electr0n wrote:I've had a chance to ride my bike a few times at 66.6v 40 amps and it's a lot of fun but when riding into a strong headwind I still feel somewhat under powered. I think my target is going to move up a little to 88.8v and 60 to 65 amps. Is that asking too much from a 12 fet lyen controller? What is the benefit of the 18 fet controller? Is it necessary for that power level?
electr0n wrote: I hate to keep pulling the motor off and messing around with the delicate hall and phase wires around the axle.
electr0n wrote: I found what looked like a burn mark and I cut off the white fiberglass stuff covering the wires
electr0n wrote:Any ideas? Opening the motor wasn't a total loss, at least I was able to spray the inside with some anti corrosion stuff. I also know for sure I have no wire cut issues, or at least I didn't notice anything obvious.
electr0n wrote:I finally got a cycle analyst! No more range anxiety. Being able to see the battery voltage, amp hours used and instantaneous power is very helpful for getting the most out of my battery pack. Prior to having the cycle analyst I would always cut my rides short for fear of taking the battery down too low.
Seeing the real time power consumption has been illuminating. Power consumption goes up dramatically even on slight uphill grades and accelerating. If not being careful with the throttle it's so easy to ride very inefficiently.
The current limiting feature is nice with some tweaking of the settings. However the speed limiting setting so far has been very jerky. It's like the power goes off when the limit is reached and then it goes back on again at high power draw, not efficient at all. I was hoping the speed would be held steady at a low power draw like cruise control, but I suppose that's not the same thing.
Users browsing this forum: -dg, d8veh, Holocene, Miles, phil o' dendron and 9 guests
