Lyen controller not working at 37V
Postby cwah » Sun May 20, 2012 9:37 am
Hello there,
I've just received back my controller from Lyen after it stopped working after I used it for 30 seconds. Now it's repaired but last time the controller melted and I didn't even know why and I still don't know the reason... (and Lyen charged my for shipping cost on both way and repair cost so no such things as warranty with Lyen)
So I want to make sure it's working now and I'd like to limit the current at 25A and make it work at 37V too.
I've installed the program and here is what I have:
The low voltage is at 18.8V here and I click on "Start transmit"
Then I transmit and put the transmit button as described on Lyen manual
Now I can stop it, I clicked on "stop transmit" and I have the "finished" feedback:
The problem now is that the bike is still not working with 37V battery. But it works with my battery at 74V. I suppose the data transmission hasn't been done?
Do you know how I can make it work at 37V?
Thanks a lot,
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Re: Lyen controller not working at 37V
Postby motomech » Sun May 20, 2012 10:23 am
Lyen's default LVC for 12S Lipo is 37V, probably no coincidence.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby cwah » Sun May 20, 2012 10:46 am
Yes, but how can I change that?
It seems to be working on the program but nothing changes.
cwah
Postby miuan » Sun May 20, 2012 11:41 am
is your 5V and 12V rail holding full voltage?
it may be that your voltage regulators are low on voltage and can not power the MCU or hall and throttle sensors. check them, they should be LM317 for 12V and 7805 for 5V. if this is the issue, you may need to lower the R1 value to about 300 ohm to run at 36V.
miuan
Postby DAND214 » Sun May 20, 2012 11:50 am
Might be a dumb question. Did you see the transmit bar go accross the program?
My com is 3 and it shows that it transmits but doesn't do anything if on wrong port.
Also my low voltage is exact what I want not 10vplts or so less.
It's a keywin eb312 board. I would guess they are the same.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby cwah » Sun May 20, 2012 12:07 pm
Mian, sorry for my newbieness, but what's a 5V and 12V rail? Do I have to check the wires on my throttle?
Dand214, I've seen the bare go up on the program.
cwah
Postby NeilP » Sun May 20, 2012 12:21 pm
cwah wrote:Mian, sorry for my newbieness, but what's a 5V and 12V rail? Do I have to check the wires on my throttle?
5 volt can be checked at the throttle, but Mian is talking about opening up the controller to check them
What controller from Lyen do you have exactly? have you spoken to Lyen about this yet?
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby Jeremy Harris » Sun May 20, 2012 1:06 pm
Check with Lyen.
If the controller has linear voltage regulators (the LM317 for 12V and 7805 for 5V) then it needs resistors changing to work at 37V. These resistors are used to drop the incoming voltage to a safe level (below 40V) for the LM317.
If the controller has the switched mode regulator, then it should be OK for a wide voltage range and just need programming.
Lyen should be able to tell you which version you have.
Jeremy Harris
Postby shock » Sun May 20, 2012 10:49 pm
^ What he said. I believe the resistor network must be changed to run that low of voltage on a 12 FET
High Voltage
shock
Postby NeilP » Sun May 20, 2012 11:29 pm
shock wrote: I believe the resistor network must be changed to run that low of voltage on a 12 FET
Is that true of them all ? I am not so sure
I do believe that some controllers have a Switched Mode Power Supply front end that allow a very wide range of voltage inputs. But still, even a SMPS style power input front end, may still need resistor change to work.
From what I have discovered in the last two days trying to get my controller working again, there are at least ( if not more) 3 different design of power front end on the Xie-Chang / Infneon boards
There are two issues here that have be alluded to, but not actually named, and either one may require a resistor network change to fix:
1). LVC issue
2). Power stage issue ( would show itself by low 12v & 5v lines)
As wevhave said, only way to find out is speak to Ed Lyen and see what he has built the board to accept.
Since I have been lead to believe all the newer boards have SMPS power input stages, I suspect an LVC issue.
Oh....... A thought......I was struggling with this issue too, and overlooked the obvious. Do you have a Cycle Analyst? Is it plugged in to the controller?
Do you realise that a CA has an LVC setting too? And if that is set higher than the LVC on controller, then it will not work either. If you have a CA, unplug it. Now does controller work
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Mon May 21, 2012 2:15 am
Thanks guys.
I have this controller:
viewtopic.php?f=31&t=18214
I have a cycle analyst and put the LVC to 32V so that should be fine.
I talked to Lyen and he told me to remove the tiny 1.2K resistor on the bottom of the controller board in order to increase the LVC.
Will try it tonight to see how it works. If it doesn't I'll try to check the power stage issue.
cwah
Postby NeilP » Mon May 21, 2012 3:02 am
But you do not want to increase LVC, you want to decrease it
Think that was a typo on your part?
If the resistor he is talking about, is a standard axial type in a piece heat shrink, then that will likely be the R12 style mod or similar. If this has been done (r12mod) then the figures you enter in to the software need to be factored
Can't think exactly how to work it now, but it is easy enough,
Also, why did you buy high voltage controller then run it at so low voltage? You will have the higher voltage, lower current 4115 FETS in there.
Seeing your sig, Are you in London? Anywhere near Biggin Hill? I am often over there at the airport with time to kill
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Mon May 21, 2012 3:10 am
Lyen told me that
"The low voltage cutoff formula for your high voltage controller is the program "halt voltage" for low voltage cutoff "LVC" = (real LVC)/2. So 18.8v = 37.6v is about right."
Then if I "desolder the tiny 1.2K resistor on the bottom of the controller board. Then the program LVC value is then the same real LVC value"
Not really sure how electronic works. Just applying :lol:
cwah
Postby NeilP » Mon May 21, 2012 3:20 am
Yes, that will be right, R12 is also 1.2k so if the mod resistor on the rear is 1.2k the that is correct
Read to bottom of controller sale page you linked to earlier, first page, knuckles post about modding for other voltages
I have not read other pages yet, do maybe more there too
180mm disks
100V 20Ah LiPo
NeilP
Postby number1cruncher » Mon May 21, 2012 10:09 am
Also, I believe your IndicateMode should be 1:Comm GND when programming.
Go to http://www.ebike.ca and buy stuff to support the rEVolution!
GT Aerostream 700c w/ Gates Belt Drive, Rear Nexus 3 Speed Hub, Front 9C stock 36v10ah LiFePo4 - Gave to my dad
Electra Townie 700c Euro 8i 12s3p Zippy LiPo - Dented rear rim on monster pothole, temporarily out of service
Electra Townie 26" 3i w/ 9C Lyen 4130 12 FET 18s2p Zippy LiPo
All things lead to the path of least resistance.
"Political correctness is tyranny with manners." ~Charleton Heston
number1cruncher
Postby cwah » Mon May 21, 2012 2:45 pm
Thanks guys, I'm going to try to remove the R12 resistor and use 1:Comm GND when programming.
cwah
Postby cwah » Mon May 21, 2012 5:08 pm
This little resistor is sooo small:
How do I desolder that? There isn't even solder on the other side of the board. I may just burn it???
cwah
Postby NeilP » Tue May 22, 2012 12:47 am
You are not supposed to be removing that one, that is R12 itself, you are supposed to be looking for annextfa one on the back of the board, a normal one , possibly in a piece of heat shrink sleeving.
Take that off and you will likely have to send it back again
Show us a pic of back of board
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Tue May 22, 2012 2:55 am
Thanks Neil. Lyen contacted me and told me it was the little one with brown red red. I've only found this one:
On the front I haven't found anything that look like this:
Hope it's going to be the right one this time.
cwah
Postby cwah » Tue May 22, 2012 3:02 am
Ok, has been confirmed by Lyen. Going to remove it :)
cwah
Postby NeilP » Tue May 22, 2012 4:08 pm
If you are going to be workng with this sort of stuff, and are not familiar with colour codes on normal resistors, or the number codes on the SMD resistors
try this little freeware app...Windows only
http://www.schematica.com/resistor_colo ... sistor.htm
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Tue May 22, 2012 5:45 pm
I downloaded the program, will use it if I have to desolder other stuff in the future.
It's working at 37V now, so nice :)
Thanks all and Neil and also Lyen for his advice :)
cwah
Postby NeilP » Tue May 22, 2012 10:38 pm
That is good to hear
But one question
Why after buying a high voltage controller have you decided to run at such a low voltage?
180mm disks
100V 20Ah LiPo
NeilP
Postby cwah » Wed May 23, 2012 1:23 am
Good question!
Why I purchased my controller, I wasn't really sure of the performance my my conhismotor mini hub. But I wanted to reach 30mph. So in case if my 74V set up is not enough to reach 30mph, I can still increase the voltage without having to change the whole set up.
Now, most of the time I won't rum at 37V, I'll use it only for long distance journey in which low speed amd high efficiency is required.
This choice isn't that random lol
cwah
Postby NeilP » Wed May 23, 2012 2:10 pm
yes, makes sense, but even from 74 volt, you col dhave stil gon up to 24S and 100 volt with the standard controller. just needed the R12 mod, and only then if you needed the regen
180mm disks
100V 20Ah LiPo
NeilP
Next
Who is online
Users browsing this forum: chrashing, competitions, friendly1uk and 18 guests
