CroBorg Commuter
Re: Greyborg Warp Build Planning
Postby Alan B » Sun Feb 05, 2012 9:47 am
I do need to put up pictures. Have a bunch.
I made some measurements of the axle and rear dropouts. The Cromotor 16mm threaded axle ends are 1-1/4" long from the disc brake mount on one side, and from the freewheel threads on the other. Some spacer washers will be needed on both sides to prevent rotating parts from touching the dropout.
The Nut is 5/8 thick, so uses about half the available thread space when fully engaged.
The rear tubular swingarm dropouts are slightly more than 3/8" thick.
There is not much room for a torque plate, and Accountant indicates one is not needed if the Cromotor is seated fully into the dropouts. Excellent! :)
The Cromotor with 16mm threads and 10mm flats has a substantial area of flat to resist the torque. Very nice. :)
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sun Feb 05, 2012 9:51 am
Here are the requested unboxing photos:
https://picasaweb.google.com/Alan.Biocc ... directlink
Alan B
1.21 GW
1.21 GW
Postby ryan » Sun Feb 05, 2012 11:05 am
Wow, were all of your boxes dragged here? They should actually put them on the truck instead of dragging them behind.
Can't wait to see this come together.
Marin DH Electric Mountain Climber. Crystalyte 5304. 72v20Ah (Dual 36v20Ah 12S2P LiFePO4 Headways). 18 FET Low RDS MOSFET Overclocker Ready LYEN Controller. (See Build Thread)
ryan
Postby Alan B » Sun Feb 05, 2012 11:20 am
Shipping is tough on boxes. Hopefully having a US dealer and shipping in larger containers will help.
I'm going slow on this build. I want it to be a really good one.
Collecting all the parts is a bit of a chore. The details are slowly coming together.
It appears that the Turnigy 6S 5AH battery bricks will fit nicely, though the wiring wil be snug. The Zippys don't fit well at all. So I'm getting more Zippys and will put 18S 16AH of zippys on the mountain bike, and take all the Turnigys for the Greyborg. But for next weekend I'm taking both and lashing them together temporarily on the BikeE. So that will be 18S 31AH. The Zippys are a bit optimistic on their amp hour rating so in reality probably more like 29AH.
I was going to put more Turnigy on the mountain bike, but the Zippys fit a little easier and a lot fewer wires are required, so I'll go with 6*3=18S 2P 16AH Zippy on the Mountain Bike. The Turnigy I have, plus more will go toward the Greyborg. The BikeE will get a smaller pack. Not sure what at this point, but if I can fit a pack inside the frame that will determine what batteries to use.
I'm trying to make all three of my ebikes be 18S. That makes chargers easier to manage, especially since I want to have them at home, work, and portable.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Thu Feb 23, 2012 10:34 pm
Ebikessf.com repaired the Schlumpf drive for me. Thanks Ilia! It suffered some shipping damage, one of the ears for mounting the chainring was bent, but it is much better now.
The above drive is a licensed variant of the Schlumpf drive that takes standard chainrings and crank arms. I obtained this one from Accountant.
This is a "speed drive" model that shifts between 1:1 and 1.6:1 by pushing the button in the center of the hub left or right with your heel. When in 1.6:1 the chainring turns 60% faster than the crank, effectively making the chainring equivalent to one having 1.6 times as many teeth.
This is important since the Cromotor is so wide it doesn't leave room for a wide freewheel. Usually only a single speed freewheel is used, and the smallest units have 16 teeth. So the front chainring needs to have a lot of teeth to pedal along with the motor at speed. This gives two gear ratios, one for pedaling without motor at low speed, and another for pedaling along with the motor at cruise speed.
Alan B
1.21 GW
1.21 GW
Postby chroot » Fri Feb 24, 2012 9:54 am
Make sense about the CroMotor better off use single speed with combine Schlumpf drive. Thanks for details and I might get Schlumpf drive for my CroMotor. Problem is they are cost ridiculous - I checked Google search.
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby gensem » Fri Feb 24, 2012 11:47 am
chroot wrote:Make sense about the CroMotor better off use single speed with combine Schlumpf drive. Thanks for details and I might get Schlumpf drive for my CroMotor. Problem is they are cost ridiculous - I checked Google search.
Accountant/Zombies do have a good price on the speed drive.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby chroot » Fri Feb 24, 2012 12:04 pm
@gensem - Really, I'll check with zombies later after I meet up with ilia and Lyen in SF today.
chroot
Postby Alan B » Fri Feb 24, 2012 12:29 pm
I obtained the drive photographed above from Accountant (the Greyborg people) for a good price. :)
Alan B
1.21 GW
1.21 GW
Postby MattyCiii » Mon Feb 27, 2012 11:30 am
chroot wrote:@gensem - Really, I'll check with zombies later after I meet up with ilia and Lyen in SF today.
Chroot,
Did you get to talk about price, or availability of the Speed Drive? Speed Drive seems like just the ticket for pedal-augmented e-power!
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby zombiess » Mon Feb 27, 2012 8:32 pm
Chroot,
I've got one for my bike and will eventually have more in the future (don't ask now), but I need the tool to cut the bottom bracket so it will fit and I don't have that part yet. Supposedly one of the guys I know here in town has access to the tool so I'm going to try and get my race bike to him so I can get it installed.
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby Alan B » Sat Mar 03, 2012 12:29 am
I received the chainring and bolts for my ATS Schlumpf drive.
Unfortunately the bent ear on the drive is not ye straight enough to take the bolt, and it causes the chainring to wobble. So I'll have to see if I can straighten it out better (or break it :( ). Wish me luck.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Sat Mar 03, 2012 12:30 am
Also received the seatpost. But it won't fit into the frame tube. Have to look into that more carefully. Hopefully it can be coaxed in without a lot of trouble.
Alan B
1.21 GW
1.21 GW
Postby Philistine » Sat Mar 03, 2012 1:36 am
I had to sand inside the seat tube a bit for the post to fit. It ended up being such a tight fit, that I don't have a clamp on my post (it just stays stuck), and I wouldn't be able to move it without a lot of trouble. That was because I didn't sand all the way through the seat tube (very hard to do that), so be aware that the suggested tube is a very tight fit.
Philistine
Postby Cicada » Sun Mar 04, 2012 11:31 pm
I went trough this same issue:)
Easy fix (30 minutes), drill a screw (hexagonal head is best)into a shorted piece of broom handle,
cover the piece of wood with enough sand paper to make it spin (hold with tape at the extremities)
and rub the inner seat post tube with a drill.
Easier than what you think.
"Try again. Fail again. Fail better"
Greyborg Warp 80v A123, 18fet controller, Greyborg Hubzilla
http://evlab.co.nz/2012/greyborg-build-awesome/
http://vimeo.com/51900545
Cicada
Postby Alan B » Mon Mar 05, 2012 12:26 am
Thanks for the tips. I will give them a try.
Alan B
1.21 GW
1.21 GW
Postby motorino magnet » Thu Mar 08, 2012 3:44 pm
Philistine wrote:I had to sand inside the seat tube a bit for the post to fit. It ended up being such a tight fit, that I don't have a clamp on my post (it just stays stuck), and I wouldn't be able to move it without a lot of trouble. That was because I didn't sand all the way through the seat tube (very hard to do that), so be aware that the suggested tube is a very tight fit.
no sexual innuendos....
motorino magnet
Postby BATFINK » Fri Mar 09, 2012 8:26 pm
Thanks for the photos, do you mind Giving a few cost details for such a build. Interested in price of frame mostly. Looks amazing. I visited greyborg site but his online shop seems to be offline
Sent using Endless-Sphere Mobile app
BATFINK
Postby Alan B » Fri Mar 09, 2012 8:40 pm
Probably best to get costs from Zombiess or Accountant. I don't have the numbers handy and things are changing.
Alan B
1.21 GW
1.21 GW
Postby Alan B » Fri Mar 09, 2012 9:03 pm
Received Pedals and Chain.
Need to package hubs (front and rear) for shipment to wheel builder.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 9:38 am
Alan, what are you using for the rear freewheel.
cassschr1
Postby Alan B » Sun Mar 11, 2012 9:52 am
Haven't chosen one. The White is the best, but it appears that it won't screw all the way down. The Dicta has threads all the way through but reviews indicate it isn't as good quality. ACS also may have quality issues.
One concern I have is if the freewheel fails the pedals will start spinning. That would create a major problem at speed.
So I have not decided. I would like to use the White Brothers unit. To get it all the way down might require shortening the threads on the motor. The fully threaded freewheel is the easiest route.
Shortening the 24FET controller
My 24FET controller is about 1/8" too long. The extrusion is longer than it needs to be, so my plan is to shorten it. I was wondering how I was going to clamp it in my small mill to shorten it. Recently I got a 120 tooth 12 inch non ferrous blade for my chop saw. It cuts aluminum like butter. So I think I will use that on the controller extrusion. I'll work up some clamping, but with this blade there is no vibration or noise cutting aluminum. So that's the plan at the moment.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 9:58 am
can a regular free wheel be disasembled and used ?
cassschr1
Postby Alan B » Sun Mar 11, 2012 10:06 am
I've never tried to disassemble one. I think they are not easy to take apart, and we need a small cog and narrow width, so the design is likely different.
Alan B
1.21 GW
1.21 GW
Postby cassschr1 » Sun Mar 11, 2012 12:12 pm
Do you know if 20a pouch cells fit in the frame....how many?
cassschr1
PreviousNext
Who is online
Users browsing this forum: Bing [Bot], mabman and 13 guests
