Philistine wrote:I had to sand inside the seat tube a bit for the post to fit. It ended up being such a tight fit, that I don't have a clamp on my post (it just stays stuck), and I wouldn't be able to move it without a lot of trouble. That was because I didn't sand all the way through the seat tube (very hard to do that), so be aware that the suggested tube is a very tight fit.
gensem wrote:If you a carefull you can fit like 24-28 (depending on the clearance you want front the side cover) 20ah a123 pouchs, but be aware that you ll have to bent the cells a little.
Alan B wrote:gensem wrote:If you a carefull you can fit like 24-28 (depending on the clearance you want front the side cover) 20ah a123 pouchs, but be aware that you ll have to bent the cells a little.
That is about 1.5 kwh of A123. Nice.
Is that using both battery storage areas on the frame?
Alan B wrote:Looking at brakes
The Greyborg standard forks have dual disc capability. So what dual mirrored calipers are available?
Looks like only two. The Gatorbrake 8 pot, and the Magura BIG Twins. Any others??
gensem wrote:Hygia sells online for the end user.
I made an order on the dual front brakes like 10 days ago, we they arrive i ll take some pictures.
Alan B wrote:Looks like Hygia uses Shimano XT/XTR size pads. Convenient.
They mention something about post mounting. I wonder if they have the proper adapters for the MTB forks.
http://www.hygia.com.tw/liveshop/index. ... duct_id=82
Users browsing this forum: Bing [Bot], Google [Bot], Yahoo [Bot] and 10 guests
