Ok I would like some more mph..mxus help
Re: Ok I would like some more mph..mxus help
Postby Mudduck » Sat Mar 24, 2012 3:55 pm
Yea that's what I just did the sal was fast..about 2 weeks..but double the price.
Mudduck
Postby Anamelesssomebody » Sat Mar 24, 2012 9:31 pm
:roll: :roll: if you upgrade, what are you going to do with the old stuff?
Edited to get the arrows right --------------------------------------------------------------------------------->>>>>>>>>>>>>>>>>>>
New at this
Anamelesssomebody
Postby Mudduck » Sun Mar 25, 2012 7:28 am
That is the question?i see you live near me.what would you want just the wheel kit,or the the whole thing?Im going to email Paul to see what he says about my battery running a Mac.
Mudduck
Postby cell_man » Sun Mar 25, 2012 8:17 am
A 3P pack would be ok on an 8T Mac running a 30A 9 fet. You'll see a little sag under full load when it's cold, but nothing major and nothing to worry about. As others have said, speed takes power and range at 25mph is way less than range on same battery at 20mph. There is a neat way you can feed a second battery into the primary battery into the charger plug. If you wanted to add a second pack later for more range, you could connect it in that way when you need that extra range, or just take 1 pack when you don't need the range. This is a better solution than running packs in parallel and that second battery could be the same parallel count,it could be smaller or it could be bigger.
You'll see about 25mph or very close to it on the 12S pack with an 8T Mac in 26", it's fast enough and in my opinion once you start going much faster than that, the battery requirements for any sort of range escalate very quickly. The 3 speed switch also means you can keep your speed in check when you do need to stretch out the pack and if you also get a program cable, you can adjust current level if you wish. You can even re-program speed 3 on the controller to 120% and get speeds of 15-20% higher, so you might even get close to 30mph on that 8T still on only about 36V. I've seen high 30s MPH on an 8T on 48V with 120% speed setting for example, a touch over 30mph on standard 100% speed.
Another and also cheaper option is to use a 6 fet Infineon and apply the same 120% speed setting to the MXUS for higher top speed, but the MXUS is not a power monster, so you would need to keep a check on the motor and go a bit gentle to avoid overheating or damaged gears. I don't see why you wouldn't see a similar 15-20% increase in max speed on the MXUS, the result should be close to what you might get running the motor on 48V.
Apologies if I have now made too many options for you there, sometimes too many is as bad as not enough :) SAL is double the price, but takes about a quarter the time as surface does, so by my calcs, it's half the price :? I think :)
http://www.emissions-free.com/ has just come online. It's a bit naff at the moment, but it can only get better :)
Drop me a line on emissions-free_worldwide(at)hotmail.com if you want to discuss any products I stock or you would like to source in the future.
cell_man
Postby Anamelesssomebody » Sun Mar 25, 2012 9:02 am
That was some good explaining by cell man. It gives you a lot of options. Since he thinks your battery will work a few different ways, I guess just the wheel kit if you go the Mac route. I'm in galloway.
New at this
Anamelesssomebody
Postby boppinbob » Sun Mar 25, 2012 10:12 am
Mudduck, I too, have a slow, safe bike. It is legal and I use it as a commuter bike to work (500w rear hub dd motor, 36v12ah batt phantom x) It uses lifepo4. It is governed to 20 mph max. I am not going to modify it. It fits my commuter needs well. I built another bike that is much faster. (HS 3540, 72v 50a with lipo ) I use it as my thrill seeker bike. I don't use it to go to work because it's not street legal strictly speaking, and because of the infinitesimally small chance of spontaneous combustion of the lipo pack which would suck if it happened on company property. You are right, the people in this forum usually have more than one or two bikes and ride the one which suits their needs the best. If it were me, I'd do another build that exactly fits my needs, and give the first bike to your wife or girlfriend. (or boyfriend if that's how you roll)
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby motomech » Sun Mar 25, 2012 11:52 am
Paul, have you tried this?
I've read here, at least one rider, who tried that w/ a geared mini-motor[can't remember which one] and the result was no speed gain.
Sorry, I can't say what the reason was[he had a theory]or link it right now, it was while ago.
Mudduck-You could add another MXUS on the frt., gain maybe 2 mph and have a much better climber. All for little cost in W/hr.s.
Paul's friend, Chinaphil, did it a while back.
viewtopic.php?t=24866
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby neptronix » Sun Mar 25, 2012 12:02 pm
If you added another motor, you'd have 12-14lbs worth of motor.
The total cost of both motors would be over a MAC motor.
The MAC motor only weighs 10lbs. and is more powerful than 2 MXUS motors combined
I've ran mine at 35-39mph constant for long periods of time.
It's likely that there will be no speed gain. More torque, yes. More speed? probably not.
So, bad idea :)
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby Mudduck » Sun Mar 25, 2012 3:35 pm
Thanks,Paul!this is why I'm happy I found you thru this fourm..yes the sal shipping is twice the price but your right,but well worth it.I'm very happy I did it..I've done about 48miles since I got it..I think my best bet is to go with the Mac.at least that way I can upgrade..because once I hit 25 mph I'm sure I'd want to go faster..really want to think about it..I just love riding my bike to work now...I haven't started my suv in a week..:)
Mudduck
Postby motomech » Sun Mar 25, 2012 9:55 pm
neptronix wrote:If you added another motor, you'd have 12-14lbs worth of motor.
So, bad idea :)
Well, not that bad of an idea, but it seems like at this point, Mudduck is committed to best speed with his existing pak. And that clearly means the 8T MAC.
Still,
Yeah, but it is distributed between 2 wheels with half the unsprung weight.
Only if he was starting from scratch. But he already has the MXUS kit and if he can't use it for this build or another, it's worth what he can resale it for. I think it would resale easy enough, but he is still is going to take a hit.[Mudduck, I'll give you $200 for it, you ship to Md.]. Actually, the difference in $ is not really enough to be much of a consideration
Not at 39V and using the stock controllers.
2 MXUS controllers....... @ 17A-34A-1326 Watts
Cell_man kit supplied controller 30A-1170 Watts
Sure there would be some parasitic losses associated with two operating systems, but they are small..
And the Mac would be easier to pump up, but that add costs, something that Mudduck is not wanting to consider at this time.
I must stand my ground on this one :lol: Every report that I have seen[here and at Pedelec UK] states a 1 to 2 mph gain when combining two like motors.
My interest is mini-motors, so Graykard and Chinaphil come to mind. Actually. The Ebike sim. shows why this is so[and the sim. never lies...it's just misinterpetreted :roll: ]. Take any pair of motors and the sum of the two motors will move the "load-line" up approx. 2 mph.
But for Mudduck, who probably isn't interested in tinkering with a 2WD build, or in general, for street only use, the MAC's ability to hit the target speed of 25 mph on 39V and retain some climbing prowless, is truely impressive.
Finally, Pauls' comments about the battery leads me to think that it would be easier to add capacity than voltage, makes the MAC the best choice imo.
Mudducks very last comments about even more speed indicate that "the bug has bitten" and makes me wonder if he could afford to add that extra battery capacity and wasn't facing any tough hills, could he even go with a 6T?
motomech
Postby Mudduck » Mon Mar 26, 2012 5:28 am
Thanks motomech,there are a lot of different ways to go with this one,I dont want to go with the two motors idea.but thanks for the input,,I think it would kill my battery and the cost of another kit and shipping.i tried to be cheap,I like the kit I got just want I asked for,but I should have spent the extra $...I have no one to blame but my cheap ass..the things you can do with the Mac is big..the bug has definitely bit me...
Mudduck
Postby mettzman » Mon Apr 09, 2012 1:21 pm
Sorry to resurrect/hijack but some helpful direction to existing threads please..........
Dogman...
..."buy another cellman battery in 48v, and use the old 36v one as a range extender when you want a longer ride. A less costly alternative would be to buy a bms and some cells from cellman, and convert your battery to 48v."
are there good examples so I don't have to bother cell-man? I'm interested to learn more about the "charge port" method as well.....
mettzman
Postby 999zip999 » Mon Apr 09, 2012 2:08 pm
Are you sure it's a 6.9ah battery ?
999zip999
Next
Who is online
Users browsing this forum: Bing [Bot], ChinaV, Diamondback, Google [Bot], wildharemtbkr and 21 guests
