FS Frame + Cromotor + Lipo
Postby gensem » Tue Nov 08, 2011 6:07 pm
I know most people around ll not care, but my new commuter frame just arrived. Need to cut the battery bag a little but thats pretty much it.
My arm is still ill but I finally felt happy with my ebike after the crash.
Edit: Video links start on page 7.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Re: New toy
Postby gensem » Tue Nov 08, 2011 6:12 pm
And a sneak peek of my lipo bunker...
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
gensem
Re: New frame + lipo bunker
Postby gensem » Tue Nov 08, 2011 6:58 pm
gensem
Postby fractal » Tue Nov 08, 2011 9:20 pm
what kind of frame is that?
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby neptronix » Wed Nov 09, 2011 1:36 am
aw man.. if you only had 1 size up of that frame.. the bag might fit in perfect! too bad about the shock hittin' it..
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby mvly » Wed Nov 09, 2011 2:36 am
Nice lipo bunker. I just use lipo bag for my lipo. I just a lot of them. :-)
mvly
Postby gensem » Wed Nov 09, 2011 4:44 am
fractal wrote:what kind of frame is that?
Fastrax CFD 2000
Its supossed to be a strong frame.
gensem
Postby gensem » Wed Nov 09, 2011 4:45 am
neptronix wrote:aw man.. if you only had 1 size up of that frame.. the bag might fit in perfect! too bad about the shock hittin' it..
I was sure the frame wouldnt have the clearance to fit the bag, but that was the best frame I could get and still think that 6x6s ll fit.
gensem
Postby gensem » Wed Nov 09, 2011 4:47 am
mvly wrote:Nice lipo bunker. I just use lipo bag for my lipo. I just a lot of them. :-)
I have some of thoses bags but since I live in an aparment and my charging spot is very close to my computer stuff(im an IT guy so I have a lot of) I decided that this kind of overkill was needed.
gensem
Re: New toy
Postby GCinDC » Wed Nov 09, 2011 9:37 am
i'm liking that frame (and i care, :lol: ) brand seems to be unknown so probably a rip-off of another successful frame?? anyone know?
gensem wrote:And a sneak peek of my lipo bunker...
i'd consider putting a flat bar on the bottom as a support somehow. the bag will sag when full. something thin enough you can bend it, and firm enough to add support. but since the seat tube splits, i'm not sure what to do. this is what i did on my early ghetto build (w/ angle bar w/ the ends trimmed) and it works great, from here.:
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby GCinDC » Wed Nov 09, 2011 10:18 am
according to this, 19.5" is a Large frame. does it seem so? just did quick sketch in powerpoint using the specs to see how many lipos would fit:
looks like you've got 6 tho, to run 18s2p? think you could fit 8 in there in the config i show?
GCinDC
1 GW
1 GW
Postby gensem » Wed Nov 09, 2011 10:49 am
Yup... its 19.5 and it was the best frame I could get from China, its supposed to have scandium and the construction looks fine. I ll be sure to test it using a big hub motor. Btw do you think the head angle is good enough for speed?
But I ll be actually using 6x zippy 8000mah wich are 165x69x52mm but I still think I can fit 6 of thoses and have some spare space.
Im at work so I cannot drawn, but I ll basically use 4 horizontally and 2 vertically.
gensem
Postby fabiograssi » Wed Nov 09, 2011 10:57 am
Nice frame, Gensem! Did you got it here in Brazil? How much and where?
- Fabio
fabiograssi
Postby gensem » Wed Nov 09, 2011 10:59 am
fabiograssi wrote:Nice frame, Gensem! Did you got it here in Brazil? How much and where?
- Fabio
China... around 400 dollars with custom black painting. If I was to order a frame like that in Brazil you know it would be 2 or 3 times more expensive.
gensem
Postby neptronix » Wed Nov 09, 2011 1:55 pm
neptronix
Postby gensem » Wed Nov 09, 2011 2:33 pm
gensem
Re: New toy
Postby gensem » Wed Nov 09, 2011 6:40 pm
gensem
Postby GCinDC » Wed Nov 09, 2011 6:46 pm
just worried lipos in a sagging bag will get damaged by shock...
GCinDC
1 GW
1 GW
Postby gensem » Wed Nov 09, 2011 6:58 pm
GCinDC wrote:just worried lipos in a sagging bag will get damaged by shock...
I tought about that too, but i dont think the cells ll have enough clearance to move but I might be wrong. Either way we ll find out in a couple of weeks if my arm keeps healing in the same pace.
gensem
Postby GCinDC » Thu Nov 10, 2011 8:26 am
i made a bag like that, for a much bigger triangle, and what i found was that the battery didn't stay snug up against the toptube like i'd hoped... :lol: instead gravity pulled it down and wanted to shape it like a tear drop (if viewed like cross section)...
if you have a hard liner between the bag and the shock that will help, but i'm guessing the shock action will eventually tear the fabric at the least and rub whatever is inside if they stay in contact like shown in your photo...
anyway, i'm really tempted to get one of these frames. so i've been researching them a bit:
i think hodaka is the parent company and they show the (more recent?) CFD 2500. (the 2500 has symmetrical chain-stays unlike the 2000 - an afterthought for the chain, that they corrected in the 2500, i wonder?)
The site is copyrighted 2001 :roll: , but the chronology goes to 2005. Looks like they've been building aluminum/scandium frames since 2001.
Can you measure the narrowest part in the rear triangle? How big of a tire will fit? 2.5"?
GCinDC
1 GW
1 GW
Postby gensem » Thu Nov 10, 2011 8:43 am
GCinDC wrote:i made a bag like that, for a much bigger triangle, and what i found was that the battery didn't stay snug up against the toptube like i'd hoped... :lol: instead gravity pulled it down and wanted to shape it like a tear drop (if viewed like cross section)...
I tought about the bag ideia and Im about to cut an old topeak rack and use as a bag base.
I saw the 2500 in the taiwan site too but was not able to find it for selling.
I ll measure tire clearance when I get home, I didnt bother to measure yet because it looks big.
gensem
Postby gensem » Fri Nov 11, 2011 6:48 am
Clearance is really good, I just measured.
3" clearance with wheel brakes, and 3,75" if you grind the brake bolts.
gensem
Postby GCinDC » Fri Nov 11, 2011 9:45 am
150mm between the dropouts?
GCinDC
1 GW
1 GW
Postby gensem » Fri Nov 11, 2011 10:47 am
GCinDC wrote:150mm between the dropouts?
Did not bother to measure too but its also big. I ll measure after work. but if I was to guess I would say its indeed 15cm. The frame is good, i mean much better than I tought I would for 370 dollars. But im brazilian and im used to pay too 2, 3 times the regular price so it might not impress you much.
gensem
Postby gensem » Sat Nov 12, 2011 7:42 am
Its bicycle sized, exactly 135mm
gensem
Next
Who is online
Users browsing this forum: BLUESTREAK, CogHog, unclejemima and 12 guests
