Hobbit wrote:*cough* speaking of freewheels, would anyone know offhand where one might pick up a threaded freewheel, same thread as these rystalytes but with ½" x 3/32" cog dimensions instead of BMX(?). That way I could run the 3 speed front, single speed rear with front and rear derailiers. Seems like the easiest/cheapest solution for my particular application. Spent an hour or two googling but drawing a blank...
Evoforce wrote:I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
Evoforce wrote:Where are you guys getting the disk for the brake on these and are the holes lining up? And what mods are you having to do to get the caliper mounted?
Andje wrote:Just a video of my 5403 performance... Personally, I am very very happy.
Floont wrote:Evoforce wrote:I see on your pictures Zomgvtek, that your spokes are also improperly laced like mine. The spoke to the outside of the hub should go over the top of the spoke laced to the inside instead of spagetting behind it which applying side force to each spoke. I wonder if they were all laced this way on the larger rims?
[color=#000080]Mine is like that too. I think they were all laced incorrectly.color]
MadRhino wrote:Over crossing spokes is ugly, but not bad at all for wheel durability.
I kept the rim for I found it OK, but relaced it with rim washers.
megacycle wrote:Beautifull job, any concerns about the cable snagging, coming straight out.
Can a cover go over there in case the worst happens lean the wheel against something or even worse, god forbiddrop the bike on that side.
MadRhino wrote:If they could be found, I would gladly buy them. It is time consuming to shape them angled, oval, and bore to match the nipple head.
ZOMGVTEK wrote:megacycle wrote:Beautifull job, any concerns about the cable snagging, coming straight out.
I will mount pegs to the swingarm to protect the wire. The bike isnt done yet, the wire will be much closer to the bike and secured better.
Users browsing this forum: recumbent and 15 guests
