FS Frame + Cromotor + Lipo
Re: New frame + lipo bunker
Postby gensem » Wed Nov 09, 2011 2:33 pm
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Re: New toy
Postby gensem » Wed Nov 09, 2011 6:40 pm
gensem
Postby GCinDC » Wed Nov 09, 2011 6:46 pm
just worried lipos in a sagging bag will get damaged by shock...
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby gensem » Wed Nov 09, 2011 6:58 pm
GCinDC wrote:just worried lipos in a sagging bag will get damaged by shock...
I tought about that too, but i dont think the cells ll have enough clearance to move but I might be wrong. Either way we ll find out in a couple of weeks if my arm keeps healing in the same pace.
gensem
Postby GCinDC » Thu Nov 10, 2011 8:26 am
i made a bag like that, for a much bigger triangle, and what i found was that the battery didn't stay snug up against the toptube like i'd hoped... :lol: instead gravity pulled it down and wanted to shape it like a tear drop (if viewed like cross section)...
if you have a hard liner between the bag and the shock that will help, but i'm guessing the shock action will eventually tear the fabric at the least and rub whatever is inside if they stay in contact like shown in your photo...
anyway, i'm really tempted to get one of these frames. so i've been researching them a bit:
i think hodaka is the parent company and they show the (more recent?) CFD 2500. (the 2500 has symmetrical chain-stays unlike the 2000 - an afterthought for the chain, that they corrected in the 2500, i wonder?)
The site is copyrighted 2001 :roll: , but the chronology goes to 2005. Looks like they've been building aluminum/scandium frames since 2001.
Can you measure the narrowest part in the rear triangle? How big of a tire will fit? 2.5"?
GCinDC
1 GW
1 GW
Postby gensem » Thu Nov 10, 2011 8:43 am
GCinDC wrote:i made a bag like that, for a much bigger triangle, and what i found was that the battery didn't stay snug up against the toptube like i'd hoped... :lol: instead gravity pulled it down and wanted to shape it like a tear drop (if viewed like cross section)...
I tought about the bag ideia and Im about to cut an old topeak rack and use as a bag base.
I saw the 2500 in the taiwan site too but was not able to find it for selling.
I ll measure tire clearance when I get home, I didnt bother to measure yet because it looks big.
gensem
Postby gensem » Fri Nov 11, 2011 6:48 am
Clearance is really good, I just measured.
3" clearance with wheel brakes, and 3,75" if you grind the brake bolts.
gensem
Postby GCinDC » Fri Nov 11, 2011 9:45 am
150mm between the dropouts?
GCinDC
1 GW
1 GW
Postby gensem » Fri Nov 11, 2011 10:47 am
GCinDC wrote:150mm between the dropouts?
Did not bother to measure too but its also big. I ll measure after work. but if I was to guess I would say its indeed 15cm. The frame is good, i mean much better than I tought I would for 370 dollars. But im brazilian and im used to pay too 2, 3 times the regular price so it might not impress you much.
gensem
Postby gensem » Sat Nov 12, 2011 7:42 am
Its bicycle sized, exactly 135mm
gensem
Re: New frame + Lipo
Postby gensem » Sat Jan 07, 2012 7:54 pm
Shaping up
Battery case (Oatnet's idea)
gensem
Postby GCinDC » Sat Jan 07, 2012 8:51 pm
woah. :twisted: cromotor there?
did you add a brace in the triangle?
GCinDC
1 GW
1 GW
Postby gensem » Sun Jan 08, 2012 12:40 am
GCinDC wrote:woah. :twisted: cromotor there?
Yup its a cromotor
Im using Doc torque arms and soldered a flat bar to support the controller inside the frame triangle.
Hoping to get the bike running in 2 or 3 weeks. Im still short of a controler and also need to assemble gary´s lite bms.
gensem
Postby hillzofvalp » Sun Jan 08, 2012 12:48 am
yum. cromota
hillzofvalp
Postby Philistine » Sun Jan 08, 2012 4:07 am
That looks badass, love the all matte black and the cromotor.
My mate has a similar setup using the same Falcon EV bag, on a Kona Stinky (very similar frame setup as yours), and he has no probs with it at all. He has been getting slight chafing against the suspension on the bottom but nothing serious. He is really happy with the setup and in my opinion the falcon EV bag in a suspension frame like that is a great commuter option. Best of luck with it.
Philistine
Postby GCinDC » Sun Jan 08, 2012 6:26 am
did you get the cromotor laced? do you know what rim it is? looks bigger than a 20"..
and are those the croforks? i see dual disc adapters...
GCinDC
1 GW
1 GW
Postby gensem » Sun Jan 08, 2012 7:41 am
Philistine wrote:That looks badass, love the all matte black and the cromotor.
I love the matte black coz it doesnt drag much attention and want to stay under the radar.
Can you elaborate on the chafing issue? You mean the tire chafing on the frame?
This frame had 135mm space but I gave it a little heat and it has around 155mm now.
I have the Falcon EV bag too, plan to put the 24fet controller inside of it and ll be hoping the controller does not overheat.
gensem
Postby gensem » Sun Jan 08, 2012 7:50 am
GCinDC wrote:did you get the cromotor laced? do you know what rim it is? looks bigger than a 20"..
I found an experienced motorcycle wheel lacer in Sao Paulo, so I gave up lacing the cromotor to a bicycle wheel.
Its a 17" 140 moped rim with michellin moped tires, OD is about 23". Front wheel is going to be 24" bicycle rims with 2.5 or 3.0 tires that ll end up having around 25-25.5" OD.
Yes, the front fork is a DNM modded to use dual rotors by Hal9000/Accountant.
gensem
Postby Philistine » Sun Jan 08, 2012 7:57 am
All I meant about the chafing issue Gensem was because my mate was stuffing his EV Falcon bag so full of LIpo and controller (I think he has about 12s3P and his controller and DC/DC converter etc.. all in there), that the bottom of the bag is pressing against his suspension in the triangle, so the bag is chafing a bit). Having said that he has been riding like that for 12 months at least with no issues. I hadn't noticed you were going the Oatnet route with the box on the forks, I imagine that will work well as well. Best of luck. Cheers, Phil.
Philistine
Postby gensem » Sun Jan 08, 2012 8:02 am
Philistine wrote:All I meant about the chafing issue Gensem was because my mate was stuffing his EV Falcon bag so full of LIpo and controller (I think he has about 12s3P and his controller and DC/DC converter etc.. all in there), that the bottom of the bag is pressing against his suspension in the triangle, so the bag is chafing a bit). Having said that he has been riding like that for 12 months at least with no issues. I hadn't noticed you were going the Oatnet route with the box on the forks, I imagine that will work well as well. Best of luck. Cheers, Phil.
I see (never heard the word chafing before)...
Im copying Oatnet, going to put 8x 6s 8000 in the box, but the support its not fixed in the fork its soldered to the frame.
Im eager to get the bike running. :)
gensem
Postby GCinDC » Sun Jan 08, 2012 8:18 am
gensem wrote:I found an experienced motorcycle wheel lacer in Sao Paulo, so I gave up lacing the cromotor to a bicycle wheel. Its a 17" 1.4 moped rim with michellin moped tires, OD is about 23".
so what spokes did you get?
GCinDC
1 GW
1 GW
Postby gensem » Sun Jan 08, 2012 8:29 am
There were no off the shelf spokes that fitted cromotor with a 17" rim, so I got 9g 110mm black spokes from newsonsportec (ebay).
Front wheel is going to use 12g sapim spokes.
Tire
gensem
Postby farmkid4 » Sun Jan 08, 2012 8:39 am
Great looking build cant wait to see how it turns out!
Keep the pics coming :D
Do you have the ability to read?
Do you use it to increase your understanding?
9C Buildlog: http://endless-sphere.com/forums/viewtopic.php?f=6&t=47608&p=698343#p698343
farmkid4
Postby gensem » Wed Jan 11, 2012 10:19 pm
OK... frame is broken...
I told the guy to go easy on the flame solder because we were just giving the swing arm "a heat". I now have a broken swing arm. grrrr
Hope I can come with a solution coz I dont trust a soldered swing arm. (ll post pic tmr)
gensem
Postby fabiograssi » Thu Jan 12, 2012 3:22 am
gensem wrote:OK... frame is broken...
Aluminum frames don't tolerate this procedures in a rule of thumb. With a cromota in the ass, worst...
Maybe build a steel swing arm with myamura, from Santo André (I think, but have the contacts...).
Do you know him?
fabiograssi
Next
Who is online
Users browsing this forum: ken1645, maramusa, mcintyretj, MSN [Bot] and 12 guests
