Code:
--< Original >--
5.875Kg Total
2.675kg Core & cables
784g Face plates
88g Bearings
2.22kg Magnet ring
110g Nuts, washers, screws
--< Current >--
2.64kg Core & cables
I pruned ~2oz and used up ~1oz
Left in about as much material as I felt comfortable with. I could have gone for perhaps 1/3 more without weakening it further if I followed up with dremel detailing, there's still a lot of essentially useless material there, but that's the thing: there's a lot of it, and I got pretty fed up of grinding. Also, unless you really want to, it's not worth it; I only gained ~2oz.
The cables are quite a bit fatter then the originals because they were too thin to do the job as required, most of the weight I consumed went there, also a greater portion of that weight is actual conductor since there's no fat sheath that follows the entire cable.
~10g went to the female mini XLR connector, it's made of thick-ish metal when something in plastic would have done the job, in total the XLR represents about 20g of weight that I could have avoided with a bit of foresight, and that sucks.
Before, ~2.675 kg:
After, 2.625Kg +-5g:
