5404/5403 The good The bad The ugly
Postby Evoforce » Sun Apr 29, 2012 3:09 am
Just thought it would be nice to start a thread on all the things involved with the 5404/5403. Issues of good and bad or trial and error and what fixes or work arounds we have found to use.
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Re: 5404/5403 The good The bad The ugly
Postby voicecoils » Sun Apr 29, 2012 3:17 am
Regarding fitting to your dropouts, here's my tips so far:
Dump the outer plastic wire guide. Using 2 or 3 c washers from ebikes.ca, you can easily create a safe space for your axle wiring to exit the recent group buy motors with 135mm dropout widths on the axle shoulders.
2 installed:
You may also need some disk spacers to acheive correct disk alignment with the calliper:
These are both issues with various hubmotors, but the width of the X54xx makes aligning everything more challenging.
Oh, and forget about a multi speed freewheel at the back!
voicecoils
Postby itchynackers » Sun Apr 29, 2012 6:50 am
Ya, I don't see any way I can get my 5404 with 3 speed to fit a 135mm dropout (even though this is what was implied when buying). I have the c-washers. I have the disk shims. I just don't have a 150mm dropout bike to put it on. I think Doc eluded to this: you could shave down the stator lip a bit so that the covers are closer together. If you look at his pictures of lowracers motor, the covers fit much closer to the spoke holes. I'll just have to wait and see what transpires around here.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby voicecoils » Sun Apr 29, 2012 7:22 am
itchynackers wrote:Ya, I don't see any way I can get my 5404 with 3 speed to fit a 135mm dropout (even though this is what was implied when buying). I have the c-washers. I have the disk shims. I just don't have a 150mm dropout bike to put it on. I think Doc eluded to this: you could shave down the stator lip a bit so that the covers are closer together. If you look at his pictures of lowracers motor, the covers fit much closer to the spoke holes. I'll just have to wait and see what transpires around here.
I think a 135mm dropout bike could work. Remove the 10mm and 5mm spacer Crystalyte included (150->135mm) and with 2 of the 3mm ebikes.ca c-washers for wire exit protection and you're at 141mm. I think many bike frames may happily sit at that width. Any 130mm dropout (road bikes) or carbon frame won't like the stretch but steel frames or overbuilt MTBs may be fine.
Modifying sidecovers, axle shoulders or stators seems both risky and laborious.
voicecoils
Postby itchynackers » Sun Apr 29, 2012 8:02 am
Yes, but I believe part of the problem is with the 3-speed. You need more washer width to get to the outside of the 3 speed so it wont bind.
itchynackers
Postby wojtek » Sun Apr 29, 2012 4:16 pm
what is the teeth range on those 3 speed freewheels?
if you run 54xx at their best, prob best solution is to have ATS drive / schlumpf crankset. Yes it is expensive, but makes the build clean, one chain line, saves space on the handlebars [no shifters], no issues with dropouts width and perfect gearing for high powered hub motor
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby itchynackers » Sun Apr 29, 2012 6:18 pm
It has 14,17,20 teeth. Should be good for about 27mph tops pedaling. Maybe a single 11 tooth is in order...?
itchynackers
Postby neptronix » Sun Apr 29, 2012 6:34 pm
Can't fit a 11 tooth on it. It would require a custom freewheel be made just specifically for that motor.
I'm surprised that a 14 tooth fits on it at all.
http://www.vueltausa.com/components/chainrings/se-flat-chainrings.html
A monster size 60T chainring could help here.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby MadRhino » Sun Apr 29, 2012 6:42 pm
Are there really some of you buying a 33 pounds motor and think that a multi speed freewheel is needed. :D
The only reason to have more gears on the freewheel is to pedal the bike when it fails. Then, with the weight it would be good to think about a 34T. My bike hadn't shifted for a year and a half, commuting and riding the mountain trails on the top gear all the time.
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby Evoforce » Sun Apr 29, 2012 6:56 pm
As I mentioned in the group buy thread, I have had trouble with the spokes being laced incorrectly in my 26 inch rim. It did not have trouble with the valve stem being non-excessable. I also believe that there should not be grease at the end of the axle where the nylon locking nut tightens. I believe this may have lead to a couple of reports of the axle being stripped possibly causing over torquing of the threads.
Evoforce
Postby Doctorbass » Sun Apr 29, 2012 6:57 pm
Here is what i did for my etrike to keep the 11 tooth option.. I reworked the standard freewheel to remove some gear i did not wanted and also removed some lip that was taking too much width and than epoxyed them to make it hold since i removed the width that had the threads to save space.. and the DP420 work really well again :wink:
Here is the very first 5 speed freewheel WITH the 11 tooth gear!! :wink:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=27108&p=393785#p393785
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby MadRhino » Sun Apr 29, 2012 7:59 pm
On a TriKe Doc :wink: , I would use a mid drive dog shift, leaving the motor with a single cog and chain binder.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby wojtek » Mon Apr 30, 2012 3:23 am
NeilP wrote:Treat all those figures as guides only
Go to ebike.ca and find the spoke calculator and put in your own figures for the rim you buy and measure it yourself
A few mm out can be enough to get it wrong and have spokes you can not use
i find it hard to get the necessary info from motocycle rim sellers :(
ERD seems not to be part of regular specs for moto industry
wojtek
Postby Hobbit » Mon Apr 30, 2012 6:56 am
*cough* speaking of freewheels, would anyone know offhand where one might pick up a threaded freewheel, same thread as these rystalytes but with ½" x 3/32" cog dimensions instead of BMX(?). That way I could run the 3 speed front, single speed rear with front and rear derailiers. Seems like the easiest/cheapest solution for my particular application. Spent an hour or two googling but drawing a blank...
"The Precious"
Rans Fusion, Crystalyte H4080, Crystalyte 75V 50A stock controller,
66.6V 18s3p 24Ah zippy lipo.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=37934
Love.
Hobbit
Postby MadRhino » Mon Apr 30, 2012 7:15 am
LBS should have a choice, but if you want to buy online you will find many on Ebay or most bicycle parts dealers.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby Andje » Mon Apr 30, 2012 7:27 am
Just a video of my 5403 performance... Personally, I am very very happy.
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby ZOMGVTEK » Mon Apr 30, 2012 10:09 pm
Heres how my 5404 is mounted.
The plastic spacer around the wire exit is epoxied to the axle to hopefully eliminate the occasional spinning that started to cut my hall wires. I have a mark on the top of it to easily check if its rotated, and it hasn't since I glued it. The other side has a flat washer and then locknut. The black spacer isn't really required, but helps reduce the angle the wires exit the motor.
ZOMGVTEK
Postby Rustedhen » Tue May 01, 2012 1:24 am
Checked my plastic spacer and it has been spinning. Heat shrink is cut, but not the wires.
Put a tiny drop of superglue between it and the frame (being carefull not to get any between the plastic and the cover)
Will keep an eye on it until I have the motor off next time to glue it in proper.
Thanks for the heads up.
Rustedhen
Postby voicecoils » Tue May 01, 2012 6:21 am
Hobbit wrote:*cough* speaking of freewheels, would anyone know offhand where one might pick up a threaded freewheel, same thread as these rystalytes but with ½" x 3/32" cog dimensions instead of BMX(?). That way I could run the 3 speed front, single speed rear with front and rear derailiers. Seems like the easiest/cheapest solution for my particular application. Spent an hour or two googling but drawing a blank...
Shimano make both 1/8" for track/bmx chain and 3/32", not the cheapest freewheels though.
http://sheldonbrown.com/harris/singlespeed.html
voicecoils
Postby amberwolf » Tue May 01, 2012 2:43 pm
Or spin the motor backwards with the freewheel mounted, and hold a file on the side of the teeth. ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Hobbit » Tue May 01, 2012 3:54 pm
Ah, thanks guys, yes, I went to a local bike shop and picked up the 3/32' size 16t and fits the thread and the chain like a glove.It was quite novel, walking into a shop and walking out with the goods instead of googling this and googling that and getting it in the mail and it's not quite what I'm after. I might need to apply that approach more often.
"The Precious"
Love.
Hobbit
Postby Evoforce » Tue May 01, 2012 7:03 pm
I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which is applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
Evoforce
Postby Floont » Tue May 01, 2012 7:46 pm
Evoforce wrote:I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
Mine is like that too. I think they were all laced incorrectly.
I wonder how badly that will affect our use and performance of this beast?
Build 2: (present build): Rear x5304 on full suspension Mongoose, 127v 30s3p 10aH Turnigy Lipo, Lyen 24FET 100amp controller, CA2.2, 26" Hookworm front, 26" Crazy Bob rear, 203mm disc brakes, Airzound horn, twin Blaze 2 watt front lights - ~54MPH top speed
All my posts on this site are licensed under the Creative Commons Attribution-Noncommercial-No Derivative Works 3.0 License
Floont
Postby alsmith » Tue May 01, 2012 8:18 pm
alsmith
Postby MadRhino » Tue May 01, 2012 8:30 pm
Over crossing spokes is ugly, but not bad at all for wheel durability.
I kept the rim for I found it OK, but relaced it with rim washers.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Next
Who is online
Users browsing this forum: cal3thousand, Exabot [Bot], Heritrix [Crawler], kentlim26, runonpre and 10 guests
