jonnyc wrote:Hey, thank you very much for the warm welcome.
1. Location: Edmonton, Alberta, Canada
----- Yes like other say, try out the Grin
2. Budget: I'd like to spend somewhere between $1500 - $2000 but have some flexibility.
----- Totally doable. you just need to keep careful track of what you spend on. Battery will most likely cost you the most if you are getting reliable battery. Do not get Lead Acid battery!
3. Typical Usage: I wish it was tear-assing and general mayhem but its really just going to be transporting me to work, the grocery store, etc.... general commuting, but i would like it to be fun and torquey! especially with the big hills I'm surrounded by.
----- You mentioned grocery shopping. This will mean a rack/trailer. Also you will need to be able to lock it up properly. Just FYI, most DYI ebike will not be easily lockable and can be very conspicuous because of the battery and bag, etc.
----- If you want something torquey, then you will need smaller wheels. 20inch wheel are the best on HS3540 for torque and 30+mph.
4. I'm not very experienced with DIY, I would likely have a bike mechanic help me with the nitty gritty.
----- If this is the case, I recommend you avoid DYI. You will run into problems and if you are not experience, it will mean a lot of headaches. But then again, you will learn a lot. It is really up to you if you are willing to spend the time to learn.
5. Expectations: Utility, low maintenance/tinkering is best once its built.
----- Get Direct Drive motor. If you are going to tackle the hills with the usual 26inch, I recommend HT3525 Motor. Just use 72V battery and you are set for 30+mph on flats. Get Lyen's 12 or 18 FET Controller and you will be set. Otherwise, get the HS3540 on a 20in wheel and you will similar setup. Like other people are saying here, keep the motor moving during the uphill to prevent frying the motor.
6. Environment: it does get quite windy at times and the hill I will be going up and down everyday is quite steep. Unfortuneatly I do not have the exact grade but I can tell you its one of those hills thats a bit scary to go down even in a car. It's quite long also, approximately 1000 feet.
----- See number 5.
Hope this helps, the advice will be much appreciated.
jonnyc wrote:Just finished a weekend of searching for a bike and think I may have found something interesting but would like some input.
Santa Cruz makes a frame called the Jackal. It's a trick frame which I'm not thrilled about, however it has replaceable dropouts which seem very beefy and its nice and light.
I realize it does not leave much space for the battery, but i'm thinking this may an option.
Any input would be much appreciated!
Users browsing this forum: Gow864, mark5, Samd and 10 guests
