Request advice: Bending CroMo tubing
Postby MattyCiii » Sat Apr 14, 2012 11:24 am
Hello, I have two questions for those experienced in bending metal tube:
1) I have 1" x 0.5" rectangle tubing, wall thickness 0.035" on the way to use as a custom built rear triangle. I'd like to make the chain stay as a single piece, bent into a "U" shape rather than cut and weld. That would mean a rather aggressive 3" inside diameter bend to just under 180 degrees. Is this possible - or should I just re-design to cut and weld a squarish "U" shape?
2) If it's possible to do, any recommendations on how to do it? I've heard of people stopping into their local muffler shop and getting bends done, but if the equipment at such a place is fundamentally incompatible with what I'm trying to achieve, better to hear it here than to waste my time driving down the road...
Any advice appreciated, thanks.
Matt
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Re: Request advice: Bending CroMo tubing
Postby Drunkskunk » Sat Apr 14, 2012 11:50 am
If you bought it from Aircraft spruce, then you're trying the same thing with the same size tube I just tried.
And the results were not good.
It shattered.
someone else may know more, but from my experiance You have to mandrel bend square tube, and get it cherry red hot or it wants to collaps on it's self. So what I tried was a series of relief cuts along the inside and tried to bend it cold. I was using a vice and a form to try the first bend, and it shattered like glass.
Drunkskunk
Postby chisixer6 » Sun Apr 15, 2012 2:26 am
look at Warren's bobber build... He got a tube bender from harbor freight that bends cromo pretty good. he's got avideo on it's use too.
viewtopic.php?f=3&t=33004
he has the tube bending a couple pages in, really neat
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Postby MattyCiii » Sun Apr 15, 2012 11:13 am
Thanks!
MattyCiii
Postby PaulD » Sun Apr 15, 2012 11:43 am
That's a tough bend to make. My race bike chainstays have a 3" radius bend that is only about 20 degrees. I made my own bending die for my bender (pretty much the same as the harbor freight model) which is fairly simple, just a 6" diameter, 1" tall cylinder with 7" diameter plates sandwiching it. You'll have to get the tube dull red in the bend area (big rosebud tip on an oxy acet torch) to prevent cracking (i'm really surprised drunkskunk had his shatter, normalized tubing would probably just crack on the outside).
The key thing that took a while to figure out, was that the bending die needed a feature on it right in the middle to push on the the inner wall of the tube to collapse it inwards prevent it from buckling. I'll take a picture next time i'm at my shop.
PaulD
Postby MattyCiii » Sun Apr 15, 2012 12:31 pm
Thanks Paul,
Sounds like it's something a bit over my head.
My original design was to put that "U" bend into the steel, then weld on two "legs" that then get welded to a piece of round tubing that is the pivot:
But I don't want to do anything that would weaken the steel, and I don't want my design to be in the "too hard to do" category and never get done/not get done right.
My current thinking is to put "S" curves into two lengths of steel like so, and connect the two together with a single welded piece.
As shown, I still use a 3" inside diameter radius on the curve, but I'm sure I can use something less aggressive like 4" or 5". Any thoughts on this design?
MattyCiii
Postby Harold in CR » Sun Apr 15, 2012 12:45 pm
Make the bent piece out of solid stock, then, weld it to the Cro-moly tubes, maybe :?:
Thanks to Justin, the forum is open source and NON-commercialized.
http://www.costaricacraftwood.com
Harold in CR
Postby MattyCiii » Sun Apr 15, 2012 1:08 pm
Harold in CR wrote:Make the bent piece out of solid stock, then, weld it to the Cro-moly tubes, maybe :?:
That's a great idea, thanks. Although I'd probably just cut and weld square cuts to the tubing at that point:
5" inside diameter "S" curves come out pretty good. Note the cross piece is also bent in this design:
MattyCiii
Postby Thud » Sun Apr 15, 2012 1:35 pm
Bending tight radius's in rectangluar or square tubing is a tough propsition.
When I need a radius that tight
I actualy slit the tube from an end to just past where you need the radius, heat it untill soft & pull the radius...then its stitch the tube back together on the slits. Its a little time consumong but it elliminates the whack deformation on the top & bottom sides of the square.
sounds like more work but the results are fantastic.
Hint: make the bends as smaller parts of the assembly & weld them together at assebly
get some......
Thud
Postby John in CR » Sun Apr 15, 2012 11:04 pm
I like the S a lot better than relying on welds at the U for strength, and to me it looks better too. I think I'll copy it if you don't mind.
John
John in CR
Postby amberwolf » Mon Apr 16, 2012 3:26 am
I was going to do something very similar, a U-shape of rectangular tubing, but realized that any method I could manage here would probably destroy the tubing at the bend, unless I were to cut triangular sections out of it's inner radius, and then reweld it together after the bend.
I decided to make it an H-design instead, as it is much simpler for me to build.
Your S-design would also be easy enough; I didn't think of trying that, but it should work much easier than a U-bend.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby MattyCiii » Mon Apr 16, 2012 5:35 pm
Thanks guys.
I re-ran the numbers on the last design - the "S" curves - and it'll work well with 6" or 7" inside diameter curves too (Probably 8" ID curves but I have not checked that yet). Hopefully the inner weld where the cross piece is mounted is not too tight for my welder friend to accomplish.
The curves are 31deg one way then 28 reverse, not much in the grand scheme of things, so hopefully the shallower curve and the larger inner radius make this possible to do with my limited tools/skills.
MattyCiii
Postby Harold in CR » Mon Apr 16, 2012 6:38 pm
I hope you thought about putting the solid piece inside the tube a ways before welding. There are other good ideas, also.
Harold in CR
Who is online
Users browsing this forum: No registered users and 14 guests
