Accountant wrote:shinyballs wrote:For what it is now - the same mass and weight, what's the maximum continuous power they can do on their motor?
4000 W is data from manufacturer.
If you want to use your motor for many years as daily comuter, that would be it.
For racing, and in the cold weather 6000 W is still on the safe side for up to 60 minutes (real life result)
7000 w is too much, dangerzone, heat can make damage on the magnets.
zombiess wrote:...
Cromotor 50mm wide stator 18x4 winds is 9.3kV and should be available by mid March. Just keep checking the 1st page of this thread [Greyborg USA Dealer thread] for updates.
Alan B wrote:Some fresh Cromotor data:zombiess wrote:...
We had seen the Kv before, but not the wind data, though I suspected it from writing inside the motor in photos. 18 strands, but only 4 turns!
Alan B wrote:Thanks for your input and observations. I'm stalled at the moment on this project waiting for parts, there are a few things I can work on like getting the side panels mounted and putting the swingarm together and planning batteries but am focussing on some other projects at the moment. In one sense it is good this build is stretching out a bit for budgetary reasons, but I'm anxious to get it going soon. The big hangups right now are the forks, front hub, cranks and rims/wheels.
I still need to find a source for the Schlumpf chainring, and perhaps the dual front disc brakes. If I can't find the duals I'll have to go with a single.
zombiess wrote:Alan B wrote: ...
Hygia for the dual front brake setup. Chain ring is a standard 110 mm 5 hole chainring. Accountant told me 32 tooth fits no problem, up to 36 can be done with mods to the plastic. Just buy one off ebay.
chroot wrote:Make sense about the CroMotor better off use single speed with combine Schlumpf drive. Thanks for details and I might get Schlumpf drive for my CroMotor. Problem is they are cost ridiculous - I checked Google search.
chroot wrote:@gensem - Really, I'll check with zombies later after I meet up with ilia and Lyen in SF today.
Users browsing this forum: Bing [Bot], crusoe, Heritrix [Crawler], Majestic-12 [Bot], OCMike, Rassy and 18 guests
