HPC Cycle vs. DIY advice
Re: HPC Cycle vs. DIY advice
Postby jonnyc » Sun May 20, 2012 4:58 pm
Just finished a weekend of searching for a bike and think I may have found something interesting but would like some input.
Santa Cruz makes a frame called the Jackal. It's a trick frame which I'm not thrilled about, however it has replaceable dropouts which seem very beefy and its nice and light.
I realize it does not leave much space for the battery, but i'm thinking this may an option.
Any input would be much appreciated!
jonnyc
100 µW
100 µW
Postby john7700 » Sun May 20, 2012 9:53 pm
jonnyc wrote:Just finished a weekend of searching for a bike and think I may have found something interesting but would like some input.
That bike is all wrong for your needs, it is a DJ bike that is basically an over grown bmx. Not good for a commuter build. And that drop out is about running a derailleur (or not) not the tire drop outs per say.
You want a traditional diamond frame bike. You don't need to spend a lot. Just an entry level mountain bike. For a hard tail you would be looking for something like a Trek 3 series (~$475 retail) http://www.trekbikes.com/us/en/bikes/mountain/sport/3_series/3500_disc/# or Specialized Hardrock http://www.specialized.com/us/en/bc/SBCProduct.jsp?spid=62175&scid=1100&scname=Mountain Bikes like these are usually available used from Crags list or such. Just try to get one with disk brakes if you can, not mandatory but much better than rim breaks. Try to avoid Wall*mart type "bike shaped objects" as Dogman calls them.
Rear hub Kit from Grinn with CA
A123 Battery and frame bag from cell man if your budget lets you. If not a Ping.
A torque arm
A miracle mirror
A beefy rear rack
A pair of fold-able steel paniers
A beefy kick stand.
Some solder, some connectors, a couple of afternoons in the garage and 400 zip ties
= A good solid commuter rig.
Start Grinning :D
Schwinn Varsity
A.C.M.E. Rocket
Zippo Lighter
Meep!-Meep!
john7700
Location: The Happy Valley ................Western Mass. USA
Postby jonnyc » Mon May 21, 2012 9:33 am
Sounds like a much easier pill to swallow.
Thanks for the guidance!
jonnyc
100 µW
100 µW
Postby dogman » Mon May 21, 2012 12:52 pm
The choice of the bike to put the kit on opens a whole new can of worms to decide on. The standard advice is to look for a dirt cheap used steel frame hardtail mtb or commuter bike. Putting the kit on that bike teaches you what you need, what you like, and then you can start shopping for a $500-$1500 bike to build up into your perfect commuters road machine.
You may want fat tires or skinny, you may want more suspension or less. The road will tell you what your likes are, after you put 500 miles on the cheap steel bike.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Who is online
Users browsing this forum: cal3thousand, ev tocak, fmadwid and 5 guests
