John in CR wrote:Moonshine,
Sorry to hear about your problems. A blown controller can create those symptoms Moonshine, especially the cogging when the failure occurred, and even the click when you tried it most recently. Commonly it can be verified with one easy test....ie With everything connected but off, turn the wheel. If it is more difficult to turn with the controller connected to the motor than with it disconnected, then some mosfets are blown and shorted in the controller.
Get yourself an ebike tester too. It takes the guesswork out of identifying most problems. eg Connect it to the motor, spin the wheel, and it tells you whether the halls and phases are healthy. Connect the throttle too it and twist...okay throttle is fine. If it's not the throttle or the motor and nothing else is connected to the controller other that the battery, then the problem is the controller or in the wiring going to it unless you have a battery problem.
John
moonshine wrote:Yea...when the controller is connected, the wheel isn't ridiculously hard to turn, but it does feel like im going against a magnet. But like i said, its a cog wheel like fashion. What i don't get is why lyen's tester is saying they're all good. I'm confused with all of the contradictions i've come across in the troubleshooting process. I'm gonna send my controller to lyen and see what he says.... Hopefully the motor is just fine...it should be. Thanks for the help everyone.
John in CR wrote:Blown fets aren't always visible. Controller failing and taking the halls with it would be a first that I've heard of, as would blowing all 3 at once.
MadRhino wrote:The big 5404 twisted 3/4 inch of steel dropout like it was lead.
This was jumping UP 4 ft stairs. 100v, 150A batt current
Building stronger now, and replacing phase wires![]()
Building a skid plate too, my 72 pounds V-10 can climb 3 ft vertical like a trial bike![]()
Got to build it strong enough to stand that kind of abuse, and find my old trial kit.
megacycle wrote:That's pushing me to get going on this fella'
Good old 26"iron horse, manitou fronts and fox vanilla rear.
megacycle wrote:Sorry to hear that but you got any photo or video of the bike up the stairs.
Floont wrote:My problem is that I cannot exceed 15 amps at WOT with the switch setting at 99% or even 120%. Don't get me wrong... It's an impressive beast but I was expecting more.
Users browsing this forum: Bing [Bot], GCinDC, Grey beard, MadRhino, sacko, wesnewell and 10 guests
