh)
40 cells x 467g = 18680g (41.2lbs)
Pack Five - 22S1P of A123 30C LiFePO4 (22 cells)
72.6v20Ah or 1452W-hr
22 cells x $50 = $1100 ($0.76wh)
22 cells x 467g = 10274g (22.7lbs)
Choice Pack - Build a config for me!
Voltage = 60-75v
Ah = >20Ah
Bonus for ease of charging, reliability, etc.
Here's my current setup:
Cyrstalyte 5304, 72v20Ah LiFePO4 Headways, Lyen 18fet controller. I have two LiFePO4 chargers, one for each pack.
Inventory list:
- Crystalyte 5404 [shipping, ETA: February; 5304 in the meantime]
- ✓ Battery Medics (x3)
- ✓ Yuba Mundo v4
- ✓ Running boards (x2 pairs)
- ✓ Lyen 18Fet Controller
- ✓ Kiwi's Custom Yuba Mundo v4 Torque Arms
- ✓ 4mm Gold bullet connectors (x100)
- ✓ 5.5mm Gold bullet connectors (x48)
- ✓ 6mm Gold bullet connectors (with housings) (x48)
- ✓ 8mm Gold bullet connectors (x12)
- ✓ 8awg silicon wire
- ✓ 10awg silicon wire
- ✓ Zippy Flightmax 8000mAh 6S1P (x12 for 18S4P, split in two packs of 18S2P)
- ✓ Methods LVC/HVC Boards (x3)
- ✓ Bulk Charger (Sorensen Variable Power Supply 80v 18A)
74v25Ah or 1850W-hr
66v40Ah or 2640W-hr
Voltage = 60-75v
Ah = >20Ah
